XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Air Cooling
Reply
Old 02-06-2007, 04:33 PM   #1
PcCI2iminal
Xtreme Family
PcCI2iminal's Avatar
Coolermaster Geminii vs Scythe Infinity vs Zalman 9700 vs Noctua NH-U12F(pics)
its the first round (the 2nd round will be finished soon),the heatsinks aren`t lapped and the room temp is 18C
The goal of this running was to see if they can handle the quad core @ 3573mhz for 10mins a 4 x prime and the Zalman failed on both config(pull/pull & 1 x 120mm) ,thats why i need to test again
enjoy
QX6700 @ 3573mhz vcore-> 1.39v (load)
CoolerMaster Geminii 120mm @ 104CFM x 2
full load 68C 66C 66C 68C
Scythe Infinity push/push config
Scythe Infinity push/pull config
full load 69C 66C 66C 69C
Scythe Infinity 1 x 120mm
full load 70C 68C 68C 70C
Zalman 9700 push/push config
failed
Zalman 9700 1 x 120mm
failed
Noctua NH-U12F push/push config
full load 71C 69C 71C 69C
Noctua NH-U12F push/pull config
full load 71C 70C 70C 71C
Noctua NH-U12F 120mm x 1
failed
CPU->QX6700 @ 3573mhz (1.39v load)
FAN->Sanyo Denki 104CFM x 2
MB->DFI RD600
DDR2->XMS2 Pro
PSU->Giga-EZ 1000w
Room Temp->18C
__________________
Mojo
Family
Biostar TP55 XE - Core i7 860(ES) @ 4.2ghz - CNPS10X Extreme - G.SKILL 1600 - Galaxy GTX275 - Velociraptor 300GB x 2 - Zippy TypeR 600w
Criminal
Biostar X58A - 920~Gulf - G.SKILL2000CL8 - GTS250 - Hitachi 40gb 7200 - Giga-EZ 1000w
Kids
P4GD1 - Pentium M 740 - XMS Xpert400 - Gladiac 7900GTX - Raptor 36GB - Aopen 560w
PcCI2iminal is offline   Reply With Quote
Old 02-06-2007, 04:46 PM   #2
deeznuts
Is that coolermaster the "fujin" that we've all been waiting for?
And are those normal temps for the QX6700? Godamn that's hot, I have a Tuniq Tower for mine I hope it's enough lol.
deeznuts is offline   Reply With Quote
Old 02-06-2007, 05:36 PM   #4
Scyth3
I kinda had a feeling that hugh Cooler master was not gonna beat Tuniq or the Infinity. You should try that new Ultra-X, that looks good.
Scyth3 is offline   Reply With Quote
Old 02-06-2007, 06:15 PM   #5
enz660
enz660's Avatar
sadly, this is close to what I was expecting... did you pressure mount the scythe infinity? If not, It would be better than cooler monster.
edit: nvm, I see the infinity is NOT pressure mounted. IMO Infinity is better.
__________________
Specs:
- e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
- P5W DH Deluxe Cooling Mod
- 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
- Nvidia 7800gt (490/575) +.1vmod (Upgrading xmas 07)
- Silverstone ST75F 750watt
- Modded Asus Vento (Black) *Heavy Case Modding In Progress*
enz660 is offline   Reply With Quote
Old 02-06-2007, 07:40 PM   #6
IKIKUINTHENUTZ
IKIKUINTHENUTZ's Avatar
Send a message via AIM to IKIKUINTHENUTZ
You should try the Ultra-X (good suggestion Scy) and maybe the butterfly thingy for the hell of it lol. Replace the Noc and Zalman for these 2.
__________________
Work and School, Work and School, oi!
IKIKUINTHENUTZ is offline   Reply With Quote
Old 02-06-2007, 07:45 PM   #7
dinos22
...you two characters
dinos22's Avatar
Originally Posted by eva2000
nice good to see infinity still up with the best
yeah agreed....good cooler
BUT you have to mod the mounting to get the right pressure
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 02-07-2007, 03:07 AM   #8
FatHippo
The Geminii is better than the Infinity imo simply because it cools the whole upper half of the mobo. Besides, its not fair to compare a modded infinity with a stock geminii, maybe a modded geminii will trump the modded infinity.
FatHippo is offline   Reply With Quote
Old 02-07-2007, 05:08 AM   #9
enz660
enz660's Avatar
if the Geminii comes with the crappy plastic mounting pins, it too can be modded in the same way as the infinity. If it doesnt...I dont know what else you can really do to it sxcept for lapping and/or adding faster fans.
__________________
Specs:
Old 02-07-2007, 08:33 AM   #10
Scyth3
I do not think the GeminiII uses plastic pegs. If it did, I would be scared to stand my case up.
Old 02-07-2007, 09:39 AM   #11
BooStFeD
BooStFeD's Avatar
Great heatsink testing from the air-cooling champ PcCI2iminal
Glad to see the Infinity on top.
__________________
Cooler Master Stacker 810 WATERCOOLED
Black Ice GTX 360 // Danger Den TDX CPU WB //
Maze 4 GPU WB // D5 Pump // SwifTech Micro Res.
ASUS P5B DELUXE // E8400 @ 4250MHz 500*8.5 1.41v
2x2GB MUSHKIN ASCENT DDR2 1066
SAPPHIRE HD4870 512Mb @ 845-1050
Corsair HX1000w // SB Audigy 4
BooStFeD is offline   Reply With Quote
Old 02-07-2007, 09:46 AM   #12
lawrywild
Xtreme Cruncher
lawrywild's Avatar
Send a message via MSN to lawrywild
Cool, however the Noctua is more designed for good temps at low rpm/silence.
try using a single 1000rpm 120mm and see which gets the best temps please
__________________
Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
lawrywild is offline   Reply With Quote
Old 02-07-2007, 10:17 AM   #13
Gam3Ra
Gam3Ra's Avatar
10x for the comparison
GeminII is not that good as all here write, but he cools CPU, motherboard chipset, VR's and Ram Memory
I have "tested" Infinity (with pressure mount) and Noctua and the NH-U12 cool the CPU by 2-3-4C better. But this with low rpm fan (I hate noise). Now my E6400 is running 3504Mhz 1.30V with ~45C load temp (~25C room).
PcCI2iminal - test the Tuniq, maybe he will bite GeminII (with 3 fans)
Gam3Ra is offline   Reply With Quote
Old 02-07-2007, 10:32 AM   #14
Eclipse3EB
Send a message via AIM to Eclipse3EB
Thanks for the report PcCI2iminal
Can you do a round of tests with Yate Loons running somewhere in between 1200 and 1600 rpm? It'd be nice to see how these guys do with 40-50cfm vs 104cfm.
Also, I can't seem to get near 71C at 1.38V (1.4775V in BIOS), 267x13 (3.47GHz) with my Zalman 9700 at full blast. On an open-air desk I get about 84C @ load with Orthos. Are you using any special mount for your Zalman?
__________________
Processor: Intel Core 2 Extreme QX6700 @3.477Ghz (267x13)
Motherboard: AB9 QuadGT | VCore = 1.4775V (1.38@Load) | Vdimm = 2.0V
Memory: OCZ PC2-6400 (2x1GB) @400MHz / 4-4-4-15
Video Card: PNY 8800 GTS @500/800MHz
Power Supply: Thermaltake Toughpower 700W
Case: Antec P160W w/ 2x Yate Loon D12SL-12 LED @ 1200rpm
CPU-Cooling: Zalman CNPS9700 LED @ 1200rpm
Temps: 45C Idle | 84C Load | 20C Ambient
Eclipse3EB is offline   Reply With Quote
Old 02-07-2007, 02:10 PM   #15
enz660
enz660's Avatar
odd, every single review ive seen tells that the noctua is beaten by both the infinity and the tuniq. When testing a modded tuniq & scythe infinity, the results were exactly the same, only when the tuniq fan was turned up all the way did it beat the scythe by 1c.
__________________
Specs:
Old 02-07-2007, 02:44 PM   #16
PcCI2iminal
Xtreme Family
thanks for all replys
i forgot to say in the first post
Artic Silver 5 for all
no special mounting clips for all
and Andy Samurai (2fans on top or 120mm x1 )failed bad on that tests
for the next i will use QX6700 @ 3.4ghz and i will keep the same bios setting
and i will run Infinity with plastic monting pins and i will mod to get the right pressure
__________________
Mojo
Family
Criminal
Kids
Old 02-07-2007, 02:52 PM   #17
quicksilverXP
Great Results. I think his tests show how much of an impact the Gemini (Fujin) can have on both PWM and NB temps. Waiting for this cooler.
quicksilverXP is offline   Reply With Quote
Old 02-07-2007, 04:20 PM   #18
mr_knowitall15
mr_knowitall15's Avatar
Nice report :thumbsup: Temps are CRAZY for that quad core though! Looks like ill be going back to water if i upgrade to a kents soon...
__________________
"Roses are FF0000, Violets are 0000FF, All my base are belong to you."
Intel Badaxe2
Core 2 Duo E6600@411x9=3.7Ghz
2x1GB Corsair Dominaor 8500C5
Evga 8800GTS-320
X-Fi Platinum
2 Seagate 320Gig 7200.10s
PCP&C 750W Silencer Quad
TT Armor Case with 25cm Fan.
mr_knowitall15 is offline   Reply With Quote
Old 02-08-2007, 04:56 AM   #19
Kasparz
Kasparz's Avatar
Send a message via Skype™ to Kasparz
Im in xtremesystems?
220cfm deltas for 24/7 is only way to go
Kasparz is offline   Reply With Quote
Old 02-08-2007, 07:47 AM   #20
PanteraGSTK
Xtreme Cruncher
PanteraGSTK's Avatar
I have my infinity in a push/pull and it works great, but from the results i can see that a push/push gets 1*c less. I wonder what a push/push/pull/pull would do? I may have to try that tonight.
__________________
gone: Asus P5N-E SLI 650i 0505 BIOS
gone: Gigabyte S3, rev C1, F7 BIOS
gone: G.Skill 512mbx2 6400hz @ 500mhz 2.35v 4-4-3-5
gone: Evga 7600GTS @ 600mhz core and 1600mhz
E6300 @ 3500mhz 1.495v
2x1gb crucial ballistix tracer 8500 @500mhz 4-4-4-12 2.2v
Evga 750i FTW
2x 8800gt 512mb
Xclio 650w psu
Scythe Infinity 2X Kingwin 80cfm 120mm fans
other irrelevant crap.
100% OC
Max OC on my crappy S3 1.8v vcore DICE cooling
Come crunch with us. Click me to find out more.
PanteraGSTK is offline   Reply With Quote
Old 02-08-2007, 11:45 AM   #21
lawrywild
Xtreme Cruncher
lawrywild's Avatar
There is such a thing as xtreme silence
__________________
Old 02-08-2007, 12:06 PM   #22
SMa
SMa's Avatar
haha
__________________
SMa is offline   Reply With Quote
Old 02-13-2007, 08:48 PM   #23
NormanABates
NormanABates's Avatar
PcCI2iminal,
cant wait for the second round...................thanks in advance
NormanABates is offline   Reply With Quote
Old 02-14-2007, 06:31 AM   #24
L'enFer
L'enFer's Avatar
Send a message via ICQ to L'enFer
PcCI2iminal, great tests! if you test it again try Scythe Infinity with two 80 mm (or others) fans both pushing and attached like this:
__________________
Sorry for my bad English
L'enFer is offline   Reply With Quote
Old 02-14-2007, 06:36 AM   #25
dinos22
dinos22's Avatar
LOL you crazy Latvian you LOL hahah
oh for those who've never experienced the loudness of these fans they are TWICE as loud as the entire rotary based single stage phase cooler.......ing loud as hell i'm telling ya'll
__________________
Team.AU
Got tube?
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
