Page 1 of 3 123 LastLast
Results 1 to 25 of 73
Thread: 3dmark tweaking guide
Hybrid View
    Jun 2002
    3Dmark 2001 Guide by Mackanz
    Hi all tweakers!
    I thought I could contribute with some experiences around the secrets of tweaking the system to the max for benchmarking.
    I know that memory bandwidth is a must with this benchmarking program, but with a bad tweaked system, it really doesn’t matter how many GHZ and flops you got.
    I am no guru when it comes to Microsoft program but I have tried all kinds of tweaks and combos now and I think I have found what works best for me and what I think will cover the basics for a 3dmark setup.
    I think it is better to say that I have a AMD rig and some parts of this guide does not include an Intel setup as that system uses another software. (4 in 1)
    First of all Win2K professional is a must, no other OS can provide speed and stability as Win2K.
    Whether you decide to change cluster size on the HD and partitions, I’ll leave that up to you but I always try to have 32 or 64, not standard 4 which I believe win2K installs as default.
    Oh and yes, NTFS is included in that as well.
    The best is if you have 2 hd:s as it is the best to put the swap file on the first partition on a 2:nd hd, preferably not on the same channel as the first hd.
    Install Win2K and SP2, you don’t have to install SP1 if you have the 2: nd.
    Install via 4 in 1 version 4.37 since that version is the fastest right now. Then install DirectX 8.1.
    Now proceed with the install of the important small programs such as Winzip or Winace and your internet setup.
    Wait with the graphics and the tweak programs such as Rivatuner or Tweak3D.
    Instead get a program called Drive Image 2002 and simply make an image of your now cleanly installed Win2K.
    I have done too many reinstallations in the last 9 months without finding an image program that worked successfully as Drive Image 2002 does.
    When the image is written and safely putted on another partition, proceed with the graphic drivers.
    In my and in many others cases, it’s the Detonators.
    I have noticed that mixing the 29.40´s with Via 4.37 gives me the best results by far and i have tested almost all other combos such as 4.39 and the newest detonators, but only to find that this combo is the best.
    Defrag the HD as often as you can, all systems like that.
    I find that the swap file is fastest if I set it to min 480 and max 480 with 256 of ram.
    Don’t touch anything in the detonator properties, let Rivatuner handle that.
    Uninstall all unnecessary programs in windows.
    Find a file called sysoc.inf and delete the “hide” section in the lines where programs that you want to uninstall is. Leave the commas (,,).
    Then go to install/uninstall windows programs and uninstall the stuff that you don’t need.
    Run regedit and go to: HKLM/system/currentcontrolset/control/session manager/memory management and set the disableexecutivepaging(This has caused bootproblems for some members, be aware) to =1, Largesystemcache=1(this has also caused problems for some members, be aware), IOpagelocklimit=16384 in decimal, Secondleveldatacache=256 or the same as your L2 cache size in decimal.
    Reboot and run regedit again and go to HKLM and turn off the fileprotection:
    Software/Microsoft/windowsNT/currentversion/winlogon and change the value of SFCDisable to REG_DWORD “ffffff9d”.
    Reboot windows and turn off OS2 and POSIX servers by finding and delete following files: OS2.exe, OS2SRV.exe, PSXSS.exe, OS2SS.exe and POSIX.exe.
    In system.ini , add the following line under 386enh: ConservativeSwapfileUsage=1
    Before hitting the start bench button in 3dmark, change the priority of the program to realtime in the task manager.
    This is just a few tweaks that I have found all over Internet and I have tried them all.
    There are probably a lot more to do but I shouldn’t write about things that I haven’t tried myself. I leave the Rivatuner guide up to MrIcee as I think he is far superior in that program than us other.
    Some warning stuff though: This guide is NOT for a normal daily use partition and i strongly recommend backups and such before doing this and off course..i will not be responsible for any damage, this is totally up to you. I would vever got a 3dmark such as my 13200k+ without doing all this and tweaking Rivatuner, and just to be sure, i reinstalled the image and did this all again and i got the same points.
    Happy benching!!
    Thanks to mbrock for letting me know of some problems that this guide may cause.
    It seems after some testing that the above warnings about the disableexecutivepaging and Largesystemcache problems is caused when combining theese settings with running Cacheman. At least that is what happened to me.
    Mac
    Problems with your OCZ product? Feel free to PM or email me here
    Jun 2002
    Houston
    VIA Raid Perf Patch should be installed if you use RAID or SCSI on 8233, 8233a, or 8233c. I think it's up to version 1.05 now
    XIP - can sit on his hair
    Jun 2002
    Wakefield, West Yorkshire, UK
    someone make this sticky....
    Jun 2002
    We need an admin in here.....
    Watercooled O YA BABY......
    Xtreme Legend
    Jun 2002
    Hong Kong
    Smile
    Done.
    DDTUNG
    Jun 2002
    Belgium
    Don't know if you know it (chance is that you do ), but at the D3D settings at the Dislay Properties, there this nice selectbox, allowing to choose for "best quality" to "best performance".
    Use the latter and see your nature scores rise up
    (or is this cheating?)
    Abit AN7 - XP2500+ @ XP3200+ (oc'ing still has to begin hehe) - 2x512MB OCZ PC3200EL Platinum Edition - Sapphire Atlantis 9800Pro @ XT @ default speeds - NEC ND2510A DVD/RW - LG 16x/40x DVD/CD - 2x Hitachi 400GB SATA - 2x Maxtor 200GB SATA - 1x Maxtor 120GB SATA - 1x Maxtor 40GB PATA - 2x WD Raptor 74GB (raidO) SATA - 2x Promise SATA150 TX2 - 1x Promise Fasttrack SATA150 TX4
    What's your storage?
    Jun 2002
    Glendale, CA
    i set it to best performance from teh box just being blank... didnt seem to help at all
    | Intel i7 3770K | Custom H2O | Gigabyte z77x-ud5h | 16GB Samsung | GTX680 | 240g Mushkin Deluxe |
    -METALLICA-
    Jun 2002
    It is blank because when using Rivatuner, you use much greater LOD than available through the driver.
    When using the driver at "for performance" that is around -1 or -2 in the LOD in Rivatuner.
    For 3dmark, that is way to much detail.
    In other words:
    Stay away from the driver details if you are using the Rivatuner and the LOD tweak within it.
    Mac
    Jul 2002
    Belgium
    This could help the people with Win 98 or Me OS
    First of all I want to say that the following tweaks are a composite of a lot of dedicated overclockers tweaks …bye NO means are they all my original ideas ! Over the years I have compiled a fairly large database of clockers that I respect and mix and match THEIR ideas to come up with this guide. I scour the various overclocking forums to pick up information and listen in on various ideas and try them out for myself. Some but not all of the guys whose ideas went into this guide are as follows, Macci, Gibbo, Digital Jesus, Chromozone, Mr Natural, Green Beret, the chillblast Borg and a lot more if I left you out I am sorry…but I do thank all for their input and help over the years.
    Following OS tweaks are for Windows 98se and Me and Nvidea Cards.
    First and foremost know your system, you should have a clean fresh install of your os, and all the latest drivers, Via 4 in 1, Direct X 8.1. Fresh clean install of all VGA drivers. Check out the system and make sure all is well , then Defrag.
    Run a baseline benchmark and publish it for future reference.
    Set typical role of computer to NETWORK SERVER.
    Set Virtual memory to ½ of your system memory minimum
    Set maximum to 2 times your system memory
    Install Cacheman utility, Turn on “conservative file swap usage”
    On the cache tab use the following values:
    32MB:
    Min: 6144
    Max: 6144
    64MB:
    Min: 12288
    Max: 12288
    128MB:
    Min: 25600
    Max: 25600
    256MB:
    Min: 51200
    Max: 51200
    Open up system .inf file I notepad and add the following line under the {386EnH} section,ConservativeSwapfileUsage=1
    Using notepad again, edit your config.sys file: Enter REM in front of all lines/entries.
    Now enter [b] Stacks=0,0 on a new line
    Open up Autoexec.bat file and add REM in front of every line.
    Now go to START, select RUN, and type msconfig, go to startup tab and click on, Untick all the boxes except explorer and systray.
    Right click my computer, select Trouble Shooting and disable System Restore.
    Disable power savings in windows
    Disable System Scheduler
    Disable features in display properties to enhance image quality : like “show icons using all possible colors.
    Have very few icons on desktop
    Run clean disk
    Run scan disk
    Run defrag disk
    Install RivaTuner or NVMAX…the following tweaks are for RivaTuner.
    Open up RivaTuner: Select the tab that says Graphics card click on this.
    Click on enable hardware overclocking…move up by 10 and test and apply (ex 220/460 stock go 230/470) now run a second benchmark to make sure everthing is ok, score will increase.
    In RivaTuner Under Power Users Section enable mipmaps
    In RivaTuner under DirectX, under Textures,set amount of RAM for PCI textures to 0
    Enable 8-bit palettized textures.
    Set Degree of anistrophy to “force level 0 (off use nearest point)
    Disable Vsync
    Enable Side band addressing
    Set Lod Bias Range to 15
    Then go into DirectX section and set the following values.
    Car Chase – 10.0
    Dragothic – 12.0
    Lobby – 4.0
    Nature – 3.1
    Under Display set resolution at madonion default of 1024x768x32
    Change refresh rate to 60hz
    Run scan disk
    Run Defrag
    Run another benchmark score will increase
    Shutdown , restart go into Bios and set your memory timings
    Cas2-2-2
    4 Way Bank Interweave
    1t Command rate
    Enable fast writes &
    Side Band addressing
    Note real power users KNOW their Bio’s setting better than Motherboard manufacturer's
    They follow forums for latest issues and Bio’s flashes and know their Bio’s inside out and try all types of Very aggressive memory settings for that you have to research your motherboards strengths and weakness on various overclocking forums and YOU must have high quality ram and cooling.
    The next tweak is to raise your FSB up as high as possible and remain stable it has been my experience that a higher FSB raises scores and FPS better than anything with exception of overclocking Graphics card… In other words 10 x 150fsb is faster than 11.5 x 130fsb even though they both = 1500 Mhz
    Once you find out where your fsb is maxed out and stable go back and run another benchmark. Your score will increase, now go back and overclock your card in small increments and keep running benchmarks , your scores will keep increasing …until you start getting a load of artifacts back it down and there you are. Can you go faster still? YES with better graphiccard cooling,ram cooling and of course cpu cooling …but that’s for next time :-)
    Now the disclaimer you do all the above Tweaks and tips at your own risk , No one is LIABLE but YOU…. I know other people who benchmark DON’T do things in this order and don’t defrag etc as much as I do but this method works for me…….. take care and enjoy………Bulldog
    Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
    EVGA E762 4Way SLI Classified - 980X @ 6Ghz Ln 6GB Dominator - MSI 5870 Lightning
    WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
    Oct 2002
    Easton, Pennsylvania, USA
    Trying a few of the tweaks now. I'll bench and post results after I'm back from class.
    -mark
    Asus P4S533
    Pentium 4 2.26b @ 2.63
    Samsung DDR PC2700 512MB (DDR465)
    Seagate Barracuda IV 40gig 7200RPM
    MSI GeForce 4 ti4600 (340/770)
    Creative Labs SB
    806 Minion 4000
    Antec pp412x
    3dmark 2001SE Compare: 14314
    Banned
    Oct 2002
    Just a little tip for win xp users, try turning on 3dmark, then pressing ctl-alt-del and going to the processes and finding it, right clicking it, and changing priority to REAL TIME.
    Worx for me increasing my score by 50 somethings points.
    Jun 2002
    Bulgaria, Plovdiv
    Can someone help with some LOD settings for the different tests with GF3?
    Jun 2002
    Bulgaria
    I'm not 100% sure these are for GF3 but you can try them :
    Car Chase - 10.0
    Dragothic - 12.0
    Lobby - 4.0
    Nature - 3.1
    | T-Bred 1700+ @ 2663MHz (12x221.9) (JIUHB 0310 "9") | Epox 8RDA+ (C1 NB) | 2x 256MB TwinMos PC3700 | Asus V8420 128MB 3.3ns Deluxe | Enermax EG465AX-VE(G)(FMA) PSU | TT XaserII modded case | Homemade Waterblocks, 2000l/h Champion Pump, AC Radiator 400x280x45mm, 8l res, 80W Pelt |
    3DMark 03 : 2030pts | PCMark 2002 :CPU : 8003 | Mem : 6279 | SuperPI 1M : 39 sec
    Jun 2002
    Bulgaria, Plovdiv
    Car Chase - 10.0
    Dragothic - 12.0
    Lobby - 4.0
    Nature - 3.1
    Allready tried them but the score was lower than with fixed LOD 4. But with Ti 4600 these settings worked great.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    wow dude your really hardcore...
    I tried a few of the things that I could easily understand and got an easy 400 over my average.
    the one that seemed to help me the most was 2 things, one I found in another post her about 20 minutes ago, but thats specifc to my motherboard.
    the other that was helpful was setting the priority level.
    Jul 2002
    Norway
    I have heard people talking about that running for example nature first, then drago, then car and so on, or something like that
    What is the best order to run the different tests ?
    Intel i7 3930K C2 @ 4700 mhz (100 x 47) 1.4v
    EK Supremacy/EK XTC 420+280/EK DCP4.0/PrimoChill 1/2 ID 3/4 OD
    Asus Rampage IV EXTREME
    16 GB G.Skill RipjawsZ @ 2400 CL10-12-11-1T
    Zotac GTX670
    Antec Quattro 850W
    Intel 330 180 GB + Micron C400 128 GB
    LD Cooling PC-V7 B/R
    Dec 2002
    Germany
    This guide is about 6 month old!
    Are there any new tweaks and drivecombinations which work better?
    Is W2K still the No 1 choice 4 AMD user?
  18. #18
    Jul 2002
    Norway
    Win2k is still the OS for AMD users, yes. The driver combo that seem to give the best performance now is Det 40.52+VIA 4.45(or 4.43+4.40 AGP driver).
    Zotac GTX670
    Antec Quattro 850W
  19. #19
    Aug 2002
    virginia beach
    k im a bit confused, i looked through riva tuner, but... how do you set certain settings to certain bits of 3dmark??
    im just dumfounded ;p
    msi k8n neo2 plat
    3200+ winchester (10x262)
    bfg 6800gt
    pdp pc3200 xbl
    thermalright xp-90 w/7v tornado 92mm
  20. #20
    Oct 2002
    Austin, TX, USA
    For most NVidia cards, 40.52 is best in Win2k. For the GF3 Ti200, however, 40.72 is the way to go.
  21. #21
    Mar 2003
    Kiev, Ukraine. ModLabs.net
    Ok. another 3 months passed. seems to me that it's time to update this guide. Sum questions that wasn't covered b4 and i think alotta people will find it pretty useful:
    1. WHAT ABOUT ATI's CARDS? Best drivers, best OS? What do you think 'bout Soft9800 script?
    2. Any tips for Intel users?
    3. Is 40.52 still king of the hill? How 'bout 42.xx & 43.xx?
    4. Alternative chipsets tips are welcome: nVidia, SiS (actually 655 for me is a good choice)...
    5. And the biggest question: SPECIFIC TIPS FOR 3DMARK03!!! There are just a few over Net
    All 5 questions a poorly covered in guides and tips that i've found (and i found plenty of 'em).
    Now i'm working on russian guide for 3DMark2001 best performance, that's why i digged alotta forums and tweaking guides. Hope to translate it in English for your pleasure, 'cos that's a tons of small tips i've heard from different people (maybe about 50 something different threads in forums and guide used) and they are not united in one consolidated guide. After i finish that guide i will start digging for 3DM03 info...
    [3dfx collection]: 132 cards. Proud owner of 3dfx Voodoo 5 6000 AGP 128MB rev.3700A
    Owner of www.ModLabs.net - the leading Russian PC-enthusiasts' project
    Founder of
    Team MXS - the best ex-USSR benchmarking team (~100 members)
  22. #22
    Jun 2002
    I have no problems if you guys delete this thread. Tech has grown a bit since this.
    Mac
  23. #23
    Nov 2001
    Wichita, KS
    I dont think it should be deleted, it is still helpful to some I am sure.
    Now if others think so as well, I could see it being unstuck, but not deleted.
    Alas, I will leave that to the 3DMark Mods to decide, Ill stay outta that.
  24. #24
    THE ORIGINAL OC JEDI
    Oct 2002
    Field of Battle
    Alt F13,
    I'm sure everybody would like to see a fresh compilation of 3d tips...
  25. #25
    Mar 2003
    Ok, i'll translate it in english... I go for vacation next week and there i'll work on new guide. It'll be aimed on R9x00 & FX5900 probably. Too bad that radeons are so boring in tweaking.
    Founder of
