Anyone tried a E4300 on mATX yet, and what was the outcome?
Wondering the same myself. Was kinda planning on exchanging my E6400 for an E4300 and run it 9x300
That's just craptastic...
Same ..waiting to see what the Gigabyte GA-965GM-DS2 is like ?
the last bios allows at last overclocking settings!
this mb can handle up to fsb320! (i965g chipset limitation)
I have a e4300 right now and my Biostar I945G-M7 v2 is coming next week. will post results. Max fsb supported by mobo is 300 but id be happy with 9x300 on a dual core for everday use on air. Did some searching around and it supposedly has a pci / pcie lock so im optimistic to reach 300x9.
mATX Conroe's can't go past 350 FSB
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
As far as I've seen and read about OC'ing, it seems the Intel 945 chipset line has a rather "iffy" PCI/PCI-E lock, meaning it actually doesn't lock all that well.
The consequence of this is that many devices begin to suffer at very high (for that chipset line, mind you) FSB speeds, usually above 300MHz (I think it's above this value the PCI/PCI-E locks begin to fail). Try searching the forum, I remember reading something about it not so long ago...
I would, therefore, recommend G965-based mATX motherboards for serious OC'ing. Of course, the problem then is to actually FIND a G965-based mATX motherboard with decent (if any at all) OC functions...Any guesses?
[EDIT]Ok, I didn't read the thread correctly. I swear I read the Gigabyte model as 945, not 965Meaning the 945-talk, albeit valid, is somewhat not important, since we're already talking about 965-based motherboards. Sorry about that.
In any case, probably the 320MHz limit on mATX boards, provided there are voltage controls, may come from the IGC (Integrated Graphics Core), which, if memory serves me right, is based on "only" 90nm tech on 965 chipsets (and 130nm in 945).[/EDIT]
Cheers.
Miguel
945g outperforms 965g when it comes to overclock c2d!
965g hits a wall around 320
945g can handle fsb up to 350!
However, the new e4300 cannot be recommended today with matx 945g/965g
because it is simply impossible to raise the fsb (Nb strap issue with c2d fsb800)!
tested on P5LD2 VM (945g) & P5B VM (965g)
The c2d fsb1066 is not concerned...
the only matx which works for the moment with the 4300: asrock 775i65g
E4300 works fine with ASUS P5L-MX (945G) at FSB 1300MT/s = FSB 325MHz = CPU 2.93GHz.
E4300 Overclocks? at AnandTech Forums
Originally Posted by Soulkeeper
Very strange!
although the 6600 works fine on p5ld2 VM DH @3150 (fsb 350)
the e4300 on this same mb does not allow any raise of the fsb over 200!
on an other forum: the p5l mx seems not to be overclocker's friendly
http://forumz.tomshardware.com/hardw...ict219450.html
It's not mATX but Gigabyte G965-DS3 is almost as good as the P965-DS3:
http://www.newegg.com/Product/CustRa...gesize=&Page=3Pros: Nice features, high overclockability.
Cons: First board was dead, no post on boot. Heard many issues of ram voltage too low for high-end memory, but Corsair CM2X1024-6400PRO worked like a charm (once I got a good board).
Other Thoughts: Right now I'm running a E6300 (1.86Ghz) at 3.22Ghz on stock cooling. By far the best overclocking I have ever personally done.
Biostar P4M890-M7 does 336MHz (for a Via chipset...)
http://www.pcstats.com/articleview.c...id=2055&page=4
e4300 is not the perfect match with 945g (P5LD2 VM DH or VM SE)!
This C2D fsb800 is locked @200 and any attempt to set fsb over 200: 201-265
results in overclocking failed!![]()
There is no way to change this! (maybe the BSEL mod)
This phenomenon does not concern hopelessly the c2d fsb1066....
The same behavior is reproduced on the P5B VM (965g)!
Be warned....
On the contrary: the e4300 + asrock 775i65g is the perfect match on matx :
http://img170.imageshack.us/my.php?i...8351415vd7.jpg
My beta test with the P5LD2 VM SE (PLL =IDT CV122C) is now completed, and the soft made by ABO-san is now fully fonctionnal!
The new revision is now available for download!
Very gratefull for this outstanding job, ABO!![]()
I think that guy might have posted his comment in the wrong board. No way in hell he's up that high with g965. Just not possible.Originally Posted by doompc
pvhk, looks nice!! What's the highest it'd boot from bios settings? It's a miracle you don't lose sound, nic, or sata up that high.
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
sorry for the late answer!
fsb@340 & PCI@115: no sata issue. PCI locked@33.3
The BSEL mod works on Foxconn G9657MA-8EKRS2H + e4300!
A guy managed to bump the fsb over 266:
Impressive, pvhk. That may just be the fastest m-ATX board available for socket 775 ever made... And one of the coolest-looking ones too (and that coming from someone who isn't that fond of red...).
I'm drooling already. I've got to know, how long till they hit the shelves. And, mor important, how much will one of these babies set me back? I'm saving up already... hehe
Cheers.
Miguel
Originally Posted by bob511
http://www.xtremesystems.org/forums/...58&postcount=8
Check that post
Asrock Z68 Extreme4 Gen3
•i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
•G.Skill F3-12800CL9D-8GB
•ASUS 7850 @ 1250//5800
•Corsair TX650 V2
•Dell 3007WFP
•Win 7 64 Ult
Since it's not clear from that quote (from the BSEL mod thread) that the GA-965GM-S2 fails to POST with the modded E4300; it boots fine with the unmodded variety, but just doesn't OC enough to really be worth talking about.
I wrote Gigabyte to see if they'd consider adding support for/removing the whatever checks on the BSEL outputs they have in their BIOS at present, and they said they'd forward the request to the BIOS devel team, but I'm not holding my breath.
@pvhk
Does that board have LEDs on it?
Can you post some pictures of it running please.
that abit really looks nice.
ironicly AMD has the best chipset for mATX C2D boards
Desktop
Intel Wolfdale E5200 @2.9Ghz
MSI P6N SLI Fi
Gigabyte Radeon HD4850ZL @ 680/2000
2GB Crucial BallistiX D9GMH 800 4-4-4-12 1T
250GB & 400GB Western Digital SATA2
Sound Blaster Audigy2 ZS
Enermax Liberty 500W
Air Cooling (Arctic Freezer 7 Pro)
Originally Posted by luihed
