Intel last week demonstrated a working processor with 80 individual processing cores. Each core, or "tile" as Intel calls them, consists of a compute element and a router that allows each tile to connect to its neighbor. The chip can deliver more than 1 trillion floating point operations per second (teraflops), depending on how fast it's running. This is only a research project right now, as there are a lot of challenges involved in making an 80-core chip that's a practical option for PCs and servers.
Intel demonstrated the teraflop research chip in a briefing for reporters last week at a San Francisco hotel. It built a special cooling system for the chip and ran a few applications to demonstrate its performance. Intel had the chip running at around 3GHz during the demonstration, but has gotten it to run faster in its Oregon labs with a water-cooled system, said CTO Justin Rattner.
This is how Intel demonstrated the chip for reporters. Several power supplies were required, and Intel also needed to build a special motherboard. Engineers showed how Intel can obtain different levels of performance by tweaking the chips' clock speed and voltage supply while running an application that solved complex mathematical equations.
