I've run into a weird problem I did not have before.
I have the 10th anniversary edition of Crucial Balistix ram. It is rated at 3-3-3 2.2V.
When I first got the ram, It would boot find at 1.8V (Default for p5B), I would go into bios and changed it to the rated 2.2v.
I've had it runing DDR 920 for 4 months now.
I decided to mess around with my computer to see if I can push my clocks higher. I'm hitting a wall at 481 so I have to reset my bios.
BUT, my sticks no longer post when I reset bios because it resets mem to 1.8V stock. This is VERY VERY annoying because I have to borrow a stick of DDR2, go into bios, and change it to 2.2V.
What caused the ram to no longer boot at 1.8V? or whatever the stock p5b is.
I stopped trying to mess around with the board because if I reset the bios again, i'd have to borrow a stick of ram just to get started.
By the way, when the ram is at 2.2V, it will do DDR 950+ no problem. I've ran memtest and test # 5 over night. Mem is fully stable at 2.2V.
Is there some thing board to make the default higher?
Thanks in advance.
