Hey there,
Today I spent some time and changed my SB and NB cooling. Here are some shots...
1) very very nasty TIM under SB and NB:
http://weboperative.com/OCIDB/index....&Qis=M&Qtmp=FS
2) needed a heat gun to take off TIM on SB and alcohol, lots of:
3) Finally they are cleaner:
4) A shot of stock cooling system (after cleaning the TIM on the SB heatsink) - have no idea why they put gray band for passive ram cooling
5) using good old as5 and a spatula:
6) Scythe Kaze 40mm fan on top of SB heatsink using Loctite:
7) Using evercool VC-RE for NB cooling - was a tight fit but I think it is OK:
8) Using a saw and metal cutter scissor - not looking so good but hey it worked:
9) It's done
Hope it helps...
EDIT: i think i need to mention that (in case) after above mods no more RMA possibility exists...
