Results 1 to 7 of 7
Thread: 4GB G.Skill 6400PHU2 HZ Micron D9GMH @500Mhz 4-4-4-12 at 2.25v on Asus 680i Striker
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Cool 4GB G.Skill 6400PHU2 HZ Micron D9GMH @500Mhz 4-4-4-12 at 2.25v on Asus 680i Striker
    Some folks say 4x1GB has issues on 680i boards for orthos blend test. So thought I'd try it out
    4x1GB G.Skill 6400PHU2 2GB HZ Micron D9GMH 629 batch for the first time on Asus 680i Striker Extreme.
    System:
    • Intel Core 2 Extreme X6800 L627A872 B2 Step 6
    • Swiftech Apogee/Radiical Triple Fan Single Pass Rad/MCP655 + Kayl 100W Custom PSU
    • Asus 680i Striker Extreme 0402 bios
    • 4x1GB G.Skill 6400PHU2 2GB HZ Micron D9GMH 629 batch
    • 4x80GB Hitachi 7K80 SATAII Raid 0 on SATA3 to SATA6 ports
    • Pioneer DVD Burner
    • 600W OCZ EvoStream
    • @400mhz 4-4-4-12 5-22-6-8-42 at 2.15v vdimm
    • @480mhz 4-4-4-12 5-22-6-8-42 at 2.20v vdimm
    • @500MHZ 4-4-4-12 5-22-6-8-42 at 2.25v vdimm
    Settings used:
    AI Tuning: Manual
    Nvidia GPU Ex: Disabled
    LinkBoost: Disabled
    FSB - Memory Clock Mode: Unlinked
    x FSB - Memory Raio: N/A
    FSB (QDR), Mhz: 1067 (means 266FSB)
    Actual FSB (QDR), Mhz: 1600
    MEM (DDR), Mhz: 800 and 960 (means 400mhz and 480mhzmhz speeds)
    Actual MEM (DDR), Mhz: 800 and 960
    Vcore Voltage: 1.325 set (1.24v bios - 0505 and higher bios fix the vcore issue but 0402 bios more stable for both my E6600/Q6600 cpus. Have not tried 1002 bios yet)
    Memory Voltage: 2.15v and 2.20v respectively
    1.2v HT Voltage: 1.30v
    NB Core Voltage: 1.55v
    SB Core Voltage: 1.50v
    CPU VTT Voltage: 1.3v
    DDRII Controller Ref Voltage: AUTO
    DDRII Channel A Ref Voltage: AUTO
    DDRII Channel B Ref Voltage: AUTO
    tCL (CAS Latency): 4
    tRCD: 4
    tRP: 4
    tRAS: 12
    Command Per Clock (CMD): 2 clock (2T)
    Advance Memory Settings
    tRRD: 5
    tRC: 22
    tWR: 6
    tWTR: 8
    tREF: AUTO
    tRD: 7
    tRFC: 42
    Async Latency: AUTO
    CPU Spread Spectrum: Disabled
    MCP PCIE Spread Spectrum: Disabled
    SATA Spread Spectrum: Disabled
    LDT Spread Spectrum: Disabled
    CPU Internal Thermal Control: Disabled
    Limit CPUID MaxVal: Disabled
    Enhanced C1 (C1E): Disabled
    Execute Disable Bit: Disabled
    Virtualization Technology: Disabled
    Enhanced Intel Speedstep Tech: Disabled
    LDT Frequency: 5x
    PCIEX16_1 Frequency (Mhz): 100
    PCIEX16_2 Frequency (Mhz): 100
    PCIEX16_3 Frequency (Mhz): 100
    SPP<->MCP Ref Clock, Mhz: 200
    Using Orthos Blend for short duration tests due to time constraints.
    @500mhz 4-4-4-12 5-22-6-8-42 at 2.25v vdimm
    Started testing by dropping multiplier from 11x to 9x and upping FSB to 400FSB and 4x1GB G.Skill 6400PHU2 2GB HZ Micron D9GMH 629 batch @500mhz 4-4-4-12 at 2.25v vdimm bios set.
    Dual Super Pi 32M
    Looks fine to me so far
    May 2005
    very good! spi 1m should get an advantage of running 4x1gig, more bank interleaving to be done then with 2x1gig.
    very impressive though, ddr2-1000 4-4-4 wont be seen in the realm of 2x2gigs for a LONG time. very good work
    i no longer use a laptop.
    Do You Owe Me Heatware??
    Champion
    May 2006
    Bangkok, Thailand
    Nice result !... i think it to be worth than 4GBMQ
    Sorry For My English
    OverclockZone Team
    THAILAND
    May 2006
    Philippines ^_^
    very nice result.. thanks eva2000 for sharing
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Thanks guys glad you like
    May 2006
    Canada
    are u running 32bit or 64bit windows?
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Memory Addict
    Aug 2002
    Brisbane, Australia
    32bit windows... yeah I know not all memory is addressed. But I am just trying to confirm what some users reported on 680i boards that regardless of 32bit/64bit windows they could not orthos blend stable 4x1GB even at stock speeds.
