Results 1 to 19 of 19
Thread: is there a way to check what IC my sticks have without taking off heat spreaders?
    Feb 2007
    wondering if its possible to check what IC your sticks have without taking off the heatspreaders?
    if not, can you please give a tutorial or link on how to remove heat spreaders? because i have never done it before and i want to be very careful. i also know they have thermal tape or something and i just want to make sure that everything goes back perfectly the way it should after i check my the IC
    thanks!
    Apr 2005
    Calgary, AB
    Yep, google.
    I dont recommend removing spreaders from DDR2, those lil chips pop off very easily.
    MB Reviewer for HWC
    Team OCX Bench Team
    Apr 2006
    Cairo
    The easiest thing is to ask first , we dont know then you can test it to know if it is Micron or not
    Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
    Asus X58 P6T
    6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
    XFX HD5870
    WD 1TB Black HD
    Corsair 850TX
    Cooler Master HAF 922
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    You can tell if the chips are made by Micron from the horizontal side of the IC.
    Love and Peace!
    Dec 2004
    hiding somewhere!
    or you can see how well it clocks, because in the end, THAT is what matters...
    Got a fan over those memory sticks? No? Well get to it before you kill them
    Apr 2006
    Quote Originally Posted by The Stilt
    Can you elaborate?
    Abit IP35 Pro
    Tuniq Tower
    Q6600 G0 @ 3600mhz
    Ballistix Tracer 6400
    X1900xt 512
    Silverstone 650 Zeus
    May 2005
    Edmonton, Alberta, Canada
    Quote Originally Posted by ozzimark
    Listen to this man
    Gigabyte X58A-UD3R | i7 930 @ 4 GHz | Corsair H50
    G.Skill RipJaws 4x2 GB @ DDR3-1600 7-7-6-24-1N | HIS Radeon HD 5870
    3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
    Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    dab420,
    Micron's FBGA chips have a thicker portion in the middle of the IC between the two rows of solder balls.
    See the attached pic for reference.
    You were not supposed to see this.
    Nov 2002
    This is looking from the bottom, right? And no other IC's have this?
    Jan 2007
    My ProMOS IC looked just like the Micron except for one difference
    Say the far left side is "1", the middle is "2" and the far right side is "3"
    On the Micron "1" and "3" are identical in the fact that they are not lowered down like "2" (see above pic, the only thing "lowered" is "2", or the middle portion)
    On my ProMOS, "1" and "3" were lowered down, and "2" looked CLOSE to the Micron picture above.
    In other words, the sides of my ProMOS looked like the middle of the Micron. i.e. LOWERED, LOWERED, LOWERED
    Micron = Cut off, LOWERED, Cut off.
    I sure hope that makes sense for you guys. BTW: G.skill 6400phu2-2gbHZ
    Q6600 G0 @ 3.2GHz (400x8) @ 1.34v
    Gigabyte P35-DS3P Rev. 2.0
    4x1GB Micron D9GMH (G.Skill HZ)
    nVidia 8800GTS 512MB (G92)
    Raptor 150 SATA / Seagate 7200.10 750GB
    Samsung/LiteOn SATA DVDRW
    Corsair HX620 PSU
    Nov 2002
    So what you're saying is that with the ProMos all 3 sections, left middle and right, have that bump protruding out of the bottom, while Microns only have the middle bump protruding, correct?
    Aug 2005
    How interesting, I just got two G.Skill kits I ordered for my parents' PC and my rig.
    Both kits look like they have micron IC's judging by that pic! The ones without heatspreaders (F2-5400PHU2-2GBNT) also have the characteristic dot in the same place as micron IC's but the rest is printed with G.Skill's info and the original info is not visible at all.
    The other kit (F2-6400CL5D-2GBNQ) look identical from underneath and have red heatspreaders which I won't be removing after I killed a stick of TX D9GMH removing the HS. Even though you couldn't see any damage, I believe one of IC's must've had it's solder balls damaged.
    Nov 2002
    That settles it ... I'm not going to take off the heatspreader! Lol, I was just looking at it too, thinking "All it is, is that little clip. Me vs. that little clip, I'll definitely win, where's my tiny flathead!"
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    The HS on TeamGroup sticks is attached with a ~1mm thick layer of brown nasty-looking paste-like tape which is very easy to cut loose from the chips. Warming the sticks with a hairdryer during the surgery makes the hackjob easier.
    Xtreme Legend
    Mar 2005
    Australia
    here is a guy that makes a lot of sense
    Team.AU
    Got tube?
    GIGABYTE Australia
    Aug 2005
    Had a closer look and based on kenton's post both of my kits are PROMOS.
    2GBNQ (6400 5-5-5) and 2GBNT (5400 5-5-5)
    Jan 2007
    Yes, my Corsair XMS2-800 C4 had bumps on the sides and the middle.
    My (supposed) Micron G.Skill only has a bump in the middle like the above picture someone posted (Not Nephilim's picture)
    My ProMOS looks identical to Nep's picture
    Corsair HX620 PSU
  18. #18
    Aug 2005
    Quote Originally Posted by kenton
    So how do those Corsair sticks clock out of curiosity?
  19. #19
    Jan 2007
    Never OC'd them. They didn't run at proper voltage per Corsair. sorry
    Corsair HX620 PSU
