Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Thread: i've hit 4.1 gig with Titan Amanda tec cooler
    Sep 2006
    I've had this dream...and that is to get to 4 gig without switching to water. I've had this tec cooler a whole month and been wanting to try it bad. I saw no review with it on c2d only amd so i was interested to find out what it could do. I been waiting on a corsair 620w psu before i could try it. I knew tec put out alot heat and so wanted a quality psu before i try. To this point i had 3.7ghz with a noctua-nh-12 55c on idle so i wanted to try the tec to see if i could get much closer to 4gig. I heard good reviews but only with amd and wc users were keen to put it down due to it being a low powered tec etc. That didnt put me off i was keen to prove them wrong and get to my 4 gig. I went through a spell of desperation and been desperate at times and looked around for new products and this is when i grabbed this titan. I read all the reviews and was keen to see what its potential was. I had delays and so surprised no reports on the c2d published were not published still. I also been waiting on a rma p5b deluxe back which prevented me testing this titan a month back.
    p5b deluxe wifi
    e6400 c2d
    g.skill 2gb hz series
    corsair hx620w
    titan amanda tec cooler
    I had it installed in a kandalf case and the titan 120mm fan lined up with the exhaust 1200mm fan perfectly. A couple of 120mm fans blowing in the front and a corsair 620w psu.
    I also lapped my cpu, this has made a difference too im sure. I only tried it lapped so i dont know the results if i had not lapped it.
    Now previously with the first p5b and noctua-nu12 i got the maximum of 468fsb with no lapping.
    So with new p5bd back not bothering to as5 the nb and sb and not replace with my zalman flower nb i proceed with everything on auto at 450fsb from memorised bios settings and went from there. It posted. I try 475fsb it posts. Thats 3800mhz. So i keep going only thing i had altered at this stage was to put divider at 1:1. At this stage im going wow i beaten my previous best and all on auto too. Vcore was showing 1.55 and temperature 55c. I now enter 500fsb i thought no way but still. It beeps it posts!!
    No Wayyyy. I like nahhh its not happening. So i try more 510fsb it posts 4080mhz. ok lets try 520fsb yes it posts 4160mhz. I boot up into xp no problems. Its stable no reboots yet got to do more testing. Now all this time temp of vcore has been 55c no matter what the speed so it obvious the tec was kicking in, cooling and maintaining that same temp wether it 3.6 or 4gig. I havent even used better cooling on the nb yet. I'm impressed.
    Its worked out a treat its nice to be proven right. I got to 4 gig and beyond. hehe
    I try manual settings this week. Potential to go more. I post results this week.
    Heres pics.
    http://artco.adsl24.co.uk/markymoo/11.jpg
    http://artco.adsl24.co.uk/markymoo/22.jpg
    http://artco.adsl24.co.uk/markymoo/33.jpg
    http://artco.adsl24.co.uk/markymoo/3.jpg
    speed and temps
    http://artco.adsl24.co.uk/markymoo/markymoo3.jpg
    Aug 2006
    Quote Originally Posted by markymoo
    I've had this tec cooler a whole month and been wanting to try it. I saw no review with it on c2d only amd so i was interested to find out what it could do. I been waiting on a corsair 620w psu before i could try it. Upto this point i had 3.7ghz with a noctua-nh-12 55c on idle so i wanted to try the tec to see if i could get much closer to 4gig. I heard good reviews but alot were quick to put it down especially wc users were keen to put it down due to it being a low powered tec etc. That didnt put me off i read all the reviews and was keen to see what its potential was. I had delays and so surprised no reports on the c2d published were still not published.
    p5b deluxe wifi
    e6400 c2d
    I had it installed in a kandalf case and the titan 120mm fan lined up with the exhaust case perfectly. A couple of 120mm fans blowing in the front and a corsair 620w psu replacing a hiper580.
    soooo what kinda temps did you get under load?
    Specs:
    - e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
    - P5W DH Deluxe Cooling Mod
    - 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
    - Nvidia 8800gt
    - Silverstone ST75F 750watt
    - Modded Asus Vento (Black) *Heavy Case Modding In Progress*
    Xtreme Cruncher
    Oct 2006
    Boston, Massachusetts
    shouldnt this go under TEC cooling? but nice none the less
    Sep 2006
    well its not stricty pure tec it listed under aircoolers roundup review
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    No, it is a tec cooler. For some reason, people seem to get the idea that tecs are only for W/C. Thermoelectric is just a result of two different metals with a current passed threw it. It doesn't mean W/C or air cooling.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Oct 2006
    Wisconsin
    To be continued...
    im impressed that is sweet
    LEXA NZXT Case
    Gigabyte GA-965P-DS3
    Ultra Quiet Zalman CPU Cooler
    Pentium D 2.8 Ghz OC to 3.4 Ghz
    2- 512 GB Corsair Ram
    nvidia g-force 7300 GT
    2- 120 GB seagate SATA HD
    19" Samsung LCD
    Sep 2006
    Quote Originally Posted by Nanometer
    yes what i meant to say it tec with an aircooler. your absolutely right it still the peltier effect. just this time with heatpipes. what im saying its only a 60w tec not like the 226 tecs you get with water.
    its one way to go without switching to water. to those who think it expensive. a tuniq tower and 2 nexus fans works out the same price.
    Xtreme Mentor
    May 2005
    Ah, I see. Gottcha 100% .
    Be fun to play with this cooler and have some over voltage and a single vantec tornado.
    May 2006
    whats the noise level like for Titan Amanda tec as with watercooling you could hit 4gig with silence. ?
    c[_]
    Nov 2002
    Alberta, Canada
    swap for a more powerfull tec... but then you'll need a better psu again lol
    All along the watchtower the watchmen watch the eternal return.
    Sep 2006
    @Digz
    the noise is low from fans spinning at 1400-1700rpm
    Sep 2006
    Quote Originally Posted by enz660
    the tec keeps it at 55c wether it idle or load. it just turns up the cold supplying more volts.
    Banned
    Jul 2004
    Scotland
    I think some peeps here are confused or aint read other threads here.
    This cooler is classed as air its not a normal TEC where you need major power or creates condensation, it runs at just right temp to do the job in hand it runs as a AIR cooler and turns TEC side on and off when needed.
    Ther is a few threads here on it.
    Apr 2003
    London. UK
    soiunds great, but i'd be interested in knowing which progran your using for temp readings.
    RIG 1: X6800 | DFI Infinity 975X/G | 2x1GB OCZ PC2-8000 Plat EL XTC |
    X1900 XTX Crossfire | FSP 700W Epsilon |
    Jan 2007
    maybe some screenies as well too
    Jul 2006
    Orlando, FL
    wtf
    this is xtreme systems, some screenshots are in order..and at least some super pi..
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    Quote Originally Posted by STEvil
    roflmao why don't you try that? Your CPU will be toast, because that aircooler can't handle a big TEC!
    Lenovo Thinkpad X220 - Core i5 2410m, 4gb
    waiting on 28nm video cards...
  18. #18
    Oct 2006
    Atlanta GA - USA
    my CNPS9500 handled a 120w TEC with no load
    but with load im not sure how much it could handle
    Heatware -> http://heatware.com/eval.php?id=51939
    Ebay -> http://myworld.ebay.com/onewhoisplug
    Feel Free to hop in my ventrio server and chat with us
    Vent6.gameservers.com:4498
  19. #19
    Admin
    Feb 2005
    Ann Arbor, MI
    Quote Originally Posted by Cupcake
    Not much more....CNPS9x00s can't handle much of a load
  20. #20
    c[_]
    Nov 2002
    Alberta, Canada
    Quote Originally Posted by serialk11r
    I said more powerful, I did not specify a high power 220w+ unit.
    I expect it should handle a 120w or so tec well enough though.
  21. #21
    Xtreme Cruncher
    Dec 2006
    Palo Alto, CA
    From my understanding a TEC will pump some amount of heat regardless of load or not. Well actually since its performance changes with temperature it probably varies a bit. But a decent sized TEC would probably burn up.
  22. #22
    May 2006
    Philippines ^_^
    some screenies please..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
  23. #23
    May 2006
    @markymoo
    Do you have or have ever owned a water cooling kit ?
    Ifso what do you think of watercooling V's Titan Amanda.
  24. #24
    Sep 2006
    you better to go watercooling in the long run. i get 37c on water at 4gig (plus i cooled my gfx card by half) compared to 55c with amanda. wc rig is in my sig. if you cant afford wc'ing go with the amanda its very reliable and stable.
    System Specs
    *New Rig*
    DFI DK T2RS - I love this board.
    Intel Quad 6600 52C load 3.87gig stable
    Asus P5B Deluxe WiFi
    Core 2 Duo E6400, Q6600 55c 4gig stable
    2X2Gb G.Skill 8000 PQ Series
    256MB Sapphire Radeon X1950XT
    Corsair HX620w Modular
    Titan Amanda Tec Cooler
    Zalman Flower NB Cooler
    Akasa 4 Fan Controller Pro
    2x 120mm XinRuilian
    2x 120mm Nexus
    Kandalf Black
    Watercooling Rig
    Swiftech Storm 18c Idle, 33c Load
    Maze 5 Gpu 28c Idle, 45c Load
    Thermochill PA120.2, 1/2" DD Tubing
    Laing D5 Pump, T-Line
  25. #25
    May 2006
    Did you get any higher stable clock with water ?
