11-29-2006, 10:07 AM
#1
Super Talent T800UX2GC4 D9GMH
Has anyone some screen how high goes that Super Talent but on GMH?
11-29-2006, 10:13 AM
#2
11-29-2006, 10:17 AM
#3
Originally Posted by AzraelDarkangel
its ok but on GKX i'm asking about the GMH
11-29-2006, 02:59 PM
#4
I'll recive a pair of T800UX2GC4 tomorrow. Will tell you if I remember it xD
__________________
|| Core 2 Quad QX6850 ES @ 3.5Ghz 1.35V || Thermalright Ultra 120 || Asus P5K3 Deluxe || Gskill F3-12800CL7D-2GBHZ
|| XFX 8800GTX || Dell 2005FPW 20" || Ultra X-Pro 750W LE || 3 x WD 320GB SD + 1 x Hitachi 500GB
11-29-2006, 07:34 PM
#5
Ive got some but I am installing windows right now, so tommorow I might have results up.
__________________
11-30-2006, 01:08 AM
#6
i'm rather interesting in MHZ and CL of ram
11-30-2006, 01:50 AM
#7
I testet one pair of this memory.
On Asus P5B Deluxe (bios 0714) I could run DDR2-964 with 4-4-3-8 and 2.25 volt (stable through superpi 32m).
On Foxconn C51XEM2AA I could run DDR2-1060 with 5-5-5-15 and 2.17 volt or DDR2-908 with 4-4-3-8 and 2.17 volt (stable through memtest).
On AM2-platform I canīt use 1t and/or could get better timings than 4-4-3-5 with 2.17 volt.
11-30-2006, 03:11 AM
#8
so itsn't rather possible to get over 1 k on CL4 on that GMH??
11-30-2006, 03:20 AM
#9
With D9GMH you can go above 1k Cas4 but voltage range from 2.3-2.5 depends on your module and what mobo your are using
__________________
Intel Core I7 920 @ 3.8GHZ 1.28V (Core Contact Freezer)
Asus X58 P6T
6GB OCZ Gold DDR3-1600MHZ 8-8-8-24
XFX HD5870
WD 1TB Black HD
Corsair 850TX
Cooler Master HAF 922
11-30-2006, 03:56 AM
#10
I never tried higher voltages than 2.25 volt. Because itīs not my memory.  I think on c2d I can reach DDR2-1000 with 4-4-3-8 at 2.3-2.35 volt. Should be really easy with my kit.
11-30-2006, 04:06 AM
#11
ok so i still waiting for a screens with highest score
11-30-2006, 04:18 PM
#12
I got mine tested... I'm quite disapointed.
I get BSOD at any voltage higher than 2.2V  Timings doesn't care... I just have to keep 2.2V.
Mine can't do 4-3-3 at DDR2 800, so max agresive timings are the default ones, 4-4-3. At 4-4-3 it has rised to 460Mhz 2.2V, anything above 460Mhz needed Cas 5-5-5. I tried 2.3, 2.4, 2.5 adn 2.6V to try 270 at 4-4-3 but always got a BSOD (only with the supertalent, i have another kit of mushkin pc6400 D9GMH which likes 2.65V). And at cas 5-5-5 it even does 480Mhz... just about 475Mhz.
This is on a Abit AW9D-MAX, tried 4:5 and 2:3 dividir if it helps but nothing, same results.
As i have said, quite dissapointed...
PD: The mushkin does 440Mhz Cas 4-3-3 2.65V, 486Mhz Cas 4-4-3 2.45V and only 492Mhz at 5-5-5 2.4V. I may be doing something wrong
PD2: It's the blue heatsinks one and they are week 45 of 2006.
__________________
12-01-2006, 05:45 AM
#13
I've removed the heatsink and w00t... that's how it looks:
Rewrited chips ?  What are suposed to be ? D9GMH as well ?
__________________
12-01-2006, 02:37 PM
#14
interesting... anyone else know about these modules? are they d9's?
__________________
Main Rig:
CPU Intel E8400 Q816A @ 4250MHZ
Mobo Asus Maximus Formula
Memory 2x2GB G.Skill PC-8000 4GBPQ
Video Cards Galaxy 8800GT
PSU Silverstone ST75F Strider 750W
Hard Drive Maxtor 7200.10 (Seagate rebadged) 320GB SATA | WD 2x36.7GB Raptors in RAID 0
Cooling D-tek FuZion | Swiftech MCP655 | Thermochill PA120.2 | 4 Yate Loon D12SM 120MM
9.89s 9min59.078s
12-03-2006, 05:30 AM
#15
My super talent didnt work that well on the AW9D-max either..on the P5B DELUXE i had 4-4-4-12 on 500mhz with the 4/5 divider.
I upped the volts to try and achieve that again but my RAM eventually borked(on the Abit).
__________________
I'm just not interested in AMD.
Bugs in sigs suck.
Cheapen SSD drives (we're almost there!!) and bring back mobo fans!!!!
...remember kids,the Ipad is an incredible experience...
12-03-2006, 10:34 AM
#16
I've just noticed that not all chips have the same "serial" written. There are chips with:
SY010403PEBPC (most of them)
But there are some others than have:
S0116802PEBPD
Written into it.
What is this suposed to be ? Is supertalent using different chips in the same stick ? And does someone have any information about those remarked chips ?
__________________
12-03-2006, 10:40 AM
#17
could be D9GCT
12-05-2006, 05:32 AM
#18
just got my kit yesterday.
cpu-z shows them as pc5300... but run fine at 420 4-4-4-12. i haven't tweaked yet but they should hopefully get up to 500!  Anyone know if week 31 happens to be d9gkx still? i'm guessing not but just wanted to ask
__________________
Main Rig:
9.89s 9min59.078s
12-06-2006, 04:45 PM
#19
Does anybody have an update on this RAM?
It's the only POTENTIAL D9GMH I can buy here in Hong Kong. G.Skill's are out of stock indefinitely. Corsairs are now Promos, and Patriot are now Elpida. Can't buy Crucial, Buffalo, OCZ or TeamGroup out here.
That leaves SuperTalent - THESE EXACT MODELS: T800UX2GC5/T800UX2GC4
EDIT: If someone would be willing to help a person like me in a rather unfortunate ram position, please drop a PM my way. If these Super Talent turn out to be Elpida chips or something, I'm in dire need of a middle man in the US who can pick me up some NewEgg rebated Crucial sticks then send em my way.
__________________
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
i7 920 3924A 205x21 / 4315 | 4870x2 | EVGA M-ATX X58 | 6GB Corsair Dominator | Corsair HX1000 | Intel X25-M 160 G2 | OCZ Vertex 60 | WD 320 || Apogee XT - XSPC FC | (2)DDC3.2 | (2)PA 120.2 | (2)BI SR-1 120 || MM H2G0
12-07-2006, 12:32 AM
#20
Which mem do you have?the silver or the blue?
Can you tell me how much efficiency sandra shows?
12-07-2006, 03:02 AM
#21
Iīm a reviewer of the german hardwaresite www.planet3dnow.de .
I tested 3 pairs of memory on am2 (Kingston, Corsair and Super Talent). From Super Talent I used the silver one. Sandra showed nearly 61 efficiency. More information and benchmarkresults you can see here.
12-07-2006, 05:24 AM
#22
Thanks...a lot!
Sandra's efficiency isn't so good,is it?
how much is the average good score?
12-07-2006, 06:57 AM
#23
Thanks...a lot!
On am2 and ddr2-800 I would say itīs a normal score. Always could be better, but itīs ok.
12-07-2006, 02:54 PM
#24
the c4 model is the d9gmh.the c5 i cant say.
12-07-2006, 05:37 PM
#25
I see. Thanks for the info Maxfly. I'll go check today if they have any C4 in stock.
By C4 I assume the product code means CAS4?
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
