Hi ppl...
This is the DFI RD600 power...
We've done this some days ago:
...and yesterday...
Hi ppl...
...and yesterday...
nice chip. What vcore did you use?
オタク
"Perfection is a state you should always try to attain, yet one you can never reach." - me =)
~1.68 in BIOSOriginally Posted by Fr3ak
Great! The Son of The Father.
That's really nice clock's on air, congrats!
It's big difference between spi and ss clocks.
Try it on DI or even ln2.
Regards!
Is it me or is looks the SPi 1M time very long? 17 sec with cpu at 3.6 and ram 600mhz cas4 ?!?!
nice air clock on that low-cost chip![]()
| '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
| '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
| '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
| '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
| '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
| '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
| '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
| '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
Originally Posted by saaya
Do not compare to a 4mb chip in 1M, 4mb chips are much faster in 1M calculation.Originally Posted by .devastatioN
Still, with ram at 600, the score should be better.
Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
Case: Murdermodded TJ-07
sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
the time aint the fastest that's for sure
sub 17s is within reach with cpu at 3400 and ram 450 4-4-4 on a 2mb chip
other than that, nice oc. I can't go over 390fsb on my e4300 no matter what vcore/vnb
@TheInVisibleGod
did u do the 1066 bsel mod and if you did what kinda gain in FSB did you obtain over 800?
With a Tuniq!Originally Posted by Achill3uS
The week I'll tell you later, I'm not shure. The ambient temp should be around 19/20ºC.Originally Posted by sparkY1000
Yes, You're right. We're working on it...Originally Posted by .devastatioN
No... I don't, what's bsel mod!?Originally Posted by Slay0r
http://xtremesystems.org/forums/showthread.php?t=134939Originally Posted by TheInVisibleGod
http://xtremesystems.org/forums/showthread.php?t=132900
basically allows your chip to boot at a default of 266*9 rather than 200*9. some have reported that this mod also helps in getting a higher end fsb .
Thanks Slay0r!![]()
You are welcome![]()
may it help you push that chip further
very nice chip , stepping? and what voltage did it take for 3.6?
i5 2500k @ 4.6ghz 1.335v [ASUS P8Z68 Deluxe]
8gb gskill ripjaws f3-12800cl8-8gbxm
600gb velociraptor + 1TB black
MSI N560GTX-TI Twin Frozr II + x-fi xtrememusic
corsair hx-620w + lian li pc201b + dell 2408fpw
d-tek fuzion1/ddc2 + petra top/thermochill pa120.3
Impressive 445 on air (i test 2x4300 Q635/Q649 , max 425 on air and 475 under LN2)
Nice clocks man! Congrats. You are the first to beat me with the CPU on air(got 3949 MHz on mine :P)
I also use the DFI RD600 board and i have done som kind of strnage observations. I would like to discuss them with you and see if you experience the same problem (after seeing you pi result, i guess you do).
I will send you a PM later on.
/Tjalve
CPU: Intel Core i7 965 EE @ 3,8GHz
Motherboard: Foxconn BloodRage X58
Memory: 3x 2GB Corsair Dominator PC1866 9-9-9-24
Graphics card: Asus HD4870 + Accelero S1 rev2 + 2st Zalman 120mm
Cooling: Scyche Mugen 2
Power supply: Antec Earthwatts 500W
Update...
http://valid.x86-secret.com/show_oc.php?id=175266
Next step will be watercooling and later sub-zero...![]()
very nice..I'm a DFI RD600 user also.. can you post your bios settings? thanks..
Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
X6800, E6750 es
Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)![]()
Ati FireGL V5100, Elsa FireGL V3100![]()
water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)![]()
Silverstone OP650![]()
raptors, baracuda![]()
He was getting max OC on air and you guys complain about Pi times =.= . The title isn't about Uber Pi times at 4Ghz on air, that thing is as flaky as a sheep on crack.
Even if I had to slacken every single timing possible to raise my CPU clocks, I would still do so. It's to see how far the CPU will go, tweaking and tightening can wait.
To OP: very nice clock, you beat my E6300 on normal air :P:. (not the freezing one -7 degree C like some lucky people among us have)
E6300 / P5B-E+ / 2x1GB Crucial Anny / X1950XT / Xfi XM / 2x320GB 7200.10/ PCP&C 510SLi / Dell 2007WFP
Achieved:
4Ghz E6300 on air - 115% OC
666Mhz 5-5-5 2.45v
Yes plz , give bios settings.
Voltage in bios...
tnxs for sharing mate..really good setup you got there..
X6800, E6750 es
