Results 1 to 10 of 10
Thread: Scythe Infinity on Gigabyte motherboard
    Dec 2006
    Does anyone know if Scythe's Infinity CPU cooler fits on a Gigabyte GA-965P-DS4 motherboard? From the looks of it the capacitors around the CPU on the m/b will either stop the cooler from fitting properly or will get damaged from the pressure.
    Plz help!!!
    Sep 2006
    Netherlands
    I'm having exactly the same doubts about Zalman CNPS9700 LED. The capacitors are pretty close to the socket and the whole is surrounded by chipset heatpipes.
    Xtreme Mentor
    Jan 2005
    The Infinity will fit, the Ninja also fits + a Tuniq Tower. There are no clearance issue with the Infinity + Ninja...it's been tested.
    Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
    Sep 2006
    Netherlands
    Quote Originally Posted by Richard Dower
    What about the backplate on the Gigabyte boards? SOme coolers require them to be taken off. I notice the Scythe's use the same attachement procedure that Intel stock is using. If it's just that, that's something some manufactuers could take an example off.
    Dec 2006
    Thanx for the info Richard,
    Just bought the Infinity. Can't wait to install it and o/c the cpu
    Sep 2006
    Netherlands
    Quote Originally Posted by Sling
    Well, did it fit? How easy was it to install on the DS4?
    Xtreme Mentor
    Jan 2005
    Quote Originally Posted by Kaap
    For the Scythe Infinity + Ninja...no need to take off the backplate/Crazycool. As Scythe uses the standard Intel push pins. For others such as Thermalright Ultra-90/120 (both tested to fit/no clearance issues) you need to remove the crazycool backplate for the Ultra-120 while the Ultra-90 uses the same Intel push pins.
    Tuniq Tower requires backplate removal, due to weight issues.
    Xtreme Mentor
    Jan 2005
    You just push the pins down, follow the Scythe instructions...it's rather simple and not much force is needed, listen for the "click" sound, if you can turn over the mobo to see if the pins are properly showing on the backside of the mobo...careful to put your hand on the cooler while turning over the mobo.
    Follow Arctic Silver instructions for AS5 www.arcticsilver.com
    Dec 2006
    Well, things are a little bit cramped in there but it fit just fine. I don't have previous experience on installing cpu coolers so I can't say if it was easy or not.
    It was definitely easier than expected and as simple as Richard says.
    Xtreme Mentor
    Jan 2005
    It does take up alot of mobo space, as it's a very large heatsink, it depends on what kind of case you have etc., but in general you'll be able to get to everything on the mobo when nesscary.
