After large preperation, it was done: My first Dry Ice session! I made a lot of pics to show how I did my first session.
1. Purchase basket
1.1 DICE Tube
First of all: The DICE Tube, built by Stummerwinter from Germany.
The tube with screws and isolation:
Container from above
Here the structure:
1.2 Little things
Vaseline:
Something to see the temperature
Exactly for the container
Washing bottle
Silicon paste
Eye protector
I also ordered a cheaply graphic card, just for secure, that my 7800gtx remains alive
All together
1.3 There is Dry Ice!
Here are two pics, DICE coming to me.
2. Mainboard: ready to be launched!
2.1 Vmods
Vdroop & Vcore mod
2.2 Vaseline & Thermal compound
Vaseline around the base area
The vaseline spray again
You can't see any much, but here the result:
In the base:
Don't forget the thermal compound
3. DICE in action!
build up the tower on the Mainboard:
Let's begin!
Take off the Mainboard, just for secure
The dice inside the container
Temp goes down(37,4 Fahrenheit):
Alcohol in the tube
Nice effect!
Temp sinks(-4,0 Fahrenheit)...
and sinks(-23,8 Fahrenheit)...
sinks much more(-88,6 Fahrenheit)...
-75°C (-103 Fahrenheit) was the lowest temp I reached.
The view above
Turn on the cumputer *fear*
Yeah!! it works!!!
5. Result
After I tested 4 hours, I came to a result. Here my Config:
- Core2 Duo E6600 ES
- P5B Deluxe
- Corsair XMS2
The result watercooled:
Core2 Duo E6600 2,400ghz@3,942ghz / Vcore 1,6 / Fsb 438 / Timings: 4-4-4-15 / Watercooled / 13,000s
with Dice:
Core2 Duo E6600 2,400ghz@4,585ghz / Vcore 1,635 / Fsb 509,5 / Timings: 4-4-4-8 / DICE / 11,312s
600mhz more
Sorry for my bad english!
Greets from Germany
Flow
. The CPU also has a fsb wall. Watercooled I only get 3,8 stable.
