Page 1 of 2 12 LastLast
Results 1 to 25 of 38
Thread: Matrix Raid - Oh Yeah
    Jan 2005
    Hamilton Scotland
    Finished the last bit of my upgrade to c2d with 2 more hitachi sata2 80gb.
    Giving:-
    4x80gb Hitach1 Sata2
    Using Intel Matrix Raid
    2 Raid stripes :-
    1st "Fast" Raid using 1st 17gb of each drive = 64gb in Raid0 128kb stripe size std cluster
    2nd "slow" Raid using remaining space = 242gb in Raid0 128kb stripe size std cluster.
    Fast Raid
    1) 8M Burst=3,336 Read=203 Access=9.7 CPU%=5
    2) 32M Burst=3,456 Read=237 Access=9.7 CPU%=4
    Slow Raid
    1) 8M Burst=3,475 Read=176 Access=12.1 CPU%=4
    2) 32M Burst=3,461 Read=186 Access=12.2 CPU%=6
    Think the hitachi & Matrix is a pretty decent combiination.
    For more on Matrix Raid see Enter The Matrix: Slice out and get the best part from your hard drives
    & Intel® Matrix Storage Technology Only real down side is the matrix raid has to be configured within XP, so i have a small xp partition on 1 of my data drives.
    • i7 920
    • DFI DK X58-T3eH6
    • G.SKILL PI Black DDR3 PC 12800 CL8 6GB kit (F3-12800CL8T-6GBPI-B)
    • Crossfire 2x ATI HD4670 GPU 785 Ram 1060
    • Thermaltake Toughpower 1200w
    • Cooling: Water - EK Supreme
    • Lian Li V2000B+
    24/7 OC 4Ghz 20x200 x8 1600Mhz 8-8-8-21
    Official Gigabyte X48T-DQ6 Info Thread
    DFI DK X58-T3eH6 on Test
    Mar 2006
    Back in Thailand for now.
    Interesting post. Just setup my first raid. Have one volume setup as raid 0 total 300 gb (2x150 raptors).
    Have used HD Tach and my burst speeds read about 250 mb/s.
    For the fun of it I right clicked on the volume and enabled write back cache and it jumped to 3000 mb/s. kin hell
    The graph was well choppy though. Just briefly checking out that thread, I'm guessing that you need to setup more than one volume, with the first being below a 100 gbs. Is that right?
    Cheers for the info.
    RLM
    QX9650@4.5ghz Vapochill LS
    E8600 (Boxed)
    Rampage Extreme
    OCZ Gold DDR3 (8500) 1680 7-6-6-20-2T
    4870x2 Vmodded + Ek Nickel
    9800GX2 Vmod + EK H20 (Stored)
    Thermaltake TP 1000W
    Lian Li P007 Case
    Jun 2006
    There is, speed-wise, no difference between a single RAID volume partitioned, and two RAID volumes. The access times are only superficial.
    It's a nice feature, but that's all it is - a feature.
    I didn't know it has to be configured from XP, I configured mine from the BIOS (though I have the ESB2 Server ICH, not ICH7/8R, but I doubt there is any difference).
    P5E64_Evo/QX9650, 4x X25-E SSD - gimme speed..
    Quote Originally Posted by MR_SmartAss View Post
    Lately there has been a lot of BS(Dave_Graham where are you?)
    Jan 2005
    Hamilton Scotland
    @RLM
    Yep it's easier to use a % of your total real estate(GBS) Thie above sizes were based on my 1st attempt where i went for a 85gb fast raid
    You can see the distinct drop at the end around 77.5% mark. so 77.5% x 85Gb = 66GB. Resizing to this has the benefit of lifting the benchmark perrformance of both drives as the 2nd raid is getting faster access space.
    So my overall factor% (the X from Bing's chart) = 20.6% 65/(4x80)
    @alfaunits - Don't think you've got the point m8. That's why i added the links at end of 1st post.
    see
    Bing's Chartfrom 1st link above
    As u can see the"Fast Raid" can give a far faster raid than average as it 's using the fastest parts of the component drives. I'm using this partition for my main os & swap file.
    Hdtune shiows min / max & avge so there is a reasonable consistenvy of high access speed.
    Fast Raid HDTune
    The 2bd raid volume which i'm using as raid0 atm usese the ramainder & is slower. Here there is a far bigger range of speeds with of course a corresponding lower average.
    The point is the matrix raid allows up to 2 raid volumes to be stripped across a collection of the same drives as shown in the chart.
    luck
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    These numbers just frankly don't make sense. I am referring mainly to the burst speed here.
    Why? Well, lets assume you are using 4x full-speed SATA II ports here, for a total bit rate of 12Gbps, or 1.5GBps. Yet your burst speeds are showing in excess of 3GBps! That's over *twice* the maximum, theoretical bandwidth (which you will never hit).
    Clearly there's something else going on here. You said you set this up in Windows... I'm almost wondering if the burst speed is coming from caching data to RAM, because it's *not* coming from your hard drives.
    With that said, the rest also comes under suspicion...
    I'm surprised you didn't notice that your burst numbers - being more than 10x what you should see with one drive - were at least somewhat suspicious.
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
    Nov 2006
    There are a lot of people ignorant about Matrix RAID over at OCForums and they love their benchmarks over there. I gave up trying to explain how 15GB of data on a regular or Matrix RAID array will have the same performance. Instead of using a Matrix array or a partition for that matter, they should invest in a good defragmenter.
    Thermaltake V9 BlacX ][ XFX PPR650W ][ Gigabyte X58A UD3R ][ i7 950 @ 4.2ghz(21x200)
    Corsair A70 ][ Corsair XMS DDR3-1600 3x2GB ][ Asus GTX560 Ti 1GB ][ 120GB OCZ Agility 3
    2TB Hitachi 7K3000 ][ Samsung SH-S183L DVD-RW ][ Asus Zonar STX ][ Tannoy 501a
    heat
    Nov 2005
    PHX
    I'm also using a 69GB slice/partition w/ 2 74GB ADFD's. It def feels snappier than when the whole drive's used. As for the crazy burst rate, I thought the SATA limits were per port? And o&o did a wonderful job w/ my single raptor, but had a helluva time w/ a mirrored array. Perfect disk threw a fit too. Anyone successfully used Diskkeeper's full version on their arrays?
    Jan 2005
    Hamilton Scotland
    I accept the burstrate looks a bit silly but it apears common in 2 versions of software, it isn't that impartant imo.
    There are some odd burst rates scattered around have looked thru the thread here lawrywild - Here's my 2x Seagate 7200.8 200GB
    Accept that some of it is statistical averaging. If i set up a 65gn partition on a clean single raid0 & put my primary os on it then i would expect to see a similar performane to my "fast Raid" stripe.
    But i like the matrix flexibility in being able to have a 2nd stripe which may be raid1, 5 etc., At the moment i have my less used os's on it xp64, Vista 32 & 64 rc2 + a data partition. So when running SP2 am getting the max benefit
    But like Jodiuh says
    is an absolute fact.
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Nov 2006
    I'd love to see some timed actual proof, which not one person has done that I've seen. Considering it's the same chipset, whether Matrix or not, I'd bet there'll be not one difference. Install an OS and programs on an array, time them, image it to a data drive, reimage to a new array and time again. If I had an Intel ICHxR chipset, I'd do it in a heartbeat.
    heat
    Xtreme CCIE
    Dec 2004
    Atlanta, GA
    Quote Originally Posted by Jodiuh
    The SATA limits are per port, 12Gbps = 4x 3Gbps ports.
    I have used Diskeeper successfully on a mirrored array myself (though if you're using matrix raid, it could be the controller is having some issue with that I suppose, however strange that would be).
    @Supershanks:
    The burst rate isn't "a little silly", it's downright "horribly wrong".
    Xtreme Network:
    Jan 2005
    Hamilton Scotland
    Sorry you mean what exactly??
    U should know what us brits are like 4 understatement
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Xtreme Cruncher
    Jun 2006
    San Jose
    I dont think the burst numbers are real, it does this on the ICH7/8 as well. I was running something similiar on P5W/Commando and performance sure doesnt feel like those burst speed. As for the partition slice, it seems the program is just reading off average throughout the partition. So if you have a shorter partition, the beginning will be faster and your average will be higher just before it starts to dip. So this slice method is just manipulating the benchmark or is it real world performance? I havent done this method so I can't comment. The only real data I did was a full partition of ICH8R w/ 4x raptors, i installed vista with a stopwatch in about ~14:56 min by the time desktop shows. With the areca setup and same drives, about ~11:20 min.
    For all your cooling needs: ShopPTS.com
    System:
    Rampage Formula // E8400 @ 4.0 (1.28v)
    4x 1GB Ballistix Tracer @ 600 (5-5-5-15)
    4x 74GB Raptors 16MB Raid-0 // Samsung F1 1TB
    eVGA 8800GTS 512MB @ 800/1111/2000
    Corsair HX620 // LG246WP
    Cooling:
    D-TEK FuZion // PA120.3 // 3x Yate Loon SH
    MCW60GT // EK Multi-150 // DDC-2 + Petra's Top
    Xtreme Mentor
    Sep 2006
    That burst is just some caching going on. Someone on this forum looked at this a while back when people were posting insane bursts with their areca cards. It's not really there.
    Nov 2006
    Quote Originally Posted by Supershanks
    That showing those benchmarks has nothing to do with actual performance, that perpetuating an uproven theory that Matrix RAID actually increases performance without objective proof is sorta irresponsible? A partition can do the exact same thing but I don't see people claiming how fast their system improved when they've done that? Why, because HD Tach can't benchmark partitions.
    heat
    Jan 2005
    Hamilton Scotland
    @Speederlander
    Makes sense all caching is on, normal running, except av/fwall down & network disabled while testing.
    Reading round i have seen it said that
    intel from time to time do tricks with their drivers giving wrong info..
    Just coming from AMD rig i've no idea if there's any validity in this comment??
    @syne_24
    Totally Agree - Which is where i got my original slice size from
    Post#8
    What i see as a benefit of matrix is the abilility to have a 2nd raid slice with a different Raid 1,5 tec., to get the best options whilst gaining the benefit of the max number of drives.
    @tuskenraider-
    I aren't making any political or propaganda statement, nor am i a believer in any conspiracy theories . I'm just a relative newbie to using 1) c2d - new build & 2) Using raid + matrix raid.
    Just saying my hd performance feels faster don't convey much does it?? Thought others may like to share & the software shots where a reasonable way 2 do it
    1st line of this thread
    Cheers
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
    Nov 2006
    @tuskenraider-
    Cheers
    I'm certainly not here to belittle the joy of your system, and you certainly have the grasp of what Matrix RAID was intended for. It is just that I've seen people take those benchmarks and ignore all the reasoning and logic behind the results and make lots of unproven claims. I would think truth and objective results serves everyone best. With that said, enjoy your new setup.
    heat
    Jan 2005
    Hamilton Scotland
    Cheers m8
    Wasn't aware of this b4, understand where your coming from
    Is the only way we properly learn, which is what I intend doing & 1 of the primary reasons i'm here
    luck
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
  18. #18
    Xtreme Mentor
    Sep 2006
    Behold the DRAMA of RAID! :thumbsup:
  19. #19
    Jul 2006
    Vancouver, BC
    My understanding is that the main benefit of using a small partition on the outer cyclinders of the disks (which can be done on any single disk or any RAID controller, not just Intel's Matrix) is that you effectively gain very good seek times on that partition because when limited to that partition, the heads have to move very little to cover the utilized surface. All goes to hell as soon as you utilize the other larger partition because then your heads are back to seeking across the full platter.
    Thus if you want super fast seek times, you should define a partition for your system that is as small as possible and ONLY use that. It's very expensive to ignore the rest of your disk's storage capacity this way, but it will get you wicked seek times.
    It should be noted that this trick will not improve STR... it may make your HD Tach curve look relatively flat but that's because you are looking at a very small subset of it.
    Supershanks... what is the rated seek time for those Hitachi drives? I'm assuming around 12ms? Notice how your fast partition has seek times around 9.7ms? That (as I understand it) is the only benefit your realize from doing this. And to shave those 2.4ms off the seek times (which is a 20% reduction in latency), you have to ignore 80% of your disk capacity! Worth it?
  20. #20
    May 2006
    Philippines ^_^
    very nice raid setup..
    I envy you.. DFI uses slow promise card
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  21. #21
    Jan 2005
    Hamilton Scotland
    @erwinz
    very nice raid setup.. I envy you.. DFI uses slow promise card
    Thnx m8, i very nearly got that board. Hope everything else is ok.
    I switched to a single raid to prove
    Post#8
    Follows exactly as expected
    the rest of the single raid speed curve follows theat of the 2nd slice
    So I then tried with Write back cache disabled Comparison
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
  22. #22
    Nov 2006
    About time someone posted a graph comparing the two and performance is unchanged, just as expected.
    heat
  23. #23
    Nov 2005
    PHX
    Notice his STR changes quite a bit w/ the cache on tho. I'll finish up the Windows install, throw some games on there, and time the loading to see what effect cache has there. Perhaps I'll do some unzipping too.
    Quote Originally Posted by Serra
    I have used Diskeeper successfully on a mirrored array myself...
    Thanks, I'll give that a go.
  24. #24
    Jan 2005
    Hamilton Scotland
    What i can't quite get my head round is the no cache Bottom Pic.
    I would have expected it to be an almost constant -x mb/sec slower than the cached performance but the uncached runs pretty constant ~160ish until it then merges with cached performance just b4 279gb.
    Any offers??
    • i7 920
    • DFI DK X58-T3eH6
    • Lian Li V2000B+
  25. #25
    Jul 2006
    Vancouver, BC
    I don't understand why write back cache affects STR at all. Isn't write back cache designed to write to the disk when it's idle while the HD-Tach benchmark is a READ test? I suspect something wacky is going on with HD-Tach.
