Results 1 to 22 of 22
Thread: 8800GTX Mods
    Jul 2003
    8800GTX Mods
    Lookin for a couple of "yeah that looks good to me" before firing this baby up, mainly wanna double check the ground location or to ask if anyone found a different mod location that might not be under insulation like this one
    Slovenian OC Master
    Nov 2004
    Slovenia
    you have a lot of pins where both 6-pin conectors from PSU comes, botom ones are all ground and very easy to solder on
    that's for ground
    OC-Lab.si!!
    Jul 2003
    Hmm so you think this isn't a good idea? I ohm'd it out and it was 0 resistance this point to the card flange.
    Slovenian OC Master
    Nov 2004
    Slovenia
    Quote Originally Posted by G H Z
    no, if it is ground, that it shouldn't be a problem, i just rather use the obvious point, big, easy to solder
    OC-Lab.si!!
    Nov 2005
    Any good results you wanna share with us G H Z ?
    Oct 2006
    AU
    so did it work?
    CPU: i7 2600K @5.2GHz
    Cooling: Water
    Ram: 2x2GB G.skill
    Videocard: GTX 580
    OS: Windows 7 x64
    Jul 2003
    Busy with a few other projects, I'll let you know when it's benching
    Oct 2006
    AU
    as soon as you confirm that it works i will do mine.
    Cooling: Water
    Ram: 2x2GB G.skill
    Videocard: GTX 580
    OS: Windows 7 x64
    May 2006
    Hong Kong
    Waiting your report
    Intel C2D E6600
    Asus P5B-Deluxe
    Inno 3D 8800GTX
    GSkill F2-6400PHU2-2GBHZ
    Creative X-Fi XtremeMusic
    Enermax EG701AX-VE SFMA
    HITACHI 80GB *1 / 250GB*2 Seagate 80GB *1
    Jul 2003
    Sorry for the delay guys, no this is not working. 500K does not change vcore over the full 20 turns of potentiometer. To clarify this is the correct mod location as shown by Shimano. I need to do a couple of things to figure out whats going on. 1 check my pot, 2 try another ground. Also wondering if the length of the wires has anything to do with it, card is running perfectly.
    Xtreme Cruncher
    Mar 2005
    EU
    I moded my GTX with 200 Ohm VR and work ok, but ... wall at 680MHz
    For ground I used fan conector.
    Regards
    Martin
    Life sometimes gets in the way of what we want to do.
    Jun 2003
    Portugal, Lisbon
    Use a 500Ohms not 500k variable resistance
    "God...i know she's dead :'( but keep her soul alive because in my heart she will never die :'(" VoRtAn_MaDgE
    Nc te eskecerei avó! :'(
    Jul 2003
    That might make a difference, thanks vortan
    Jun 2003
    Portugal, Lisbon
    Difference?
    That makes a huge difference G H Z
    Tell us how it goes after u put the correct vr m8...
    Cya
    Oct 2005
    Denmark
    any update on modding?
    Asus Rampage II Gene - i7 920 D0 Lapped - Lapped Noctua NH12U-F
    Sapphire HD4870 X2 - 6GB Corsair Dominator GT@T1 - Windows 7 x64
    2 x WD Velociraptor 150GB Raid 0 - 500GB Samsung T166
    Antec ThreeHundred - Samsung A656 40"- TX650W
    Oct 2006
    LOL
    As VoRtAn_MaDgE said 500Ohms to 500KOhms is a difference of few thousand Ohms ...
    ...minor details... lucky u it wasn't the opposite!
    Anyway looking forward to reading your results.
    Oct 2006
    Quote Originally Posted by DEVIL K-ce
    Is that 200Ohm your final resistance to the circuit or the VR's total resistance - you should clarify this. Anyway with a 200Ohm final resistance, the voltage gain under load is aprox. +0,16v (1.26v default [load] | 1,42v modified [load] | 1,49v modified [idle]). I believe poor cooling keeps you at 680 not voltage.
  18. #18
    Xtreme Cruncher
    Mar 2005
    EU
    Quote Originally Posted by HighT3ch
    200 Ohms is final resistance. Poor cooling hmm no way : chilled water
    And test is on 680i mobo = more vgpu voltage, not the same as 975X. Check with DMM and vgpu is 1.55V in idle, well 1.48-1.5V in load.
    Regards
    Martin
  19. #19
    Oct 2006
    Well sounds weird already, I guess either you are either unlucky with the card or something else is wrong. I suggest you use a fixed resistance not a VR and try again. I use a 150Ohm fixed resistance and I get 1,55v [idle] and 1,48~1,49v [load]. I have similar cooling to yours (chilled water) and run fine at 730 core. Do you provide adequate cooling to power mosfets etc?
  20. #20
    Xtreme Cruncher
    Mar 2005
    EU
    Mosfet cooling = delta 120mm fan with 12V power
    Meybe no lucky with this card
    But next test G80GTX - Galaxy card's in progress
    Regards
    Martin
  21. #21
    -100C Club Member
    Feb 2004
    australia
    would this mob be ok for say a XFX card?
  22. #22
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    -kayl-
    Yes. Every GTS/GTX is identical at the moment. Same pcb --> Same mods.
    You are as good as your samples are!
