Results 1 to 6 of 6
Thread: Determining whether the IHS is soldered or not?
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Hey I know someone who is interested in popping the lid of his FX-62 but we don't want to do it if the IHS is soldered on for obvious reasons. The date code is 0630vpmw, is this before or after the IHS's got soldered?
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
    Sep 2005
    Las Vegas, NV
    hehehe, Its only 400 bucks to replace the FX-62... miz well give it a try and tell us.
    ~Mike
    Main Rig: Intel Core i7 7700k @ 4.2GHz, 64GB of memory, 512GB m.2 SSD, nVidia GTX1080Ti
    NAS: QNAP TVS-1282, 8 x 4TB WD Golds(Main Storage Pool), 4 x 960GB M4 Crucial (VM Storage) , 2 x 512GB M.2 Caching
    Private Cloud: 4 Nodes (2 x Xeon 5645, 48GB DDR3 ECC/REG, 1 x 1TB HDD, 1 x 960GB SSD/Each)
    Distributed Encoding Cloud: 4 Nodes (2 x Xeon x5690, 24GB DDR3 ECC/REG, 1 x 128GB SSD/Each)
    Feedback
    EBAY:HEAT
    Jan 2007
    Boston, Massachusetts
    AMD chips come with soldered cores now? Really only one way to find out for sure.
    Codename [GOLIATH] - Lian-Li G70B
    Loop 1 [D-Tek Fuzion - PA120.3 - 3xSan Ace 1011 - DDC2 w/Petra's top] Loop 2 [MCW60 - EK ASUS NB 5 - EK ASUS 4 SB - BI GTX240 - 2xSan Ace 1011- D5]
    ASUS Maximus Formula - 8GB OCZ REAPER DDR2-8500 - Q6600 - EVGA GTX260 core 216 55nm - Silverstone ST75F
    Codename [Black-Dragon] - Lian-Li PC65B
    Loop [Dangerden TDX - BI GT240 Stealth - 2xYate loon SL - D5]
    DFI NF4 Ultra-D - 2GB Teamgroup Croonus(5BF)@260MHZ - Opteron 165 CCBBE0616XPMW@2.88 GHZ- ATI X1900xt - Corsair HX520
    Sep 2005
    Las Vegas, NV
    yes, they do come with soldered cores now.. better heat transfer..
    ~Mike
    Feedback
    EBAY:HEAT
    I am Xtreme
    Apr 2005
    Upstate, NY
    Quote Originally Posted by SparkyJJO
    Check the Copyright Date on the IHS. afaik, if it's copyright 2001 AMD, it's not soldered. Copyright 2005 AMD is soldered.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Love and Peace!
    Dec 2004
    hiding somewhere!
    applies to all, but not all are soldered. while the C 2005 chips have been soldered, i'm pretty certain i've seen a few that aren't... so it's really a toss-up. better safe than sorry though, eh?
    Got a fan over those memory sticks? No? Well get to it before you kill them
