Results 1 to 16 of 16
Thread: Kentsfield trick for high FSB benching
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    For those of you who have a Kentsfield and want to test high FSB you can disable corew three and four to reach the highest bus speeds possible on your motherboard.
    I wanted my bandwidth back and dropped to one core and went for 500FSB and it booted, then enabled core two and the system booted into windows fine.
    This will improve scores that dont take advantage of four cores/threads with the maximum FSB being possible as well as a small increase in the top speed of the chip when running only two cores. I cannot confirm that all systems will work as described above, I am on an 680i board by EVGA that will go past 500 with ease.
    This is for benching and for those who want to try it.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Memory Addict
    Aug 2002
    Brisbane, Australia
    interesting... not much use for 3dmark06 with 2 cores disabled ?
    Jun 2002
    Las Vegas
    Nope, but the other products run fine.
    I have a bunch of scores saved up now from being unable to post, hope they get the orb fixed soon.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Champion
    Jun 2002
    lab501.ro
    FUGGER, what BIOS are you using ? P20/P21 with Qx6700 B1 remained at low bandwidth and low FSB limit with core 2 and 3 disabled, even if Windows reported only 2 active cores.
    Jun 2002
    Las Vegas
    Bios 23? 12/16/06
    I fired up for a screen shot, B3 chip.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Champion
    Jun 2002
    lab501.ro
    There was no P23 out when i had the Qx6700's
    May 2006
    Serbia-Belgrade
    One stupid question, can commando disable 2 cores from bos, if not how to do it?
    @FUGGER
    Can you answer to my pm, from couple days
    xtreme energy
    Oct 2004
    Europe, Latvia
    Disable either in bios or msconfig
    Jun 2002
    Las Vegas
    Not sure about commando. Ill look back for your PM.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Banned
    Nov 2006
    Quote Originally Posted by Spacemaster
    @FUGGER
    Yes it can
    May 2006
    Serbia-Belgrade
    Quote Originally Posted by Drag
    Yes it can
    I will play with commando and X3220 at wednesday, so thanks for info.
    Jan 2003
    Macomb Twp MI
    Wow nice info.. Funny as i remember lookin at that option going why would one want to dissable some of the cores?? lol.. This is why! Cool.. Cant wait to get a chance to check this out.. Thanks man for the info!
    I've already added a link to this at evga's forums.. Nice find!
    Running now, http://www.evga.com/forums/tm.aspx?m=693435
    Intel 3960 @ 5Ghz
    Asus Rampage IV Extreme
    QuadFire 7970
    X-Fi Sound Card
    16GB G.Skill 2133Mhz DDR3 Quad Channel Ram 9,11,10 @ 1.65v.
    3 Acer 23" 3D Ready LCDs
    2x Ultra X4 1600 WATT P/S 's
    MM Extension Ascention UFO Case W/ Top of the line Water cooling. Dream build!
    Banned
    Nov 2006
    whats the temperature difference?
    Oct 2006
    Yermo, CA
    Quote Originally Posted by kiwi
    I have two motherboards each with Its own QX6700 cpu, One is an Asus P5W DHD and the other is an Abit AW9D-MAX and I don't know of any way to disable any core of a cpu. If It exists I'd love to know where.
    Xtremely Addicted
    Dec 2004
    NL
    run>msconfig>bootini>advanced>numproc=
    Champion
    Jun 2002
    lab501.ro
    Quote Originally Posted by JokerCPoC
    From BIOS, only Intel 975XBX/2 and the 680i reference boards (eVGA, BFG etc) have the option to disable cores.
