Dear TEAM Customers :
The new TEAM Xtreem Dark series PC2-6400 (ProMos) was developed with entry level overclockers and gamers in mind. If you are new to Overclocking or would like to cross over into the Overclocking world, The Team Xtreem Dark series is definitely your answer.
The latest Microsoft operating system Windows Vista will be available for end users next year, and it will require large capacity, lightning fast and stable memory to ensure you get the most of performance from Windows Vista.
Team Xtreem Dark series modules are well prepared and geared toward adapting this new operating system, thus Team Xtreem Dark is undergone compatibility and stability testing against Microsoft Windows Vista to ensure you get the most out of this latest operating system.
The latest PC games require large capacity, lightning fast memory to deliver the most powerful performance. The Xtreem Dark Series PC2-6400 is the ultimate memory solution for graphic-intensive PC titles and provides 800MHz clock speeds, unsurpassed reliability and performance to unleash every graphic possibility, Making sure every frame per second counts and avoid lagging that could frustrate your gaming experience. With higher data burst transfer rate, the faster reaction you get. This 240-Pin DDR2 SDRAM system memory facilitates lightning-fast data transfers, optimum resource management and smooth multi-tasking.
Using the same high quality heat spreader as Team Xtreem series, it can ensure that every heat from the chips will go through our specially design and unique heat solvent which will be transferred to our high thermal vaporizer heat spreader making sure every pieces of IC gets equal cooing effect. Team Xtreem Dark series memory can also withstand high heat caused from the extended voltage up to 2.6V when you need to adjust the voltage in order the get the performance you wanted. This memory is a great upgrade for your lethal gaming system or 3D rendering needs.
TEAM already worked closely with Tankguys.com, NCIX.com, and Tigerdirect.com to get this new series ready and available in 2007. For more information, please log on www.teamgroup.com.tw or PM me for details.
TEAM XTREEM DARK DDR2/800 4-4-4-12
TEAM XTREEM DARK DDR2/667 3-4-4-8
