技嘉 GA-N680SLI DQ6 Retail
CPUZ
BIOS:F2
525外頻,1:1 DDR2-1050
CPUZ
BIOS:F2
525外頻,1:1 DDR2-1050
WOW!
This board is looking&clocking great!![]()
Intel Core 2 Duo E6400 2.16GHz 2Mb + Zalman CNPS9500AT
Gigabyte GA-965P-DQ6
G.Skill DDRII 800MHZ 2GBPK Dual Channel CL 4-4-4-12
CONNECT3D Radeon® X1900 XT 512MB + Zalman VF900Cu
WD 160GB SATA II 8MB 7.2KRPM (WD1600JS) *2 in raid 0
LG GSA-H10N DVDRW BLACK
Leadtek WinFast TV2000 XP
Enermax Liberty 400W Active PFC
Gigabyte Triton Black
The heatpipe setup looks amazing! I love the back plates!
How stable is the 525 fsb?
Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
Holy cow! I almost jumped on the p5n32-e Plus, I might have to hold out for this board. Wondering how effective that monstrous heatpipe solution will be, I can imagine that 680i chipset just cranking up the heat on the pwm area. Great results though, how about memory OCing, amazing like other 680is?
i dont think u can put an aftermarket cooler (cpu) with a plate underneath the board like the tuniq
[/SIZE][/COLOR]
Originally Posted by Evanesco
500FSB prime Air
Ajfina>
yes, i can, but not 100% compatible
looks impressive,thanks for sharing
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar Tpower X58A - 920~Gulf - G.SKILL2000CL8 - GTX580 - Intel 520 120GB - Antec HCP 1200w
Biostar TP67XE/TZ77XE4 2500k~3770K - G.SKILL 2800 - GTX480 - OCZ Vertex2 50GB - Corsair AX1200
Biostar Tpower X79 i7 3820 ~ E5 2680 - G.SKILL 2400C11 - GTX560Ti - Intel 520 120GB - AX1200i
Kids
P4GD1 - Pentium M 780 - XMS Xpert400 - GTX460 - Raptor 36GB - Aopen 560w
yeah, i doubt that. Seems my Tuniq is not compatible with this boardOriginally Posted by Ajfina
@ MECURY : nice board and impress ocing u have![]()
I agree! That looks simply awesome!Originally Posted by afireinside
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
Originally Posted by xs64
I suspect that backplate heatpipe does little to nothing and it likely doesn't work at all when the board is mounted vertically (althought that's assuming there is actually any fluid in the system to begin with... It may be so poor that it's dry inside and strictly for show). I would remove it in favor of properly mounting an aftermarket backplate.
no problem with any voltage u set in bios, doesn't have the buggy like p5n32-e sliOriginally Posted by Kunaak
What about quad-core clocking?
carppy 2T time
8x500 1:1 (Boot 500 in bios)
525 is not that stable yet.Originally Posted by afireinside
Originally Posted by MECUCRY
That is not completely true, especially with the F2 BIOS.Your board appears to be just like the one Gigabyte delivered to HiCookie.
yup,they send to xfastest to do the reveiw,but retail resion no doubtsOriginally Posted by bingo13
Why is this the perfect board. LOLOriginally Posted by bingo13
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Intel i7 3770k
░░░░░░▄▄▄▄▀▀▀▀▀▀▀▀▄▄▄▄▄▄░░░░░░░░░ ASUS GTX680
░░░░░░█░░░░▒▒▒▒▒▒▒▒▒▒▒▒░░▀▀▄░░░░░ ASUS Maximun V Gene
░░░░░█░░░▒▒▒▒▒▒░░░░░░░░▒▒▒░░█░░░░ Mushkin 8GB Blackline
░░░░█░░░░░░▄██▀▄▄░░░░░▄▄▄░░░█░░░░ Crucial M4 256GB
░░░▀▒▄▄▄▒░█▀▀▀▀▄▄█░░░██▄▄█░░░█░░░ Hitachi Deskstar 2TB x2
░░█▒█▒▄░▀▄▄▄▀░░░░░░░░█░░░▒▒▒▒▒█░░ FSP 750W Gold
░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Fractal Arc Mini
Actually, not that good in bios, still F2,Originally Posted by Knight
vMch max is +0.2v
no vtt setup
Sb has problem voltgae max is +0.35v
Or was this "review" done at Gigabyte?Originally Posted by MECUCRY
done at gigabyte? duno what u said?Originally Posted by bingo13
im not working in gigabyte, and ths mobo and testing in my home![]()
Good, then drop a retail CPU in it and show the results that people can expect when this board goes on sale in two weeks. It is easy to get the high FSBs with the 1333 CPUs in it, I know this for a fact. While ES results are nice, it is only fair to post retail CPU results for a clear picture on the board's capabilities.Originally Posted by MECUCRY
Something like this - http://img114.imageshack.us/img114/7...09x440agp4.png
How high can you take a Quad Core on the F2 BIOS?![]()
No, just the perfect CPU to use in it for those screen shots.Originally Posted by Knight
