http://valid.x86-secret.com/show_oc?id=172774
Its in fatality An9 mobo,2*512 micron D9GCT,cooled with Thermaltake BigTyphoon
Some more pics:
Some more pics:
Sry for bad english
Sry for bad english
wow...nice OC on that opty....
ASUS Maximus VI Hero
Intel 4770K Delidded @ 4.7GHz
Swiftech DDC w/Petras Top
EK Supremacy Direct to Die/MCW80 GPU
XSPC 120.4
2x8GB G.Skill
MSI 6950 2GB 975/1400
Samsung 830 2x128GB RAID0/WD 2x3TB RAID1
Corsair 800D with AX850W PSU
Dell U3011 30" LCD
Seems like a 6000+ limit of 3.4Ghz.Very very nice clocks man,and the temps are very good.![]()
It its bench stable at 3.38Ghz?
Its my pals rig,but he said its full stable at 3378Mhz at 1.475V (set in bios)Originally Posted by informal
Sry for bad english
Very impressive clocks. What stepping is it?
Btw, where did he get that desktop background? Can't see much of it but it looks cool.
ask him if more voltage helps, and if he can provide any orthos shotsOriginally Posted by Lamika
Got a fan over those memory sticks? No? Well get to it before you kill them
Simply amazing as for 90nm![]()
Any chances for rig pic??
Thanks for bringing this info Lamika![]()
RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
SmartPhone Samsung Galaxy S7 EDGE
XBONE paired with 55''Samsung LED 3D TV
Mainly higher OC results due to improved 90nm production capabilities.
no, it's definitely some tweaks to the core. if it was a change to just the silicon, the changes would show up on the stepping printed on the IHS only, not a change of the silicon revisonOriginally Posted by informal
what are the changes though? i wish i knew![]()
wonder what the price difference is between the two.
~Mike
Main Rig: Intel Core i7 7700k @ 4.2GHz, 64GB of memory, 512GB m.2 SSD, nVidia GTX1080Ti
NAS: QNAP TVS-1282, 8 x 4TB WD Golds(Main Storage Pool), 4 x 960GB M4 Crucial (VM Storage) , 2 x 512GB M.2 Caching
Private Cloud: 4 Nodes (2 x Xeon 5645, 48GB DDR3 ECC/REG, 1 x 1TB HDD, 1 x 960GB SSD/Each)
Distributed Encoding Cloud: 4 Nodes (2 x Xeon x5690, 24GB DDR3 ECC/REG, 1 x 128GB SSD/Each)
Feedback
EBAY:HEAT
That's why i said MainlyOriginally Posted by ozzimark
wow, so are the F3 stepping for opty's only?
Athlon XP-M 2500+ 0343MPMW The King is Dead!
Phenom II X6 1090T 1025GPMW Long Live the King!
I'm from the church of the operating room
nope, you can check it here.Originally Posted by VulgarHandle
now i gotta figure out where to get one of the CZ opterons. i've only been seeing CS at newegg![]()
I want X2 3800+ CZ but they are very hard to find.Probably will go with G1 3600+ since they OC like crazyOriginally Posted by ozzimark
and it's silly how cheap it is
wodering how fast it is compare to C2D??
AMD Phenom II 955 BE 200*19.5 @ 1.440v
DFI LP DK 790FXB-M2RSH (06/07/2009)
G.Skill F2-8500CL5D-4GBPK 2GB * 2 400Mhz @ 4-4-4-10-18 2.1v
ATi HD3870 X2 1GB ???Mhz/???Mhz
Dell 24" 2405FPW LCD
WD Caviar Black WD1001FALS * 2 @ RAID 0
Enermax Infiniti EIN720AWT 720W
There are plenty of benchmarks out there that compare C2Ds to Athlon FX/X2 chips. General results seem to indicate that the C2D can spot the A64 a 400mhz handicap and they will be equal. So I would imagine that at that max overclock his chip would compare well with a C2D X6800 (2.93ghz).Originally Posted by showmanlkz
Gigabyte MA790X-UD4P//Dell Latitude D620
Phenom II BE 940//Core 2 Duo 2.0Ghz
2x2GB OCZ Reaper//1GB PC5400
640GB WD Blue//80gb 7200 rpm hdd
Radeon 4850//Geforce 7300 Go
Hello
Its an e4300@2890Mhz to compare opti@3300Mhz
Sry for bad english
I forgot:the cpu stepping is:ACBVF 0701TPMW Bach number 0008 I think its a a nice one![]()
Sry for bad english
Wow. Awesome OCwell done.. on air too.
I'm quite keen to put my F3 5600+ into DFI board after seeing these results. I can't squeeze 3.3 out of it atm. Wondering if it's the board or a poor OCer.
Lamika:Great work!
Nice OC. Congratz!![]()
"We are competing, competing to win. And the main motivation is to compete for victory" - Ayrton Senna
