Results 1 to 16 of 16
Thread: DFI ICFX3200 T2R/G FSB Scaling & Voltage Settings
Threaded View
    Nov 2005
    Mansfield TX
    I've done some extensive testing with the RD600 and have compiled the data into a quick chart to help others in setting up quick overclocks on their board. Memory was left async, DDR2-800, 2T for most of the tests. All testing done on open test bed (HSPC Top Deck Tech Station). North bridge cooled by Microcool NorthPole XE Whisper Chipset Cooler, cpu cooled by Tuniq Tower with stock fan. Your results may vary, but these were the exact settings used to reach each final result.
    CPU: E6400 L628B194
    Memory: G. SKill 6400 HZ's
    Video: Evga 7900GT's
    PSU: OCZ GameXtreme 700w
    Case: HSPC Top Deck Tech Station
    **** Use these voltages & settings at you own risk****
    It has been said by other more knowledgable enthusiasts that 1.5v on the nb is the max safe 24/7 voltage.
    Bios Settings
    [HTML]
    Genie Bios
    >Performance options
    Memory Clock Frequency: DDR-400
    Control CPU Frequency: Manual
    x CPU Frequency (Mhz): 4XX
    NB FSB Strapping: Auto or 333
    PCI-E Overclock: 105
    Software Reset Clockgen: Enabled
    Memory Overclocking: Disabled
    Overclock Frequency(MHz):
    >NorthBridge ASIC CFG
    >NorthBridge Selections
    Memory Channels: Auto
    Memory Power Mangement: Disabled
    IGD Clock Gate: Disable
    NB Channel Mapping: Auto
    Simple Addr Translationisable
    Chip-Select Swap: Disable
    Burst Length: 8
    Bank0 Map GFX: 4
    Bank1 Map GFX: 5
    Bank2 Map GFX: 6
    Channel Mapping NB: 5
    Channel Mapping GFX: 1
    Bank0 Map NB: 5
    Bank1 Map NB: 11
    Bank2 Map NB: 7
    >Memory Timing Menu
    CS Output Timing: Delay 1/4 clock
    CK Output Timing: AUTO
    Dual channel Split Mode: AUTO
    ADDR/CMD Driving Pre-AMP: Disabled
    ADDR/CMD Driving Strength: 05
    Clocking Driving Pre-AMP: Always
    Clocking Driving Strength: 05
    Address/Command Timing: Auto
    Memory Timing Select: Manual
    CAS Timing (TCAS): 4
    Read RAS-CAS Delay (TRCDR): 4
    Write RAS-CAS Delay (TRCDW): 4
    RAS Precharge Time (TRP): 4
    Cycle Time (TRAS): 12
    Row Cycle Time (TRC): 22
    Refresh to Active (TRFC): 42
    Bank to Bank CMD (TRRD): 3
    Write Recovery (TWR): 6
    Read-Write Command (TRTW): 3
    Write-Write CS (TWTW_CS): 2
    Write-Read Command (TWTR): 3
    Write-Read CS (TWTR_CS): 2
    Read-Read CS (TRTR_CS): 2
    Read Data Transfers: 5
    Memory Auto-Calibration
    Read Data Transfer: Enable
    Read Strobe Delay: Disable
    Read Strobe Arrival: Enable
    >FSB IO Strength
    FSB IO Driving COntrol: Default
    x 1X NMOS Strength
    x 1X PMOS Strength
    x 2X NMOS Strength
    x 2X PMOS Strength
    x 4X NMOS Strength
    x 4X PMOS Strength
    CPU Vid Control: 1.**v
    CPU VID Special ADD: Auto
    DDR2 Ram 1.8 Voltage: 2.25v
    CPU VTT 1.2V Voltage: 1.**v
    NB Core 1.2V Voltage: 1.**v
    NB PLL 1.8V Voltage: *.**v
    NB PLL 1.2V Voltage: 1.**v
    NB PCI-E 1.2V Voltage: 1.**v
    NB Core 1.2V convert from: *.**v
    SB Core 1.2V Voltage: 1.**v
    Clockgen Voltage: *.**v
    GTL REF Voltage control: Enabled
    CPU Core 1/2 GTL REF Volt: 48
    CPU Core 3/4 GTL REF Volt: 48
    North Bridge GTL REF Volt: 128
    CPU PLL Setting Overide: Enabled
    PLL Override loop count: AUTO
    Conroe P-State Multiplier: x8
    C1E Function: Disabled
    [/HTML]
    445FSB 4 hrs orthos ---465FSB 4 hrs Orthos----470FSB 4hrs orthos----480FSB 2 hrs orthos---478FSB 12hr Orthos---488FSB 2 hrs Orthos
    Praetor
    » Intel i7 2600K 3103B306 » Asus Maximus IV Extreme-Z » Asus GTX 470's TRi-SLI » Corsair Dominator GT CMT4GX3M2A2000C8 » Corsair Force F180 SSD » Corsair AX1200 PSU » Corsair 800D
    » Cooling : Swiftec Apogee XT » Swiftec MCP350-DDC1 w/XSPC Dual DDC Bay Reservoir » Swiftech MCR320-QP w/Scythe SlipStreams 110CFM
    The Yamato
    » Intel i7 920 3849B028 or i7 980X » Asus Rampage III Extreme Black Edition » Asus HD6970's QuadFireX or Asus GTX 570's 4way SLI » 6GB Corsair Dominator GT TR3X6G1866C7GTF » Corsair Force F180 SSD » Corsair AX1200 PSU » Microcool Banchetto 101
    » Cooling : Dragon F1 Extreme Edition(LN2) » Custom SS by RunMc »
