Results 1 to 24 of 24
Thread: 620w Enermax liberty not upto a 8800GTX ?
Threaded View
    Feb 2006
    UK
    I installed a XFX 8800GTX yesterday and since i have ive been having a few problem which i suspect is lack of power.
    The first thing i noticed after installing is the post screen seems jerky when detecting devices etc, I can only descibe it to be like the lag in windows when you havent installed your graphics drivers.
    Also if I download anything my system keeps freezing for a second say every 5 seconds and eventually the download with fail. Also i copy say a 100mb folder to another part of my harddrive it will copy ok but im not able to do anything else, the taskbar is frozen and and it wont even let me CTRL-ALT -DEL ??
    I would have thought my enermax liberty 620w would have been fine with one GTX, ive connected both the PCI-e connectors to the card.
    My complete system:
    Asus P5WDH
    Conroe 6600 @ 3.6Ghz
    2Gb Team Xtreme ram
    XFX 8800 GTX
    76GB Raptor
    300GB Maxtor
    Swiftech apex W/C
    2 x 80mm fans
    Floppy
    DVD/RW
    CDROM
    The card seem to run fine, not problems playing games or running 3D06 and it has overlocked to 660/2060 so far .
    I wondering whether i need to shell out on a more powerful PSU or whether ive a faulty 8800?
    Here a pic of everest and the voltages look ok.
    Q9650 @ 4Ghz - 1.216v
    E8600 @ 4500Ghz - 1.34v - Q822A435
    Q6600 @ 4014Ghz & E2160 @ 3.6Ghz
    Silverstone Zeus 850w, Maximum formula,
    Custom Water Cooling, 4GB OCZ 9200 Flex II,
    Xfire 4850's 800/1150, 3D Mark 06 , Vantage,
    Frontlineforce
