Originally Posted by
ViperJohn
Open NotePad then copy and paste the following into a text document and then save it with
a "NV Classic CP.reg" file extention. Use the quotes when you save or Notepad will add a
.txt extension onto the file which you do not want.
Windows Registry Editor Version 5.00
; NVIDIA Windows 2000/XP Display Coolbits file
; Copyright (c) NVIDIA Corporation. All rights reserved.
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global]
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NvCplApi\Policies]
"SedonaDisable"=dword:00000001
"ContextUIPolicy"=dword:00000001
"TaskbarUIPolicy"=dword:00000001
"CplGroupUIPolicy"=dword:00000001
After saving right click the NV Classic CP.reg file you created to merge it into the registry and
bingo you have the good old Classic (and useable) CP back.
