Results 1 to 8 of 8
Thread: Did you see 3 cores before?!See come to the N680i is true of have a little bug?!
    Apr 2006
    Taiwan
    Oct 2006
    The netherlands
    I hope for you that it isnt a bug
    My PC:
    - Intel Core 2 Duo E8400 (9x 333),
    waiting at cpu waterblock for OC
    -2GBHZ G.Skill Dualchannel@ 333@ 1.9V
    -Asus P5B Deluxe, no mods
    -2x raptor 74gb (8mb) RAID0
    -8800GTS @ stock
    -Creative Soundblaster Audigy SE
    -Zalman 460W-APS
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    You can disable cores in bios. Check to ensure one didnt get disabled.
    You can disable 1, 2, or 3 cores.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    You just killed one of them
    May 2006
    Philippines ^_^
    Quote Originally Posted by Pt1t
    Nooooooooooooooo...
    I hope not..
    Asus P5W64 WS Professional , DFI Infinity 965P-S (testing)
    X6800 , E6750 es
    Micron Fatbodies , Micron D9gkx oem, Crucial 8000, Crucial Tracer 8500 (incomming)
    Ati FireGL V5100, Elsa FireGL V3100
    water cooling setup (EK 775 cpu block, swiftech NB Block, Swiftech pump, BI dual pass dual 120mm)
    Silverstone OP650
    raptors, baracuda
    Aug 2006
    Thats what you get for testing quads Now get to some real testing on the E6600 please Nah just kiddin...i hope for you that core didnt crap out.
    E6600 L629B
    Asus Striker Extreme testing. I hope DFI can make my dreams come true!
    CELL SHOCK PC6400
    Tuniq tower 120
    MSI 7900GTO
    OCZ 600W
    Apr 2006
    Taiwan
    Quote Originally Posted by FUGGER
    I didn't move any enactment in the bios
    Jun 2002
    Las Vegas
    You dont have to. Overclocking too far and reset or using the load presets if saved as a dual core.
    tripple check, thats where my cores went a few times.
    Intel Optane
    Platimax 1245W
    Intel 3175X
    96GB Patriot Steel
