Results 1 to 25 of 73
Thread: GTX360 or PA120.3 ? which 1 to buy ?
Threaded View
    Sep 2006
    Surat, India.
    Red face GTX360 or PA120.3 ? which 1 to buy ?
    How much is the performance difference between the two ?
    GTX360 is cheaper, bit thinner n its also optimized for low cfm fans
    is the PA120.3 worth the extra cash, or should i just stick to the GTX360 ?
    if the diff in performance is less like 2-3c, then i will buy the GTX360, if its anything more that that, PA120.3 it is
    I cant find any real-world comparision out there,
    PS: The main config of my WC would be
    Pump: MCP 655
    CPU block: D-tek FuZion
    GPU Block: MCW60 for 8800gtx
    Pipes: Tygon 1/2in ID 3/4in OD
    Help me guys
    TIA
    ANP !!!
    Sound: Asus Essense ST | Wharfedale Diamond 9.1 | Norge 2060 Stereo amp | Wharfedale SW150 sub (coming soon)
    Camera Gear: Canon 6D | Canon 500D | Canon 17-40L | Canon 24-105L | Canon 50mm f1.4 | Canon 85mm f1.8 | Rokinon 14mm f2.8 | Sigma 10-20EX HSM | Benro A3580F + Vanguard SBH250 | Bag full of filters and stuff
