Hi!
I am in a mess in trying to set downclocked frequencies for desktop use with my 8800GTX and activate default stock clock while in games.
I have tried RivaTuler, ATiTool, "new" stile NVidia Control Panel profile manager and even Coolbits to manage with the profile manager of the "classic" NVidia Control Panel.
RivaTuner works good, but while in game I have continous bumping between 2D and 3D frequencies. Here are a couple of shots:
If I try to use desktop shortcuts to load the profiles manually, the GPU and RAM does not change both, but only the GPU or the RAM changes.
In ATiTool I am able to set an executalbe list with witch activate the 3D profile, but even here the GPU and RAM does not change both contemporary: only the GPU changes while the RAM stays at the default stock clock.
The new lower RAM frequency does not even get saved in a new profile: it remains at default stock even if I have set it to a different one.
In the "new" NVidia Control Panel there is a nice profile manager, but unfortunately the previously saved profile wont load because I get an error:
nTuneServer:
There has been problem C:\Program Files\NVIDIA Corporation\nTune\Profiles\new.nsu
Last, I have tried to load the "classic" NVidia Control Panel with Coolbits, but even here I get problems: I am not able to save new profiles.
The just disappear right after having saved.
Now.... is there a way to manage REAL dynamic overclocking??
Even application controlled would be good.
Thank you all!
