Hello again....![]()
Here are "some" Vmods of the ABIT IN9 32X - MAX mobo.....I don't have much time to do some explanations right now about them but I'll be back....
Let's start with these mods and I'll update time to time....
A big thanks for esdee's digicam (mine is gone for RMA and still nothing)
These are two mods in the same picture....
VMCH (VNorthbrigde) and VFSB (VTT of the CPU)...
These are also two mods in the same picture...
VSP (VSouthbridge) and VHT (VHyper Transport)
This is the VCore of it......The same might be for the ABIT Quad GT as well but I'll take a look for it so as to be sure....![]()
LAST - for now - are the VGTLRef mods.....These mods are esspecially for the QUAD CPUs so as to reach HIGHER fsbs....
By doing those ones, I got my QUAD (actually Gorillakos') from 3D benching at 355MHz to reach 404MHz - still searching it though for higher - under AIR.....
It's a bit complicated though BUT if you print the picture and follow the traces, you'll understand it.....![]()
For this mod credits MUST be given to Freecableguy who has pointed out the pins of the CPU and said that we need VGTLRef mods so as to take our QUAD at a higher fsb....![]()
I'll be back with some more though.....![]()
I forgot to capture the VMCH booster mod that IS NEEDED TOO....It's like the ABIT's AW9D-MAX mod......A cable on the back of the mobo....
Any question you might have, I'll be glad to answer....![]()
