The German community EffizienzGurus.de wrote a Tutorial "How to mod a DDC-1T to a DDC-1PlusT" ..
The text is in German, but the pictures are good!
*UPDATE*
English version available, too!
English HowTo on EffizienzGurus.de
Have fun!![]()
*UPDATE*
Have fun!![]()
Too late :P
Afaik it only works on new revision pumps.
How do you change a plus to a normal?
turn down the volts!!! yay.Originally Posted by Graystar
Lenovo Thinkpad X220 - Core i5 2410m, 4gb
waiting on 28nm video cards...
It can be done, do the reverse...Originally Posted by Graystar
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
"Artificial intelligence is no match for natural stupidity."
Easier said than done. I tried using diodes but the solder joints melted. and you need 9 volts to start the pump, so the 7 volt mod doesn't work.Originally Posted by serialk11r
That's what I was thinking but my board doesn't have the solder bridge. It already looks like the first pic. And it's definitely a DDC-2.Originally Posted by nikhsub1
Hook it up to a sunbeam rheobus lolOriginally Posted by Graystar
u need to have the new revision with blue impeller to do this!
X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
Gigabyte 890gpa-ud3h v2.1
HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
Dell U2412m, G110, G9x, Razer Scarab
It doesn't work that way.......Originally Posted by serialk11r
Is plust just the 18w version?
E8400 8x500=4000 | ABIT IP35-E
2x2GB Tracer PC2-6400 1:1 500MHz 5-5-5-15 2.0V
Galaxy 8800GT 800/2000/1100 1.3V | 80GB X25-M G2 + 1.5TB 7200.11 | XFiXG
Fuzion | MCW60 | DDC2+Petra | Coolrad22T+BIP1
Merom 13x133=1733 1MB L2 0.950V
Jup
I think the mod is to turn a 10W into a 18W, am I right?
If this is the case, I'll be buying some 10W's soon.
Patriotism is the conviction that this country is superior
to all other countries because you were born in it.
-- George B. Shaw
You're right!![]()
while you do so, you might want to ask a few questions first, namely if the 10W's you'll be ordering are the newer revision (as shown in the guide and mentioned here), this modification presumably only applies to the newer 10W revision with the blue impeller.Originally Posted by Jochenp
Don't race him, Jake! He has upper motor parts by Lingenfelter!
What I honestly don't like about the new revision is the seemingly small inlet on the rotor. I haven't had one here so far, but judging from the pictures it seems to be a lot tighter than on the older DDC+.
Intel i7 8700k | AsRock Z370 Gaming K6 | G.Skill TridentZ PC4-3200 | Gainward GTX 1080 Phoenix GLH | Seasonic Prime Titanium 650W
Something aftermarket tops won't fix?
-- George B. Shaw
How could it? The inket on the rotor itself looks way smaller. So then you'd have a large inlet on the top, but a small inlet on the rotor.
LOL!Originally Posted by Radical_53
I'm gonna have one of the engineers at Laing send one of the new pumps to me so that I can actually measure what the differences are... AFAIK, the blue-impellered pumps haven't really hit the US market yet and they'll be phased in silently. As such, there'll be a period of time where some people may end up getting the older ones, while others get the newer ones.Originally Posted by Radical_53
Anyway, like I said, I'm gonna see what I can do... there's more to mess with than just the impeller housing.![]()
I'm doing science and I'm still alive...
Hey can't you stick a cone shaped thing in the inlet to make the water get sucked in more efficiently?Originally Posted by Petra
This is how my DDC-2 board looks. I also noticed that it's a version 6.0 board (whatever that means.) Obviously, there's a huge difference between the board layout of my board and the board in the article above.
You have the old version of the Laing.. it's just with the Laing with blue impeller possible..
@petra: That would definitely be some interesting info! I'll try to get my hands on a newer revision too. I'm really curious about the changes they made to the impeller.
There's probably not much to it. Smaller hole equals higher head but less flow. There are many pumps, such as Iwaki, that allow you to change the flow characteristics just by changing the impeller.Originally Posted by Radical_53
They might just be tweaking the performance of the pump to better match our systems. Being a pump company, I would guess that their goal is to have the pump operate near its BEP (Best Efficiency Point) while in a WC loop. That would provide the best performance and longevity for the pump. Historically, pumps in our little loops have operated way outside their intended ranges due to the large head losses of components.
My pump was manufactured in 10/06...about 3 months ago. What exactly does "old version" mean to you?Originally Posted by krueml_
I have a red impeller.
Note that the blue impeller doesn't have any holes like the orange did:
I wonder if the blue 18w impeller is identical to the 10w pictured above? Maybe it's got holes like the orange?
A few spontaneous questions:
- I wonder if they fixed the starting issues in the new reversion?
I hope so because I don't like recommending pumps with "high" failure rates like I've been doing for the past months.- Are both versions equally priced (by laing that is, not by resellers)?
If not I guess they won't be selling many 18w pumps from now on.- Why did they even release two version?
Because the 10w version is quieter?- With this new smaller impeller hole, maybe alphacools top has an advantage over Petras due to it's smaller inlet?
Maybe I'll be recommending Petra'sTech DDCT-02 blue in a couple of weeks?
