E6600 + 965-S3 slowdown!!!!?!
This is weird.....
I have changed everything back to stock default, but it seems that my system is basically running at half speed.
SPI is gone to 45 seconds or something, Memory bandwith has halfed. Basically all the results put me at the same level as a 3.0Ghz P4 !!!
This is on a Gigabyte S3
E6600 @ Stock 2.4Ghz Vcore stock
Idle temps 30-35 (from Core Temp)
Ram- Team Xtreem (512x2) 4-5-5-18 Default Timings @ 400 2:3 divider.
The gfx is a PCI elcheapo ATI from years ago.
Its fair to say that I only noticed after installing Power DVD, but I can't seem to put my finger on what caused the change. There had been many reboots when i was pushing the system earlier in the day.... but to run at basically half speed is weird.
So I suppose I will ask.... "Any ideas, cos I'm damn well confused?"
- You may not post replies
- You may not edit your posts
Forum Rules
