Page 1 of 3 123 LastLast
Results 1 to 25 of 64
Thread: Xtreme OC @ Abit USA
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Thumbs up Xtreme OC @ Abit USA
    After being out of contact for over a year with Abit we recently made arrangements to meet and overclock at Abits facility in Freemont California. We wanted to show the cascade and LN2 cooling as well as break 5Ghz with the Quad core processor for those attending.
    XtremeSystems member Philly_boy flew in a few hours before I left for the bay area and he was invited to attend as his timing could not have been more perfect to make the trip. I needed a co-pilot for the long haul as well as some help loading and unloading of the cascade.
    We loaded up the triple stage cascade in the back of a Ford Mustang Shelby for an awesome trip to Abit at mach speed. Will it fit?Yes! it fits like a glove and did not budge one inch event with hard breaking.
    At Abit they had a break room setup for us, there was plenty of power and arranged nicely to suite the occasion. Access to the area was great, we were able to roll the LN2 bottle inside for a day of benching.
    The first half of the day I ran on the cascade, everything ran perfect with the exception of the vcore mod not working as intended. Adjustments to the trimmer resulted in no gain. I was able to break 5Ghz and ran some benches at 4.9Ghz.
    We had a chance to test setup and test on the IN9 board that is based on the Nvidia 680i chipset and has a digital PWM. This was not board we were focused on but a nice change of pace to see something new.
    The Kinston ram arrived a bit late to give it a good workout and watch for errors. I was not able to run it at full speed as I was shooting for lowest latency. I ran the ram at 3-3-3-9 @ 800/900Mhz for the benchmarks, 2.4v was set in bios for ram voltage. The modules were ES and only had suggested voltage, there was no timing present on the sticker. The heat spreader was standard aluminum.
    After lunch I switched over to LN2 and the new K|ngp|n Dragonpot. We were all blown away by the impressive new design. Check out the pictures below, the base is sold copper and has a meaty center pin for better heat dissipation. This is by far the best pot on the market today. I was using a bottom fed dewer and copper lines to feed directly into the pots. I could adjust the valve to any temp I desired. I could run a low steady -120c, bump it up to -150c and hold it, or even go full on and hit -197c in an instant.
    Far better temp control than the cascade is capable of doing as well as temps far beyond what is capable with conventional cascade refrigeration cooling. I was very impressed with how well the pots could maintain a temp.
    Abit is listening and responding to the needs of the enthusiasts, we put a few ideas on the table of things we would like to see that would help negate the high costs involved with high end benching. Lower cost enthusiast boards may be the next step, removing the unused stuff we usually disable anyway. Get back to the basic stuff to get costs way down will also suite other markets as well. Abit knows to use high quality components and it shows in the products ability to produce some of the highest benchmarks to date for its class of machine. I don’t want to see this change, its what makes Abit a great choice.
    One thing I did learn last week was its not called U-GURU, its MicroGuru.
    Abit, Intel and Kingston sponsored the demonstration, many thanks to the sponsors for having us. I am very happy that everything went a good as it did on short notice.
    Uploading pictures in progress.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Jan 2006
    Sheffield, UK
    Sounds great FUGGER!
    Make sure to post some pictures of that LN2 dewar you mentioned, that is probably the first time i've ever heard of LN2 being controlled like that.
    -150c Club Member
    May 2005
    Northeast, USA
    Any pictures or preferably video?
    If you have a cooling question or concern feel free to contact me.
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    good to hear abit is onboard again, didn't they get you a pre release max? i thought you were already hooked up with them?
    oh i almost forgot:
    this thread needs some pics
    Jun 2002
    Las Vegas
    I had one of the first Max boards in the USA. not a pre-release.
    pictures will be up soon. no video, I wish I had one form the ride home.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Muslim Overclocker
    May 2005
    Canada
    Sounds intense. Subed and waiting for pics!
    My watercooling experience
    Water
    Scythe Gentle Typhoons 120mm 1850RPM
    Thermochill PA120.3 Radiator
    Enzotech Sapphire Rev.A CPU Block
    Laing DDC 3.2
    XSPC Dual Pump Reservoir
    Primochill Pro LRT Red 1/2"
    Bitspower fittings + water temp sensor
    Rig
    E8400 | 4GB HyperX PC8500 | Corsair HX620W | ATI HD4870 512MB
    I see what I see, and you see what you see. I can't make you see what I see, but I can tell you what I see is not what you see. Truth is, we see what we want to see, and what we want to see is what those around us see. And what we don't see is... well, conspiracies.
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    yes the u they use is for micro
    good to see abit fighiting to get back on track, nice to see you guys had some fun there
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
    Xtreme Cruncher
    Jan 2006
    Cornwall, UK
    sounds like a lot of fun Charles! and great too hear abit are ready to cater to the needs of us overclockers too .
    Xtreme Cruncher
    Sep 2006
    Canada
    sounds so freaking awesome... i wish i was experienced enough . tell us more about in9, i beg you. awaiting pictures.
    Xtreme Cruncher
    Jun 2006
    San Jose
    sounds like you had some fun..
    also how did you like the bay area traffic? lol
    For all your cooling needs: ShopPTS.com
    System:
    Rampage Formula // E8400 @ 4.0 (1.28v)
    4x 1GB Ballistix Tracer @ 600 (5-5-5-15)
    4x 74GB Raptors 16MB Raid-0 // Samsung F1 1TB
    eVGA 8800GTS 512MB @ 800/1111/2000
    Corsair HX620 // LG246WP
    Cooling:
    D-TEK FuZion // PA120.3 // 3x Yate Loon SH
    MCW60GT // EK Multi-150 // DDC-2 + Petra's Top
    Jun 2002
    Las Vegas
    horrible traffic at 5am, bumper to bumper as we drove into the bay area.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
    Muslim Overclocker
    May 2005
    Canada
    Bumper to bumper traffic at 5 am :/
    Good thing I live in a small city.
    Water
    Laing DDC 3.2
    Rig
    Banned
    Dec 2004
    Near Philly, Pa
    Here's the pics of the event:
    Xtreme Cruncher
    Sep 2006
    Canada
    how do the kingston 9600 scale with voltage? like usual 'micron' suspects? in9 5-digital vrm is true!
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    fugger how much costs rent that car
    Apr 2006
    Pleasant Hill, MO
    I love how an 8800gtx is just... there. Just in case... ya know? lmao...
    Even though we're benching a cpu.
    Ryan
    "Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
    Abit IP35 Pro
    Intel Core 2 Quad 6600 @ 3200 w/ Tuniq Tower
    2x2gb A-Data DDR2 800
    AMD/ATi HD 4870
    I am Xtreme
    Dec 2002
    too bad you couldnt get 5g, looks like the AW9 doesnt get the FSB too high on the kenty huh?
    Nice speed still though, and its cool that abit let you do this.
    Glad that they are back in the enthusiast game.
  18. #18
    May 2006
    Philippines ^_^
    nice car..
    great oc..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  19. #19
    Dec 2005
    nice oc guys
    even nicer car
    DFI LANPARTY UT nF4 Ultra-D [6/23 BIOS]
    AMD Opteron 148 [CAB2E 0546GPMW] [257x11.0 @ v1.500] & Zalman CNPS7000B-CU
    OCZ EL Platinum Rev. 2 2x512[207FSB @ 2-3-3-6 @ v2.80 1T]
    DFI Ultra-D [6/23 BIOS]
    eVGA 7800GT [470 / 1100]
    Western Digital Caviar SE 250GB Serial ATA
    Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply
  20. #20
    Banned
    Dec 2004
    Near Philly, Pa
    Quote Originally Posted by FghtinIrshNvrDi
    Ryan
    If the Kentsfield and the mobo would've cooperated. . .we were going to take a run @ the single card 3D Mark 06 WR.
  21. #21
    Dec 2005
    Saratoga, CA or UC Irvine
    aww man! I live like 30 mins away from fremont too! haha. 5G was soo close too. Nice pics guys!
  22. #22
    Xtreme Recruit
    May 2006
    Barcelona // Spain
    Thanks nice pics
    IT= The never ending Story
  23. #23
    Jul 2004
    Portugal
    That's nice
    E6550
    Asus P5K
    EVGA 7900GS 256MB
    2*1GB Team Elite 667mhz
    Seagate Barracuda 320GB/80GB
    Enermax Liberty 620W
  24. #24
    Sep 2004
    DriverHeaven has an article on the event with some more pictures featuring the guys from XS.
    Sourcing parts for a mildly over clocked abacus.
  25. #25
    Apr 2006
    nice going guys
