Heres a little comparison between the P5B Deluxe WiFi and Asus P5B-E Plus, seems a lot of ics are missing, if a few different places on the mobo. BIOS is basically the same with the same voltage options from bios. A lot of the capacitors on the P5B Deluxe WiFi have changed to the tin caps.
Seem that P5b-E Plus mobo either doesnt like my new Intel D 925 much or the mobo is a heap of shiiite.
Because the Intel D 925 has a multi of 15x if i boot through bios with higher that 215FSB it just rests mobo to stock settings. Same if i change settings different to that of AUTO. ALso the vdoop is insane, stock voltages = 1.15vcore in windows.
Even 1.4v is 1.25v and 1.5v bios is 1.29v in windows. I need to get a conroe into this board and see if the results are the same.
Clock gen does work and a little play I got the Intel D 925 to 3.9ghz on air with 1.5v in bios orthos stable for a quick run. Gets toasty though even with a low vcore.
Phase change her tomorrow and see how it goes ehehehe.
