XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Motherboard Vmods
Reply
Old 12-22-2006, 02:27 PM   #1
couppi
P5N-E vmods
All vmods can be found at VR-Zone except for the Vdroop mod.
Vdroop mod:
couppi is offline   Reply With Quote
Old 12-22-2006, 03:58 PM   #2
DDTUNG
Xtreme Legend
DDTUNG's Avatar
They would be similiar to the ones for the P5N32-E SLI. Check the thread started by OPPAINTER in this section for details.
DDTUNG
__________________
XtremeSystems - we overclock and crunch you to the ground
I left the optimized files on three 3GHz P4 HTs. Ban me.
DDTUNG is offline   Reply With Quote
Old 12-30-2006, 04:33 PM   #3
sbinh
DDTUNG
They are not the same ....
These are pix for P5N-E 650i SLI:
Close-up
sbinh is offline   Reply With Quote
Old 12-30-2006, 05:20 PM   #4
couppi
This is what I got out of the thread:
These should be right, but I haven't tried them. Also, the solder points are damn small. You'd have to find out which of the resistors each leg corresponds to to make it easier.
Old 12-30-2006, 06:17 PM   #5
SaII
SaII's Avatar
Send a message via AIM to SaII
:O nice find, so when are you going to test this mod?
__________________
uh oh, HOT DOG!!
HEAT
God needs to open source his code, it sucks we have to wait for all those scientists to reverse engineer his stuff.
SaII is offline   Reply With Quote
Old 12-30-2006, 06:34 PM   #6
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
why on earth would you need a 1k resistor ? (1000, ie; 1megaohm)
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 12-30-2006, 07:44 PM   #7
couppi
It's what celemine1gig says
Originally Posted by celemine1Gig
OK, now for the mod, I'd try a 1 MOhm (in words, one Mega Ohm = 1000 K Ohm) trimmer potentiometer connected between pin#16 and pin#17. With the trimmer set to maximum resistance you change the original value by about 6-7%, which should be OK. So, start with maximum resistance and then tune it down in order to lower the droop voltage. Hope it works.
Old 12-31-2006, 03:43 PM   #8
celemine1Gig
IT Engineer in the making
celemine1Gig's Avatar
Send a message via ICQ to celemine1Gig
1k is 1000 Ohms
1M is 1000000 Ohms
Why you need 1M:
Have a look here:
http://www.xtremesystems.org/forums/...d.php?t=126019
I recommended a 1M trimmer because the original resistance on the Asus P5N32-E was 59K.
What you do when adding the trimmer, is adding resistance in parallel to the original resistance. With the trimmer set to full resistance you want only a small influence on the original value. Now using the formula for parallel resistance you get the following with a 1M trimmer:
(59K x 1000K) / (59K+1000K) = 55,71K
55,71K / 59K = 0.944 , i.e. 94,4%
That means that with the poti in place and at full resistance you still get ~5.6% decrease in total resistance. If you take a lower value trimmer, you'll get a higher decrease, i.e. the voltage will be increased (perhaps even siginficantly) when the poti is yet to be trimmed.
But please measure resistance for this board and don't just take the values from other boards for granted. There can be quite some differences. The values named above are solely for the P5N32-E!
__________________
celemine1Gig is offline   Reply With Quote
Old 12-31-2006, 04:09 PM   #9
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Mod's it's the same as OPP question ?
Regards
Martin
sory for english but is 31 december
__________________
E8400 @ 4.5GHz // Asus Maximus Extreme // 2 x 2GB A-Data XPG 2000 // Sapphire HD 4870 // R0 Maxtor 250GB + WDR 74GB // Antec Nine Hundred // Antec TPQ 850W
DEVIL K-ce is offline   Reply With Quote
Old 01-04-2007, 10:57 AM   #10
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Bump
Hmm vcore vcore for P5N-E is the same as P5W DH/P5B Dlx or not This is the same controler
Anyone help ?
Regards
Martin
__________________
Old 01-06-2007, 09:33 AM   #11
Lestat
I am Xtreme
Lestat's Avatar
1k is 1000 Ohms
1M is 1000000 Ohms
Why you need 1M:
Have a look here:
thanks for the info guy.
and also correcting me on the megaohm not sure what i was thinking lol
i dont think i have seen anything over a 200k used.. 1mega seems pretty rediculous.
but this board needs a droop mod BADLY, and needs to be done on an easier spot.
the spot shown here is impossible. i mean you would need a soldering tip the size of the head of a needle to do it.
please tell me someone has found a better way.
__________________
Old 01-06-2007, 10:34 AM   #12
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Hmmm trace route from FB4 for this what I marked
Is this ok
edit : resistance beetwen FB4 and marked point's is 10 Ohm
__________________
Old 01-06-2007, 01:37 PM   #13
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Bumpy bump
I try and solder 50k Ohm to point marked on my previous post.
Tune down and nothing Still the same vcore no more
__________________
Old 01-06-2007, 03:23 PM   #14
celemine1Gig
Originally Posted by DEVIL K-ce
Bumpy bump
With a original resistance of ~10 Ohm, the 50K trimmer is a bit overkill. That's also most likely the reason why you didn't see any vcore increase. It takes some time until the vcore would decrease, with the 50K in place. I'd rather use a 10K trimmer for this board then. And be sure to use a appropriate ground. That could also be why your mod didn't work.
Oh and are you 100% sure that the contact that you marked with a red line is really directly connected to pin#4(FB)? The resistance between the point and the pin should read less than 1 Ohm when measured with a multimeter.
Take a multimeter, set it to continuity test mode and then look for alternative solder points. It's as easy as that. Shouldn't take longer than 5 minutes, even when taking the mainboard out of the case.
__________________
Old 01-06-2007, 03:42 PM   #15
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
In my previous post I'm writing wrong data :
Resistance beetwen this FB4 and marked point's is 0.10 Ohms not 10 Ohm ---> sory
Yes I'm sure trace route from FB4 is to this marked point.
Hmm 10K Ohm - I try this way
Thank's
Regards
Martin
__________________
Old 01-06-2007, 03:52 PM   #16
celemine1Gig
Thank's
Regards
Martin
Hold on!!! I thought the resistance between ground a pin#4 would be 10 Ohms. Sorry, I got this wrong. Don't use a 10K trimmer then. The trimmer value depends solely on the resistance between pin#4 and ground in this case.
__________________
Old 01-06-2007, 03:55 PM   #17
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Heh ok I understand
Pin 4 and ground - 10 Ohm
Ok I check this resistance i reaply.
Regards
Martin
edit :
ok i check and ... :| PIN4 and ground nothing :| PIN3 and ground - 22.2 Ohm
__________________
Old 01-06-2007, 04:24 PM   #18
celemine1Gig
edit :
What do you want to say with "nothing"? There is always a resistance between feedback and ground. Are you sure that the range was correct when measuring?
__________________
Old 01-06-2007, 04:29 PM   #19
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
DMM show me nothing when I meansure PIN4 and ground
DMM is ok, range is set ok.
I'm
__________________
Old 01-06-2007, 04:52 PM   #20
SaII
SaII's Avatar
http://www.vr-zone.com/?i=4450&s=12
try that i guess?
__________________
uh oh, HOT DOG!!
HEAT
Old 01-06-2007, 05:03 PM   #21
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Originally Posted by SaII
Man thank's
I check vr-zone some days ago and nothing Good review
__________________
Old 01-07-2007, 09:19 AM   #22
SaII
SaII's Avatar
post back your results!
__________________
uh oh, HOT DOG!!
HEAT
Old 01-07-2007, 01:13 PM   #23
sbinh
Hmmm ... quick question. How would you "pencil"? It seems soldering is not my fav. ... ....
Old 01-07-2007, 01:39 PM   #24
quent
quent's Avatar
I'm
Did you try with 220kOhm range ?
__________________
Cooling : Waterchiller, Cascade and ~100L LNČ
Hardware : Many things !
quent is offline   Reply With Quote
Old 01-08-2007, 03:29 AM   #25
DEVIL K-ce
Xtreme Cruncher
DEVIL K-ce's Avatar
Ok i test vcore mod (soldering) in night and is ok. Work good.
500MHz FSB is no problem with max vmch from bios
Thank's for Shamino.
Regards
Martin
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
