Today I was curious about what's underneath my striker's chipset in terms of TIM. So I took a peek under and below is what I found.
I decided to use a Thermalright HR-05 chipset cooler for northbridge and Thermaltake Extreme Spirit II for southbridge (yes fits fine and allows 8800GTS SLI and even for a length PCI-E based SATA raid controller in middle PCI-E slot if need to it seems).
The memory you see is Teamgroup 6400C3 D9GMH since i moved my OCZ PC8000 Titanium Alpha VX2 modules over to my DFI ICFX3200 RD600 system.
The last time to see the stock heatpipes.. bye bye and so long
What's underneath, looks like 2x TIMs there the normal grey pad and white paste too ??
Only the white paste made it's way to the northbridge and southbridge chipset cores it seems. 680i chipset is week 36, 2006 while southbridge is week 40, 2006 dated.
Thermaltake Extreme Spirit II on southbridge with clearance for 2x 8800GTS SLI
Thermalright HR-05 on northbridge with Coolermaster 70x25mm 0.12A fan
And Swiftech MC14 copper ramsinks on mosfets
Swiftech Apogee installed...
Temperatures on NB for MB temp on PC Probe2 dropped maybe 2-5C lower. Southbridge thermal probe = OPT3 dropped 6-8C.
