That's the definitive version of WBs for Nvidia 8800GTX and GTS
WB's are made of binded high quality copper and milled from the whole piece of copper.
As usual, the internal structure let the water flow very well without limiting the powerless pump;as a matter of fact you can even
get rid of expensive pump with high maximum head because a smaller pump like the Seltz L20 it's enough.
In addition to exceptional performances, structure made possible a loss of weight (LogiX is about 660gr and LogiS 620 gr) distibuted
on the VGA through all screws.
For their structure both are easy and fast to assemble, even for beginners.
CNC MANIFACTURE:
* Internal manufacture of fins and carving
* Lid milling
* Fittings of delrin with 10.70mm internal hole
* Grinding on the whole perimeter, base lightening and corner giving off.
* Logo carving
HANDICRAFT MANUFACTURE:
* High quality tin welding.
* Superficial trimming
* Painting
* Isolation with professional liquid which seals fittings between waterblock and fitting.
TECHNICAL SPECIFICATIONS:
* Made in Italy
* Compatibility:
- logiS: with the 8800GTS
- logiX: with the 8800GTX
* Top grade quality copper.
* Tubes compatibility: 10x14 - 12x17 - 14x19 sia Silicone che Cristall
* Weight:
- logiS: about 620 gr
- logiX: about 660 gr
Thanks to amd4ever for his special advise.
Now, some photos:
Logis
LogiX
for more info you can send me PVT
