Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Tweaking the 8800 shader..
    Xtreme 3DTeam Member
    Oct 2006
    from what I understand, the default shader speed on 8800 cards is 1200 for gts and 1350 for gtx models
    using nbitor and nvflash, I tested the effect of increaing this to 1450 on a 8800 gtx
    system setup is as follows
    P5B Deluxe wifi
    E6600 running at 400 x 9 w/ 4/5 mem ratio
    xfx 8800 gtx running at default speeds and default voltage
    results in 3dm06
    sm2 = 4830
    sm3 = 4926
    score 11,221
    with shader at 1450
    sm2 = 4921
    sm3 = 5031
    score 11,401
    aquamark
    default 201,602 ran 3 times in a row with same result
    w/ shader at 1450 201,727...202,088...201,962 (3 times in a row)
    I don't believe that rivatune or atitool touches the shader clock
    So , please check it out and let us know your results
    from what I understand, 1500 is the limit (as per Nvidea), but who knows?
    Possibly the lower clocked gts can benefit more from this!!...
    E6600 week 28, Asus P5B vanilla, 4.64Ghz,P5B vanilla w/ Vmods, vapochill and other stuff, Super Pi 1M = 11.0000s
    QX6700 on EVGA 680i w/ twin 8800 GTX's SLI
    Second Place hwbot 3DMark06 Sli 20999 (12/2/06 till ...???)
    Xtreme X.I.P.
    Aug 2004
    Chile
    i believe you mixed the numbers with shaders at 1450 in sm3.
    looks interesting, can you push this further? can you try with OC on the vga?
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Here is something to look:
    Click image for larger version.
Name:	8800GTS clocks.JPG
    When you overclock your core, shader clock increrases too.
    I really think Nibitor does't work at the moment. (I will check it later tonight)
    You are as good as your samples are!
    Jun 2006
    Hollanda
    sm3 = 7926 = 4926?? lol
    Oct 2006
    Quote Originally Posted by metro.cl
    oops just a typo...but I correctd it
    I will be pushing this a lot further, but I was hoping that others would confirm the rivatune, ntune, atitool part for us
    i will have results later or tomorrow, ...awaiting the arrival of a qx6700 and replacement of my no boot evga 680i
    Oct 2006
    Nibitor does work for the shader
    I just tested it
    It may be an option if shader needs to be adjusted separately from gpu clock, no?
    Oct 2006
    Quote Originally Posted by lookmomnobrains
    too much going on...yes please shoot me
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    I just modified bios. I used 1296MHz shader speed (default 1188 + 96MHz). Have to test this more.
Name:	shader kellotus.JPG
    Oct 2006
    for anyone interested, here is a link to my post at another forum , where Nibitor and nvtweak is available
    http://www.mvktech.net/component/opt...d,40568/#40568
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    I have to believe my own eyes
    1680x1050 3DMark06 (4AA/16AF, Driver quality high)
    Default shader clock 1188 (core 684MHz real)
Name:	1680x1050 4aa_16af 24_7clocks.JPG
    Default shader clock 1296 (core 684MHz real)
Name:	1680x1050 4aa_16af.JPG
    Noticeable difference with high resolution.
    Oct 2006
    I also did another test ocing using riva, but with the base shader set to oem and then 1450 in the bios
    here are the results
    675/1000/1350
    aqua 206,856
    w/1450 bios 206,988
    3dm06 sm2= 5570 sm3= 5678
    w/1450 shader bios
    sm2= 5673 sm3 = 5765
    1 question arises...when ocing using riva, does it scale from the base settings...some think that it does oc the shader as well.
    so are we simply ocing on top of the base 1450
    This brings up an intereting question for the hard core benchmark crowd, and that is what are the gpu/shader limits and now that we can adjust separately, maybe there is more room to tweak
    perhaps setting the default core lower and shader higher or visa versa would allow using just riva to then tweak as a whole
    If this holds true, then we need to know the limits of the gpu and shader, so that one doesn't crash the system while the other still has headroom
    any thoughts?
    on another note....aqua is doing something strange
    I ran the test 3 times without exiting and the scores got progressively lower.
    I exited completely and ran it again and the score went up, but not as high as the first run
    So I used riva to return oc settings back to oem , then back to 675/1000
    Ran aqua again and the score was back up to the highest achieved.
    Any comments on why?
    Can some others please pick up the ball from here and post their findings
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Don't run aquamark. It doesn't tell what your GTX/GTS can do.
    3DMark06 with high resolutions is much better.
    Did you look that table I posted earlier. When you raise your core clock, shader clock always rise in certain point.
    Oct 2006
    Quote Originally Posted by SF3D
    yes that is interesting
    I can't seem to get the hardware monito in riva to work with my setup
    Do I need to change a setting somewhere? I am using 2.0 candidate 16.1 with forcevga device set at 92
    May 2005
    Sugar Land, TX
    Yes. I can't overclock my CPU right now and this is what I get in AM3..
    8800GTX @ 575/900 - 1482xx
    8800GTX @ 660/1062 - 1482xx
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    Unwinder released Rivatuner 16.2 with full 8800*** support.
    http://downloads.guru3d.com
    Oct 2006
    thanks...I was just there, but didn't spot it...
    Xtreme Mentor
    Nov 2005
    Devon
    Good job guys!
    Wish I have 8800
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  18. #18
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    This doesn't increase performance in games. F.E.A.R and Oblivion run worse with increased shader speed.
    Well, there is a good reason why they are not clocked any higher by Nvidia.
    This can improve 06 score when trying to break somebodys WR
    I flashed original bios back.
  19. #19
    Oct 2006
    try lowering it....you may be able to bump your gpu clock up a bit and keep the shader under control
    it's all fairly new, but the facts will come out shortly, I am sure
    Just some food for thought
  20. #20
    Xtreme Mentor
    Jul 2004
    Ontario
    I wonder why faster is worse in games? Odd...
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  21. #21
    Jan 2005
    Bay Area, CA
    Quote Originally Posted by cantankerous
    An increase in error rate would slow things down.
  22. #22
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    There is a lot of lag in games. In oblivion ~5-10 fps lower.
    I think, that when streaming processor (shader) speed is so much higher than default, it does not get enough input data from lumenex engine (core).
    Look this page:
    http://www.xbitlabs.com/articles/vid.../gb8800_5.html
    I don't know much about these, so someone with more knowledge could clear things up.
  23. #23
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Try to see the XTAL's (Crystal oscilator on the PCB) frequency and then add THIS frequency as much times as you wish on the default shader frequency: Default shader frequency + XTAL's frequency x 1 (or x 2 ,x 3, x 4, etc.) .....
    INTEL PWA FOR EVER
    Dr. Who my arss...
  24. #24
    Nice Hardware!!!
    Jan 2006
    Finland/Tampere
    hipro5
    Why? What is the point in that?
  25. #25
    Aug 2002
    Athens---Hellas
    ALL frequencies (core, rams, etc) have a reference frequency and they are "based" on that...
    INTEL PWA FOR EVER
    Dr. Who my arss...
