Results 1 to 23 of 23
Thread: 1T VS. 2T on Nforce 680i
    XIP
    Nov 2004
    NYC
    Thanks Franc
    Heres quick comparo @ 3-3-3-autos/704 and 4-4-4-autos/1006 with Team Xtreem 6400C3....
    3D...
    Sep 2006
    so 1t is SLIGHTLY better.
    gigabyte 965p-s3
    intel c2d e6300 @ 3.255 24/7 (stock hs/f)
    corsair xms2 (twin2x1024a-6400c4) ddr2 800 @ 930 5-5-5-15
    xfx 7600gt @ 650/841 [560/725 stock] (stock hs/f)
    samsung spinpoint-p 160gb
    antec sonata2 w/ 450w trupower2.0 psu
    i love my budget gaming rig <3
    highest OC so far.
    XIP
    Nov 2004
    NYC
    Probly so
    It needs more testing with higher cpu mhz. like 5Ghz and up for 3Ds.
    Also if some ddr2 5400 with default cas3 can run 1T with this board....it would be nice
    Xtreme X.I.P.
    Dec 2005
    nice review. I am having one hell of a time with quad core and this board.
    This board definitely is strange, it needs some bios help.
    Oct 2005
    Why are the runs so slow?
    I am Xtreme
    Apr 2005
    Upstate, NY
    680i's ram performance is just sad.
    Nice effort + comparison though.
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Oct 2005
    I know, I do not know what Kunaak was smoking when he said that 975 and 680i have similar chipset latencies...
    Xtreme X.I.P.
    Aug 2002
    Quote Originally Posted by fhpchris
    There is derfinitely something up with 680i and Superpi on the longer runs, I was running a 32M the other day and I was minutes behind the Intel 975 at the end for same settings. In 3d though it is pretty close. Weird.
    Regards
    Andy
    XIP
    Nov 2004
    NYC
    Yep, its a little slow..
    Xtreme X.I.P.
    Dec 2003
    Thanks for starting this thread, Dumo
    I hope you don't mind me adding some of my results? I did not want to create a new thread for the same analysis, so I joined the fun here
    Enjoy
    Testbed onfiguration
    Intel Core 2 Duo E6600, cooled w/ Intel stock cooler
    eVGA 122-CK-NF68-AR (nForce 680i SLI), BIOS P20 official
    Corsair TWIN2X2048-8888C4DF 2x1024MB
    EVGA 7800GTX KO @ 490+40/1390, ForceWare 84.21
    Windows XP SP2 with all current updates.
    --- DDR2-858 4-3-3-3.0-1T (Tras-Trp-Trcd-Cas-Cmd) ---
    SPi32M - 13:35................... 3DMark 2001 - 48695......... 3DMark 03 - 22166............. AM3 - 21056 CPU
    Everest Ultimate 3.5 - more
    --- DDR2-858 4-3-3-3.0-2T (Tras-Trp-Trcd-Cas-Cmd) ---
    SPi32M - 14:12................... 3DMark 2001 - 48435......... 3DMark 03 - 22133............. AM3 - 20299 CPU
    ... and for comparison, higher memory clocks @ 2T
    --- DDR2-938 4-3-3-3.0-2T (Tras-Trp-Trcd-Cas-Cmd) ---
    SPi32M - 13:59................... 3DMark 2001 - 48556......... 3DMark 03 - 22139............. AM3 - 20646 CPU
    --- DDR2-1206 4-3-4-4.0-2T (Tras-Trp-Trcd-Cas-Cmd) ---
    SPi32M - 13:32................... 3DMark 2001 - 48683......... 3DMark 03 - 22189............. AM3 - 21272 CPU
    --- DDR2-1306 4-4-4-5.0-2T (Tras-Trp-Trcd-Cas-Cmd) ---
    SPi32M - 13:27................... 3DMark 2001 - 48737......... 3DMark 03 - 22171............. AM3 - 21409 CPU
    So, 1T is quite fun, isn't it? Although I can boot to Windows and run e.g. SPi 1M @ DDR2-900 5-3-3-3.0-1T, it was not very stable for most other stress benchmarks. Also, getting even DDR2-858 8-3-3-3.0-1T to be ORTHOS or HCI Memtest stable, borders a miracle
    I will do some more testing as I hope to somehow get DDR2-900 5-3-3-3.0-1T to be at least SPi32M stable? So far, no joy But I really like the kick 1T gives in this particular benchmark!
    XIP
    Nov 2004
    NYC
    Yep, 1T is fun ..Really nice clock on those 8888 Bachus ...Reminds me of 6400C3 which imo is a 'free for all fsb/Dram' memory.
    Banned
    Dec 2005
    Everywhere
    My little test ... on eVGA nF680i SLI + Corsair XMS2 8500C5 + C2D@3600MHz, difference between 1T and 2T is +- zero ...
    Dominators are on the way ...
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Looks like the next challenge is to get 1000MHz 1T with 4-4-4 timings or less, and you'll have the ultimate performance that even DDR1350+ can't match.
    I like this lower latency stuff, it's very Athlon-ish.
    Formerly XIP, now just P.
    Nov 2005
    The Netherlands
    question:
    How many Mhz in mem OC (same volt, same timing) do you lose setting 2T -> 1T on average ???
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by TaPaKaH
    question:
    From the results I've seen, usually around 300MHz or more lost to 1T.
    Nov 2002
    Houston
    Quote Originally Posted by OBR
    The synthetic benchmarks will not show that big of a difference, it shows up in applications.
    X.I.P
    Mar 2005
    well..... becasue you guy need to try 4-3-3 @ 1200
    mine HZ runs 4-3-3 @ 1200 2.5v
  18. #18
    Sep 2005
    800MHz/3-3-3-1T was faster than 1100MHz/4-4-4-2T from my testing. I couldn't run many tests, however, because 1T wasn't stable enough.
    I don't check my PMs very often.
  19. #19
    Sep 2005
    http://img292.imageshack.us/my.php?i...dr8001tjx0.png
    Once you get 1T working, it's not slower than 975X.
  20. #20
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by guess2098
    Well that's some nuts G.Skill you've got there Denny. But hardly what the average forum goer posesses.
  21. #21
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    4-3-3 ?????? oh come on now man thats pretty outrageous for D9GMH
    i never doubt you guess2098 but thats insane for gskill HZ's
    unless you have the PC8000 HZ's then thats D9GKX
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
  22. #22
    X.I.P
    Mar 2005
    i think all D9 can do 4-3-3 from 1000 to its max (GCT, GMH, GKX)
    mine HZ is 1000 GKX tho
  23. #23
    XIP
    Nov 2004
    NYC
    4-3-3 1t
