Finally got an Asus P5B Deluxe for my Q6600 Kentsfield adventures and now the FSB is much improved over D975XBX Bad Axe1 board!
System:
- Intel Core 2 Quad Q6600 Kentsfield QUPT B3 Step 7
- Swiftech G4 Storm/Thermochill 120.3/MCP650 + Kayl 100W Custom PSU
- Asus P5B Deluxe 0804 bios (upgraded from 0405 bios)
- 640MB Gainward Bliss 8800GTS Dual DVI with 96.89 drivers
- 2GB OCZ PC2-8000 Titanium Alpha VX2 Micron D9GKX
- 500GB Seagate 7200.10 SATAII
- Gigabyte I-RAM with 1.5GB Kingston KHX3200 Winbond BH-5
- LiteOn 165H DVD-ROM
- FDD
- 3x 120x25mm 76cfm 0.4A fans
- 1KW OCZ ProXStream 1000PXS Quad PCI-E psu
Seems bios sensor is out of wack, but coretemp works fine.
@2400Mhz at 1.275v bios (1.232v)
Idle
Load
Seems on D975XBX Badaxe the 4 cores are registered differently from P5B Deluxe
D975XBX shows
1st cpu = cpu0 + cpu2
2nd cpu = cpu1 + cpu3
P5B Deluxe
1st cpu = cpu0 + cpu1
2nd cpu = cpu2 + cpu3
Strange the 1st core on 2nd cpu is always alot cooler!
@3500Mhz - 9x389FSB
To start 3500Mhz - 9x389FSB quad stressprime at 1.4000v (1.5v set in bios, 1.4720v windows idle droop to 1.4000v)
PCI Express Frequency: 100
PCI Clock Synchronization Mode: 33.33Mhz
Spread Spectrum: Disabled
CPU Vcore Voltage: 1.50 (1.432)
Memory Voltage: 2.10v
FSB Termination Voltage: 1.4v
NB Vcore: 1.55v
SB Vcore (SATA/PCIE): AUTO
ICH Chipset Voltage: AUTO
Memory Remap Feature: Disabled
Configure DRAM Timing by SPD: Disabled
DDRAM CAS# Latency: 4
DRAM RAS# to CAS# Delay: 4
DRAM RAS# Precharge: 4
DRAM RAS# Activate to Precharge: 8
DRAM Write Recovery Time: 4
DRAM TRFC: 25
DRAM TRRD: 6
Rank Write to Read Delay: 10
Read to Precharge Delay: 10
Write to Precharge Delay: 10
Static Read Control: Disabled
Modify Ratio Support: Enabled
Ratio CMOS Setting: 9x
CIE Support: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
CPU TM function: Disabled
Execute Disable Bit: Disabled
PECI: Disabled
Idle
Load
Seems 2nd cpu on the Q6600 with cpu2 + cpu3 run alot cooler than cpu0 + cpu1![]()
