Results 1 to 5 of 5
Thread: 680i Simplified
Threaded View
    Xtreme 3DTeam Member
    Oct 2006
    680i Simplified
    With all the problems people are having with these boards, I thought that I would throw up some tips.
    maybe these have been covered before, elsdewhere, but it sure helped turn a not so good situation into an easy and rewarding result.
    HistorY:
    I got an EVGA 680i board to run my E6600 on. I got it up and running after a bit of fiddling, and fsb got up to 1942 / 4 x9, so I was kind of happy, but not overjoyed, seeing as I was coming from a P5B wheere I had no problem getting 562 Mhz out of the buss.
    Then the board died, so I went and got another one. This one would only go up to about 465 fsb, so I was not too happy, but I tsted a lot of different combos and wrote down all the fsb speeds that would boot.
    Strangely, some of the settings would boot most of the time, but sometimes I it would go into safe mode, when it just wirked fine. Simply saving the bios without making changes, 1 , 2 or maybe 3 times and it would boot. Shut it down completely and back to safe mode...hmmm
    Then I got a QX6700 and slapped it in...outside of the oem settings, it would not boot to anything AT ALL
    even at ANY of the E6600 settings that ran fine, NO GO.....
    fast forwrd to my point....
    Here is the deal....
    Here is how I st it up as a NO brainer
    1 Go into bios and set everything to AUTO. Disable 1394 and everything else that you don't need. Leave all voltages on auto except for maybe vcore and mem.
    Boot to the oem fsb and multiplier
    2) Reboot and check all the voltages.Set them all manually to what they defaulted to.
    Herre is where the fun begins
    3) You booted to the oem settings, so now look at the fsb screen
    You are set to AUTO , so fsb is 1067
    Look at what it says your ram is set to and also look at the timings. Also check to see if they match what your ram specs are, but don't change them just yet.
    Example: with my Gskills, fsb was 1067 , mem was 667
    4) Write all the timings down
    5) Now change FSB MEM Clock to LINK
    Change FSB MEM Ratio to AUTO
    Start upping FSB QDR Mhz from 1067 in incrments of 5 or 10
    The only othe settings that may cause a no boot is Vcore and Mem voltages.
    6) Keep rebooting while upping FSB QDR Mhz and posssibly core and mem voltages.
    Once you've reached the limit of your cpu, it's time to make soome decisions.
    That's a subject for another post, except to say that if you are happy with your current cpu speed, then start playing with the mem timings
    You can go into EXPERT mode and try forcing some better timings
    NOTE: It seems that the big deal is to try and get high fsb out of these boards. The method I decribed will get you to your top cpu speed, which has to be determined first.
    Then by looking at the mem settings, you can determine if more fsb is possible
    I advise NOT to go into unlinked mode until you've gone through this part
    My results so far?
    Currently running 1150 fsb w/ mem at 719...and the mem is GSkills PC-5400 with 3-4-3-8-1T timing all other mem timings on auto
    E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
    QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
    Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
