I just got this board and have it go through some time.
It's quite a nice board and easy to get on high fsb: high ram freq.;
I just would like to share my settings for those who still not really get on the right track,
therefore, I won't post the board and introduce those rich functions.
let's just go directly to the parts you guys concern about.
here are all the tweaking settings::
1. Here I have to suggest you if you have meter, go measure every points; because you need to trust what you measure not those numbers from motherboard monitor of BIOS. From the PIC below, besides Vcore due to Vdroop that I need to set 1.5v to obtain 1.43v, the others voltages are way greater than what I set here.
here we have all the memory parameters setting; be sure that your ram can handle those settings, or you can give safe settings first. Most likely Team Group's
DDR800 3-3-3-8/DDR1000 5-4-4-12 can do that like my settings here.
the least important page of bios;
remember that you will need to disable those annoying settings here in order to overclock well.
Later I will have some super pi and 3d bench post.
OPB
