Results 1 to 19 of 19
Thread: Tuniq Tower vs Scythe Infinity + Mods?
    Aug 2006
    A Stock Tuniq Tower, maybe with a lapped base, OR a scythe infinity with this mod and two Noctua 1200rpm fans (push/pull config). Can the tuniq really beat that? I know you would really have to test that but what does your gut tell you? lol
    Specs:
    - e6600 3.2ghz, 1.35vcore (MAX 3.9ghz 1.7v) Cooling: Project_Infinity: The search for the best quiet air cooling.
    - P5W DH Deluxe Cooling Mod
    - 2048mb Patiot PC2 5300 @ 890mhz, 4-4-4-12, 2.15v (MAX 1053mhz 2.35v)
    - Nvidia 8800gt
    - Silverstone ST75F 750watt
    - Modded Asus Vento (Black) *Heavy Case Modding In Progress*
    I am Xtreme
    Dec 2002
    both are good setups, just different, at the noise levels of 2x120's i think the scythe will probably give you better performance. But the adjustable fan on the tuniq will probably give you colder temps with the fan at max speed.
    but we are talking small differences here, what difference is 1 or 2c going to make? just go with whatever is cheaper/ more appealing.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Infinity probably edge it out... http://i4memory.com/showthread.php?t=3218 and http://i4memory.com/showthread.php?t=3211
    no Tuniq here to compare though
    Aug 2006
    Specs:
    - Nvidia 8800gt
    Memory Addict
    Aug 2002
    Brisbane, Australia
    interesting don't seem to see where they mention what case they used for in case temps ? 18C ambient temps for setups was used though...
    Aug 2006
    heres a quick diagram of my mod if I end up getting the infinity!
    tell me what you guys think?
    Specs:
    - Nvidia 8800gt
    Xtreme Cruncher
    Sep 2005
    Bay Area, CA
    tuniq tower cooling a Core 2 Duo chip seems more appealing to me.
    Aug 2006
    B U L G A R I A
    Go with a Tuniq,if you can find it...I am searching day and night for it..but Shipping from U$ to Bulgaria would cost...U$D 107...
    Aug 2006
    Quote Originally Posted by Fixt00l
    isnt the fan loud at full speed?
    Specs:
    - Nvidia 8800gt
    Aug 2006
    B U L G A R I A
    They say it is annoying,but it makes about 48,8 dBa,and my old Gigabyte 3D cooler was making about 60,and I was still able to work.
    Xtreme Cruncher
    Sep 2006
    Norway
    Talking
    In that case the Infinity have gone the other way
    The fan is spinning at 1128rpm and makes nearly no sound
    IT cools an Amd Opteron 165 at 2,7ghz and the heatsink isent even warm
    I love this Cooler
    Xtreme Cruncher
    Oct 2006
    Essex, UK
    How much difference in temps would you get having 2 120mm's on each side of that infinity?
    Aug 2006
    Quote Originally Posted by Bootup05
    well a test was done at x-bit labs and two 1200rpm fans did better than one 2000rpm fan.
    edit:
    it beats all the coolers in that test (open case) so with the pressure mount mod, I would expect it to be about 5c better than that test?
    Specs:
    - Nvidia 8800gt
    Aug 2006
    B U L G A R I A
    Not more than 4C,I suppose.
    Aug 2006
    yes, 4c isnt that much, but when you take into consideration that 2 1200mm fans equals about 24dba (two scythe s-flex 1200rpm) thats way less the the average 33-36dbz that is made by one 2000rpm fan.
    Specs:
    - Nvidia 8800gt
    Aug 2006
    B U L G A R I A
    How about 2 such fans on the Tiniq,then
    Egyptian OverClocker
    Mar 2005
    Cairo, Egypt
    Quote Originally Posted by enz660
    isnt the fan loud at full spedd?
    http://www.xtremesystems.org/forums/...d.php?t=126514
    Soon to be :
    ASUS P8P67 Deluxe, Intel SB i7-2600k, G.Skill Rj-X F3-12800CL6D-4GBXH, MSI HD6950 2GB, Corsair 750AX, Intel 80GB G2 SSD, DELL U2410
    Used to be: SaFrOuT
  18. #18
    Dec 2006
    Phoenix, AZ
    Forgive the n00b question...
    How would that work with only 2 flat sides on the Tuniq and it's orientation on the board?
    and why not swap out the Tuniq fan for a <30db fan?
    I've been trying to decide between the Infinity with mods vs. Tuniq for my sig build...Any thoughts?
    *** H0RM0NE ***
    "Fight's on; Fight's on."
    Current Build:
    * Asus P5N32-E SLI PLUS Rev A2 BIOS 0602
    * E6400 L629B642
    * Crucial Ballistix 2GB PC2-8000 CL5
    * Corsair HX620W
    * XFX GeForce 7900GS XS 256MB GDDR3
    * 2 x Seagate Cudas 400GB SATAII RAID 0
    * Creative SB X-Fi Platinum 7.1
    * Onboard Nic/Lan
    * Scythe Infinity P/p & TT CL-C0034
    * Antec P180B
    * NEC Multisync FE2111sb
  19. #19
    Aug 2006
    I <3 a quiet pc so I went with the infinity with mods. It took a lot of work to finally get improvments over the stock performance if the cooler, but in the end, I have tuniq temps and a silent pc. After trying this out, I wouldnt say it beats the tuniq, but if the tuniq were turned down to the same noise level as my cooler, it would lose.
    Specs:
    - Nvidia 8800gt
