Results 1 to 13 of 13
Thread: Micron D9HNL chips (78nm 1Gb DDR2) single side
Hybrid View
    Jan 2006
    Taiwan, Penghu
    This was my old test...Micron D9HNL chips (78nm 1Gb DDR2)
    CPU:E6400 ES B1
    Cooler:Zalman 9500
    MB:Gigabyte 965P-DS3 Ver.1.0 C2 no mod BIOS:F7
    VGA:ASUS 7900GTX
    Power supply:Zippy G1 500W
    HD:Seagate 7200.10 320G SATA2 & Seagate 7200.7 200G SATA
    New D9HNL chip
    Take a look at the specification
    New chip and smaller than D9GMH!
    Here were the brief tests! (still under F7 bios)
    DDR2 800 (2.0V 15-5-5-5, no boot under12-4-4-4)
    DDR2 900 (2.2V 15-5-5-5 Under FSB400, no option for DDR2 900 w/h DS3)
    However, after I update DS3's BIOS to F10, D9HNL flies...
    DDR2 900 15-5-5-5 only needs 1.8v
    I will take more tests these days...Really impressive!
    Apr 2006
    at 900 is it superpi 32 and orthos blend stable?
    "WW3 will be fought with nukes, WW4 will be fought with rocks!":
    Jan 2006
    Taiwan, Penghu
    Quote Originally Posted by GrimReaper
    stable at 32m
    Jan 2006
    France
    Let's send them 2.2-2.3V with fan and show us results
    Feb 2006
    Russia
    What about more voltage??? How memory behaves in mode Ultra-Low Latency? (3-2-2-4 or 3-3-3-4)
    Jan 2006
    Taiwan, Penghu
    Quote Originally Posted by jmax_oc
    Quote Originally Posted by v|aDy
    OK, later after my duty I'll take some tests...
    I am Xtreme
    Dec 2002
    wow im subscribed, that looks great.
    Jan 2006
    Taiwan, Penghu
    After several tests...sorry to say it can't not boot DDR2 1000 or more (under DS3 Ver1.0)
    Maybe it's mb's problem, these days I'll get a new mb...
    so, I'll keep trying...
    Oct 2006
    I have those memory sticks on a MSI K9N SLI-2F.
    I'm just wondering, do you think I will reach DDR900@5-5-5-15?
    Or are you a professional overclocker who just got lucky?
    Simply, are your Crucial PC5300 D9HNL unique?
    || Gigabyte P35-DQ6 || Intel Pentium E2160 || 2*1024 Crucial BallistiX PC8500 || Sapphire HD 3850 || Hitachi 500 GB || Hauppauge WinTV-NOVA-T-PCI ||Zalman ZM600-HP600W || Lian Li PC7B || Windows Server 2003 ||
    Sep 2006
    The Netherlands
    Quote Originally Posted by minibite3 View Post
    Depends on the ICs, their quality, your system, etc. A lot of factors.
    Past performance does not always guarantee future results, but in case of D9HNL (or Micron for that matter) I'd say the odds are in your favor.
    I sense a certain contradiction here.
    You only need luck once you start gambling. Luck helps, but it's best not to bet on it.
    If it's a 1GB module chances of getting D9HNL are good, as it's a 1Gbit IC used to produce 1GB modules with 8 ICs instead of 16.
    Oct 2006
    Quote Originally Posted by r00n View Post
    Let's say that I'll put my identical Crucial PC5300 D9HNL i that system. Do you think the memory is capable of running DDR900@5-5-5-15? Or is it hard to reach that far?
    Feb 2007
    Norway
    I've got the same chips, single sided, sadly my x2 3800 oc's like crap, no high ramspeeds for me, but mine goes stable at 832Mhz 5 5 5 15 2T, at 4 4 4 12 2T I can't even boot... regardless of voltage (tried up to 2,4V)
    Jun 2006
    Belgium, EU
    I'm quite sure it is
    Desktop
    Intel Wolfdale E5200 @2.9Ghz
    MSI P6N SLI Fi
    Gigabyte Radeon HD4850ZL @ 680/2000
    2GB Crucial BallistiX D9GMH 800 4-4-4-12 1T
    250GB & 400GB Western Digital SATA2
    Sound Blaster Audigy2 ZS
    Enermax Liberty 500W
    Air Cooling (Arctic Freezer 7 Pro)
    Quote Originally Posted by luihed
    I like my rams like I like my women.... naked and tight
