XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Old 12-03-2006, 02:31 PM   #1
dinos22
...you two characters
dinos22's Avatar
680i owners pls join in. We need to figure out FSB "strap" change performance hit
Hi Guys
There's been a little talk now that at high FSB 680i chipset takes a beating from 975 much like 965 boards do past 400MHz FSB particularly Asus P5B Deluxe unless you boot <400FSB and clockgen up
Denny confirmed yesterday that there is a performance penalty past 424MHz FSB and i'd like others to join in and do some testing and determine whether all boards are the same
when you join the thread please run memtest 1.65 and do 5MHz FSB jumps from say 380MHz FSB and look at the RAM bandwidth. Once you see the bandwidth drop after increasing FSB determine at which FSB EXACTLY that happens and post some 32M SuperPI times
****MAKE SURE YOU MANUALLY SET RAM TIMINGS
once you've done that jump to this thread
http://www.xtremesystems.org/forums/...d.php?t=125418
and download latest beta clockgen for these boards and then boot at fast FSB and clockgen up to see whether the "strap" stays the same (i'm calling it strap as i don't know what nvidia would call that heh).
Also test what the highest benchable FSB in fast mode is comapared to looser/slower mode
here is Dennys finding
Originally Posted by guess2098
here is the proof that 1699 & 1700 FSB break line
1699FSB (424.7) fast 32M
1700FSB (425) slow 32M
anything above 1700+ are kinda useless now
i'll be joining in when my 680i arrives....any day now
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 12-03-2006, 03:16 PM   #2
skiman
This might be helpful for what was happening on P5B
http://www.bleedinedgesupport.com/oc...ad.php?t=23803
__________________
skiman is offline   Reply With Quote
Old 12-03-2006, 03:27 PM   #3
dinos22
dinos22's Avatar
thanks for the link
yes we have a massive thread here regarding 965 chipset 1333 strap change at 400MHz FSB. Basically nvidia 680i chipset seems to have the same performance penalty so let's get people to contribute here and find out more
__________________
Team.AU
Got tube?
Old 12-04-2006, 12:47 AM   #4
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
what about linked and unlinked comparing the exact same ram timings.
so lets say 1699 @ 840mhz linked Sync
vs
1700 @ 840 unlinked Ram at 840.
(or what ever the actual setting would be)
you see what i mean. is linked or unlinked making a difference.
is like 3:45am and i am dead as hell and dont have the patience for 32m pi runs until the sun comes up but i will be trying it.. maybe.
my RMA 680i comes today. as eVGA was very happy to rma my board when i told them i was having the Raid and SATA errors.
they know about it, but kinda suprised them RMA'd the board if there isnt a fix. along with the huge FSB holes.
basically i cant boot at over 450mhz no matter what cpu multi or ram timings or anything.. nothing works.
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 12-04-2006, 01:22 AM   #5
Lestat
I am Xtreme
Lestat's Avatar
ok well i figured linked or unlinked wouldnt make any difference and i was right.
i lost nearly 27 seconds when going from 1699 to 1701
by using Clockgen, i still lost over 19 sec. so there is still something else going on.
and since clockgen uses higher increments i was even running faster cpu. (just a few mhz but still)
ram is 1:1 so its only like 850mhz
but even so that other guy has got some insane 32m scores. i mean sheesh.. he is over 3 minutes faster than me at the same cpu clocks.
__________________
Old 12-04-2006, 03:24 AM   #6
damnnit
I notice with my board it boots up to 461 then has a hole till 470-473 then 500-520. Maybe this will help you. 1mb superpi is long enough for me, i havent tested any 32mb yet.
__________________
QX6700 ES - B1 S5
eVGA 680i
ATI x1800xtx
Cellshock DDR1000
Silverstone DA750
damnnit is offline   Reply With Quote
Old 12-04-2006, 03:52 AM   #7
lopri
Are you guys setting memory subtimings mannually? Those change by whatever logic NV implemented, and FSB is a main factor that affects the subtimings. If you leave them auto, they will change drastically per FSB, memory speed, etc.
Edit: Never mind. I guess OP already set timings mannually.
__________________
I don't check my PMs very often.
lopri is offline   Reply With Quote
Old 12-04-2006, 03:56 AM   #8
dinos22
dinos22's Avatar
YES it's important that ALL memory timings are manually set for this exercise including vdimm
linked and unlinked is another lot of tests that would be interesting to see
__________________
Team.AU
Got tube?
Old 12-04-2006, 04:18 AM   #9
JohnMike
JohnMike's Avatar
That is true. I got my eVGA 680i this weekend and played with it for a while before i set my 24/7 setup. At first i just play with the main timings and was hard to go higher with Ram (CellShock DDR2 PC2-8000 2GB) speeds, then i start mess with the Ram subtimings and i was able to get higher speeds and stability.
I believe that Ram subtimings are one of the main keys to get higher performance from the board, i think thats a plus from nVidia 680i chipset over Intel 975/965 chipsets.
So it mayte be usefull that we share subtimings setups. I will post my once i get home.
__________________
Windows 7 Ultimate 64bit, Power By:
Asus Rampage II Extreme
Intel I7 950
Corsair DDR3 1600C7XMS 6GB 7-7-7-21
Sapphire HD 5870 1GB
SSD GSKILL Falcon 128GB
ASUS DVD±R 16x DRW-1612BL
Corsair HX1000W
Silverstone TJ07 Black
JohnMike is offline   Reply With Quote
Old 12-04-2006, 07:56 AM   #10
Lestat
I am Xtreme
Lestat's Avatar
dino check my piost above for a quick linked/unlinked comparison using the same ram speed.
__________________
Old 12-04-2006, 09:47 AM   #11
kapdori
I am definitely loosing memory bandwidth going from 1699 to 1700 fsb.
I was actually running my e6300 at 1880 fsb with my memory timing of 4-4-4-9 at 940mhz and I was very disappointed with my bandwidth. I tried many different timings for the memory at different speeds but that was best bandwidth I got but still no happy. But at my cpu speed at 1699, I get more memory bandwidth even with same timings for the memory. So definitely there is a hole or something above 1699 fsb.
kapdori is offline   Reply With Quote
Old 12-09-2006, 01:12 PM   #12
illuminati-hwt
From a fellow danish overclocker (Hessi):
424,75 (1699) x 8, Super Pi 32M @ 15:39,281
430,50 (1722) x 8, Super Pi 32M @ 15:56,390
424,75 (1699) x 9, Super Pi 32M @ 14:29,360
430,50 (1722) x 9, Super Pi 32M @ 14:36,969
411,25 (1645) x 9 = 3701,25 Mhz. Super Pi 32M @ 14:39,563
462,50 (1850) x 8 = 3700,00 Mhz. Super Pi 32M @ 15:01,219
__________________
Soon: Intel E8400 | GA-P35-DS3R | HD3870X2 | ST75ZF 750W
illuminati-hwt is offline   Reply With Quote
Old 12-09-2006, 02:15 PM   #13
X.T.R.E.M.E_ICE
so from 425fsb upwards the timings in the chipset get very loose.
__________________
Case:HAF 932|PSU:Corsair HX1000w|CPU:i7 920 @4GHz 8 threads - Cooling Corsair H50|Mobo:GB X58-UD3r|Ram:3x2GB G.skill Trident|GPU:His 5870 1GB 1000/5.2GHz|HD: Velociraptor300GB/SamsungF1 1TB|LCD:LG 32" Full HD|OS:Windows 7 x64
X.T.R.E.M.E_ICE is offline   Reply With Quote
Old 12-09-2006, 02:30 PM   #14
illuminati-hwt
Yeps, in the bios it's represented as quadpumped.. So 1699 is fine and 1700 enforces loose timings.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
