Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: alpha's Allendale E4300
    Feb 2005
    OZtralia
    Just a very brief torture session to ascertain how well the new E4300 core clocks
    Hardware is as per my sig
    It looks like 3.60GHz will be beyond WC unless a TEC is used though my WC rig has a NB plus GPU in the loop (plus it needs a good clean :o ) with ambient @ 34C today
    3.30 to 3.40Ghz should be OK for most decent high performance WC though I would not recommend running @ over 3.30GHz due to the extra .05Vcore needed for only another 100MHz
    I am reasonably sure that CoreTemp is NOT reading temps correctly as they do not correspond with Speedfan that I have adjusted to match coretemp when using my e6600 (using +4C offset) and I am positive that the CPU rebooted when running @ 3.60GHz due to exceeding its operating temp
    Heres the first run @ 3.60GHz, very unstable but managed to do an 1M SuperPi run
    Vcore of 1.60V was needed (set in bios, reading 1.560V with 1.57V @ idle reported by speedfan) to boot into windoz though it could boot into bios @ 3.60GHz using only 1.50Vcore
    3.60GHz
    This is @ 3.40GHz, still not stable though with good cooling it could possibly be OK, I set 1.550Vcore in bios that read as 1.512 in bios and 1.52V idle in windoz
    3.40GHz
    Heres 3.30GHz using 1.50Vcore set in bios that reads as 1.456V in bios and 1.47V idle in windoz
    This seems to be under the critical cutoff temp and seemed stable with my very limited testing
    3.30GHz
    lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2&3 etc etc all powered by Corsair PSU's
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    how high can u go with stock volt ?
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
    Banned
    Jun 2006
    Durham, NC
    Why do these Allendales seem to be crappy overclockers?
    Apr 2006
    San Gabriel, CA
    Quote Originally Posted by SaFrOuT
    +1
    i5 2500k @ 4.6GHz - Corsair A70 | Biostar TP67B+ | G.Skill RipJaws DDR3-1600 2x2GB | MSI HD7950 TF3 | X-Fi Titanium | WD 750GB Black | CM 690 II - Corsair TX850 | 2xDell 2407WFP A04/A03 | Win 7 Pro x64
    http://www.heatware.com/eval.php?id=48222
    Xtreme X.I.P.
    Jun 2002
    Tel Aviv, Israel
    Run Intel TAT program and compare between the two programs.
    I'm not even sure that Speedfan has Core Temp detection for Conroes
    Member of Overclockers.com Folding @ Home team
    "<The_Coolest> you can't unwaste wasted CPU cycles" - Start FOLDing now!
    Main rig:
    AMD Ryzen 7 2700X / Mobo: Asrock Fatal1ty X470 / EVO 970 500GB + WD Blue 250GB + HDD / GPU: Dell RX 570 4GB / Mem: 2x16GB DDR4-3200 G.Skill 32GTZKW TridentZ - 32GB total / PSU: Seasonic Prime Ultra Gold 650W
    Secondary rigs:
    Core i7 2600K 3.4GHz @ 4.3GHz (Scythe Mugen2) / Mobo: Biostar TP67XE / 2x Inland Pro 120GB / GPU: HD5450 / Mem: 4x4GB DDR3-1600 G.Skill 8GBXL RipJawsX - 16GB total / PSU: Seasonic S12II 620W.
    Core i3 540 3.06GHz @ 4.0GHz (Freezer 7 Pro) / Mobo: MSI H55M-ED55 / GPU: Integrated / Mem: 4x2GB DDR3-1600 G.Skill 4GBRL RipJaws - 8GB total / PSU: Antec 380W.
    Core Temp - Accurate temperature monitor for Intel's Core/Core 2 and AMD64 processors
    Dec 2002
    Quote Originally Posted by Omastar
    1.6ghz crappy?
    Its low budget chips which exceed anything overklocked.
    For a new budgetrig those will be truly nice to have.
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
    Sep 2006
    SoCal
    there is a reason these are the cheapest, slowest clocked C2Ds - ever heard of binning?
    these things will not be the second coming, they will be a nice chip for a mild overclock on grandma's rig and extreme clockers who use them as disposable chips...
    haven't seen any evidence anywhere that they do much over 3.4+/- without way more voltage than their 6xxx bretheren.
    • E8500 @ 4.25 -1.41v/P5K-E vdroop mod
      2x2gb OCZ Plat 1000@1000
      7800GT/WD640AAKS
      RocketRAID 2322/4 x WD7500KS RAID5
      Sunbeam Core-Contact
    May 2003
    Hopatcong, NJ
    I see you posted in my thread about TAT / CoreTemp, but I really do believe TAT is way off this time. As Eva said, the tool was never intended to be used by the public and it was for mobile chips. And please explain to me this screenshot if TAT is correct....
    http://www.fileden.com/files/2006/6/20/80195/temp3.JPG
    TAT is obviously NOT correct because I am not getting any throttling even when TAT reads over 95C, whereas CoreTemp is below the 85C threshhold. The reason why your system shut down at 3.6GHz was not because of your temperatures, but because the chip wants more voltage. I can cause the same rebooting on my chip if I give it too little volts on any speed.
    My e4300 seems to be a litltle better, but yes, I have noticed a similar trend in needing higher voltages. To get 3.4GHz stable, I need 1.4875v in BIOS, which comes out to about 1.45v real. I am currently running Orthos(5 hours and going) at 3.5GHz with 1.49v real. Coming from a Yonah system, I'm pretty happy with my results
    You also have to remember that this is the very first week/batch of the E4300, which is the lowest binned chip. Everyone seems to expect 'B' chip like overclocks, which isn't too reasonable imo. Who knows, maybe in a few weeks a magic week/batch will pop up, just like the "B" chips did.
    'Gaming' AMD FX-6300 @ 4.5GHz | Asus M5A97 | 16GB DDR3 2133MHz | GTX760 2GB + Antec Kuhler620 mod | Crucial m4 64GB + WD Blue 2x1TB Str
    'HTPC' AMD A8-3820 @ 3.5GHz | Biostar TA75A+ | 4GB DDR3 | Momentus XT 500GB | Radeon 7950 3GB
    'Twitch' AMD 720BE @ 3.5GHz | Gigabyte GA-78LMT-S2P | 4GB DDR3 | Avermedia Game Broadcaster
    Desktop Audio: Optical Out > Matrix mini DAC > Virtue Audio ONE.2 > Tannoy Reveal Monitors + Energy Encore 8 Sub
    HTPC: Optoma HD131XE Projector + Yamaha RX-V463 + 3.2 Speaker Setup
    Nov 2006
    How is exceeding the x6800 a "crappy" overclock? Honestly what do you expect for less than $200? Most CPU's can't do anything near 100% increase.
    Apr 2006
    Quote Originally Posted by falqon
    yeah... and how does the performance scale out? That still sucks for a 9x multiplier CPU. I'd expect around 3.4ghz, and I can get it from an E6300, plus, you get better performance than an E4300 at the same clocks. Plus, an E4300 may clock 200 or 400 mhz more, but that E6300 will still match the performance.
    -----------------Main Setup-----------------
    Processor: Intel C2D E4600ES @ 3.4 Ghz
    Motherboard: Abit AW9D-Max
    Heatsink: Cooler Master GeminII HSF
    Graphics Card: eVGA 6800GS 515//1320 (hacked SLI)
    RAM: 2x 1Gb GeIL Ultra UDCA= DDR2 800Mhz cas 4
    RAM: 2x 1Gb Crucial Tenth Anniversary DDR2 667Mhz cas 3
    Hard Drive (Primary): 1 x 200Gb Seagate EIDE
    Hard Drive (Secondary): 1 x Seagate 160GB SATA
    Hard Drive (Secondary): 1 x Seagate 300Gb SATAII
    DVD-RW Drive: 1 x Lite-on CD-RW/DVD-RW
    Power Supply: Antec Basiq 500W
    Aug 2006
    eu/hungary/budapest.tmp
    Quote Originally Posted by StealthyFish
    Keep in mind:
    - this is a cheaper cpu
    - probably slower bin
    - still A revision
    - with it's lower stock fsb, doesn't need so much higher-performance ram and
    mobos. Look at it: at 333 fsb, you've got 3GHz and you can still run ddrII-667
    ram and some worse-performing mobos.
    Usual suspects: i5-750 & H212+ | Biostar T5XE CFX-SLI | 4GB RAndoM | 4850 + AC S1 + 120@5V + modded stock for VRAM/VRM | Seasonic S12-600 | 7200.12 | P180 | U2311H & S2253BW | MX518
    mITX media & to-be-server machine: A330ION | Seasonic SFX | WD600BEVS boot & WD15EARS data
    Laptops: Lifebook T4215 tablet, Vaio TX3XP
    Bike: ZX6R
    Admin
    Dec 2003
    Hillsboro, OR
    Can you lower the multiplier and test for max FSB please?
    Nov 2006
    And where is this proof? Please tell me you're not extrapolating from stock speeds.
    Admin
    Dec 2003
    Hillsboro, OR
    E6300's stock speeds are only 33MHz higher, yet 3.5GHz is normal for them. They're also cheaper than the E4300's.
    Feb 2005
    OZtralia
    It looks like CoreTemp readings seem to be accurate once the high Vcore used for 3.30GHz and above is lowered to around 1.450Vcore and below for 3.20GHz ????...........interesting
    I have not benched to find the highest MHz at default Vcore (1.3250V) as yet but looking at the numbers I think 3.00GHz @ 1.3250Vcore would not be too far off the mark
    I benched @ 3.20GHz this morning and found the lowest possible Vcore to be 1.4125V set in bios with 1.3760V read in bios, windoz = 1.3840V @ idle and 1.360V under ORTHOS large FFT load with Speedfan and CoreTemp readings about the same
    The temp reported in bios for the 3.30 to 3.60GHz runs was between 50C and 56C , now @ 3.20GHz with the Vcore lowered the reading is ~ 36C
    3.20GHz
    I forgot to give the chip details earlier so here they are:
    E4300SL9TB
    Q640A***
    Pack Date 21/12/06
    Arrr BUGGER, I just noticed I used the wrong screenshot, I actually tortured it for around 12min
    May 2003
    Edmonton Alberta
    Quote Originally Posted by Gautam
    i found teh 4300s just slightly cheaper up here, hard decision to make. The best thing abotu athe 4300s over the 6300s is that you can use almost any kind of budget pc6400 ram and not have to worry about it being the bottle neck at all. Could save you a few bucks there
    Banned
    Jun 2006
    Durham, NC
    Firstly, X6800s have 4MB cache, so to truly 'exceed' it, you'd have to clock an E4300 to about 3.3/3.4GHz or so, and the chip reviewed here apparently was nowhere near stable at 3.6GHz, so I'm assuming 3.3GHz would be about its max stable with reasonable voltage, maybe less. Secondly, countless people have achieved 100% overclocks on E6300s, on air no less. I was just expecting more seeing as so many people claimed E4300s would all be massive overclockers for a great price, and they're obviously binned under E6xxx parts; the only plus is the 9x multi for boards that AREN'T P5B-Deluxe. It's a good budget chip, but as usual it was overhyped by the typical herd of internet reviewers.
  18. #18
    Nov 2006
    They're going to be sold for $118 in a couple months, what did you honestly expect? "great price" is a relative term. As for the binned under 6xxx, well that's just completely wrong, you don't even understand this things core. As for the 9x multi, it has a lot more to do with not buying $250 RAM than the $150 mobo.
  19. #19
    Admin
    Dec 2003
    Hillsboro, OR
    They're going to clock amazingly.
    They're going to be cheap.
    Do we see a pattern here?
    There's no such thing as a free lunch, and if something looks too good to be true, it usually is.
  20. #20
    Nov 2006
    Nobody said they're "going" to clock amazingly? And yes they're "going" to be cheap in the 2nd quarter of 07, how do you not understand that simple concept?
    No, I see absolutely no pattern, just a strange post with no point.
  21. #21
    Feb 2005
    OZtralia
    OK once we/you can get over all the usual hype* (*see bull s h i t e) and take a look at the market segment and usage this chip is intended for it really does not have or should I say will not have any competition once the price settles
    For a budget gamer (or a gamer on a budget ) this chip is what they have been waiting for
    Cheap CPU, a mid to low end board that only needs to get to 350FSB, and nearly every board on the market can do that (except some of the really cheeeeep boards ) coupled with the cheapest DDR2 PC5200 should leave enough left in the kitty to buy an 8800 vga card for a machine that will be the equal in games to rigs costing double to three times as much
    Just because these chips wont run stably at ~ 100 to 120% overclocks (well this batch anyway, who knows what the future will bring) and are not priced competitively as yet does nothing to take away the significance of this launch
  22. #22
    Jul 2006
    This chip at the moment seems a better deal than a E6300, but once the e6300 gets a true 4 MB cache and becomes the "e6320" I'm sure I would say the decision isn't easy anymore. (I'd probably take the e6320 but then again I have the RAM to run the Mhz)
    So for the time being e4300 seems like the best buy for the money (until 4mb L2 caches becomes standard on all E6XXX's )
    P.S. E4300 is supposed to be $20 cheaper than E6300. So except prices to fall.
  23. #23
    May 2005
    why is it some people here think these "Allendales" are conroe core? i dont get it the info is right in front of yall it is a L2 revision,not B2. Different cores and some seem to forget once the B2 conroe cored 63/64's filter out they will be L2 Allendale cores.
    Intel Pentium G3258 | ASRock Z97M OC Formula | Samsung 2x4GB DDR3-1600 | Galaxy GTX660 GC | Samsung PM840 Pro 128GB, PM830 250GB FDE |
    "I Love To Camp!"
    "Comensing Shock Therapy!"
    HeatWare
  24. #24
    May 2003
    Edmonton Alberta
    Quote Originally Posted by Evilsizer
    Are you saying thats a good or bad thing?
  25. #25
    May 2005
    Quote Originally Posted by Super strokey
    could be a bad thing...could be good...hard to say...since the e4300 seems to be clocking around the norm for e63/64's no not a bad thing. though this could be good when intel gets the L2 "allendales" kinks worked out and we might see better clocks. just to early to say atm... im planning on a e4300 to mess with though. esp. since in gaming the extra 2mb's of cache doesnt really help.
    "I Love To Camp!"
    HeatWare
