Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: Project Oracle
    Oct 2004
    Project Oracle
    Thread notes
    This project has been going on for almost a year now I think, including the time I took to make the original design. Originally, it was a high school graduation project, but was interrupted when I was injured and unable to work on it. So now I'm back at it, with a new design and a new battle plan, so take a look through the work I've done so far and check the new design at the bottom of the post. My new metal is being picked up tomorrow, so I can start retrofitting the case to the new design.
    I was posting this on Gideontech, Bit-tech, and HardForum, but I've been lurking here for a long time so I figured I'd bring the log over. I'm working on cleaning it up and making it one coherrant post instead of 25+ separate ones.
    The Design
    Design Notes
    I forgot to include the dimensions and whatnot, but Oracle will be a 16 inch cube constructed out of 1/12th inch aluminum. The finish will either be a very nice automotive gloss black paint, or powder coated something nice and shiny.
    The water tank will be constructed out of 1/4 inch acrylic, and will be lit by white LED's embedded in the plexi. I've got an air pump that will pump bubbles into the tank and hopefully create a very pleasing effect. Check out my inspiration over at Metku Mods.
    I dont have the side panels designed because that depends a lot on the internal layout which seems to be changing constantly, but it will involve lots of mesh.
    At this moment I'm planning on having most of the fans pushing air in, and let the heat float out of the mesh top. However, should that not work I will build a bracket of some sort holding 2+ 120mm fans to pull air out.
    Cooling
    -CPU: Dangerden TDX
    -GPU: Whatever waterblock fits on a 7900GS
    -Chipset: Something passive
    -Pump: Aquaxtreme AQX-50Z-DC12
    -RAD: Black Ice Pro III
    Prep
    The work area: (yes, I cleaned up after I took these)
    The Tools:
    My home made metal break:
    My dad picked this up off lease for $120. It looked brand new when we leased it, so we figured it was better than spending $250 for a new one. Cuts aluminum like butter.
    Stage One: The Exterior
    I started out getting all the pieces I'd need for the exterior of the cube sheared down to size by Carlson Steel in Bellingham. Anyone needing some metalwork done in Whatcom County should look them up, they're a good group of guys.
    The base:
    The back on:
    The top strapped in place:
    The front riveted in:
    The cube from the back:
    That last picture shows quite a few things: the Lian Li motherboard tray I'll be using, the sheet of tinted acrylic, and the door to the paintbooth where the parts will get painted
    The top cut (the mesh is just sitting there at this point):
    The front and back cut:
    The current internal layout, with the finished PSU mount in place. Note that the hard drive rack is just sitting there, I haven't decided how I want to mount it yet.
    How I built the first piece of the bracket. Next I added a piece of aluminum bent to 90* that runs parallel to the bottom of the bracket. Note that the bracket pictured below was a prototype, the two I have in my case are more squared and dont have the slope on the top and bottom.
    Once the whole thing gets painted you wont see any of those scratches or the pen marks, so all in all much cleaner. I still need to drill and tap the mounting holes to secure the bracket to the case, but that's for another day.
    I've made some other progress, but I dont have current photos. I've been running up the ol' credit card picking up some parts.
    From performance-pcs:
    I will never buy from these guys again if I can help it, everything that's showed up from them has either been in terrible shape or missing pieces. Nothing major enough to warrant a return, but still annoying as all get out. They do, however, have a lot of parts that no one else carries, so sometimes you just have to grin and bear it. Another thing, I ordered the racks out of a PC-7 HERE, but they called and said they didn't have those, but instead the racks out of a PC-65. Considering the design is identical, I figured what the hey and had them ship my order out. This was not what I expected, however, due to the time constraints I'm working under, these will have to work.
    All the fans and the fan grills came from SVC, which I still think is the greatest web shop ever for this sorta thing.
    More toys, again from performance pcs:
    DESIGN NOTES
    I have decided to drop the optical drive in favor of a more developed fan control system. This makes the most sense for me since I've only used my optical drive maybe 3 times on my main rig since I installed windows and I can just pick up an external enclosure anyway.
    Next up on the to do list is to get the motherboard tray cleaned up and mounted, as well as finally build the water tank and get it tied into the case. After that comes the fan controller, the fan mounts, and then I'm just about done, save making the mount for the hard drive rack.
    Got a little work done over the last couple of days, but with midterms coming up (i.e. tommorrow :grr: ) I wont have anything new for a couple days. I've also found that I'm not big on "in progress" pictures since I have trouble stopping to take them. However, when I break the whole thing down for paint you'll get to see how it all went together.
    Started with this hunk of metal, it was actually meant for the optical drive rack, but since I sacked that plan I figured I'd put it to use.
    Bent it, drilled it, mounted a piece of aluminum to the side and came up with this:
    That being one half of the motherboard rack, I obviously needed another. This one I decided to connect to the front of the case for two reasons: chassis rigidity, and additional support for the board.
    I made a mock up of my tank just to make sure I can get the desired effect and whatnot. Its very rough and I got adhesive all over the thing, the next model will be cut with a router (vs a tablesaw) and have sanded edges and whatnot.
    This was also my first experience with plexi glue, so that was interesting to say the least. However, all in all it turned out how I wanted it, and when I lit it up and added bubbles it was :jawdrop: worthy. I had to set it in the case just to see what it's going to look like, and I must say I'm rather pleased. Once I build the new one and get the case painted its going to look just like I wanted.
    I rough cut the pieces I would need and got the templates sized, only to find that my router had busted a bolt so I sicked my dad on the problem, he wont have time till this weekend to check it out.
    Design Notes
    Not too much, had to change my motherboard rails from channel to this current design. I still need to add some round stock in the middle of each bracket to add some support.
    In other news, I got myself a mini fridge and stocked it nicely:
    Got a bit done today.
    Mounted the radiator, though I seem to be missing the shots I took of it all tied into the case, so I'll have to snap some when I get out to the shop later.
    I dont really like how this turned out, so I think I'm going to spring for a quality 117mm hole saw ($30 :sigh: ) and redo the mount.
    I cut the panels for the new tank and started to sand them down, but didn't have the time start gluing them together.
    Tomorrow I should get the tank built and mounted, and reinforce some of the brackets with some round stock I picked up.
    Got the plexi cut for the new tank. The process wasn't that difficult, but it was messy. Basically I rip the sheet down with a table saw, making sure that they end up being slightly larger than intended. Then I clamp it down on a particle board form and run the router around it. Little filing and some sanding later, and I end up with some very nicely cut plexi pieces.
    I got the first part of the tank built. I'm waiting on building the rest until I can drill and tap all the holes that need to be drilled and tapped.
    This is everything that's going to be attached to the tank. That's two fittings for the water intake and out take into the watercooling loop, and two fittings for the air pump.
    Three things I love about having a former mechanic (and generally very handy guy) for a father. The first is the air lines plumbed in all over the shop and connected to a very nice air compressor, the second, I say "hey dad, you happen to have a tap set?" and he pulls this out:
    and then says "I have the rest at work," so I'm all set in that regard. Then the other day when I was cutting the rad mount out, he pulled this out:
    The diamond bit works wonders. I used it in cunjunction with files and sandpaper to get the finish I wanted and the general shape.
    My smaller workbench is a mess at the moment :o My next project may be cleaning it up.
    This modders occasional drink of choice:
    And for anyone who forgot what I'm cooling this with:
    The Plexi cutting process:
    Rough rip, clamp, route, file, sand.
    Building the tank:
    The result of the cutting process:
    The finish is decent, but occasionally the router bucks, resulting in those wonderful white imperfections.
    The tanks upside down, the end with the two fittings are near the bottom of the tank. Once I glued the top on, I realized I forgot to drill and tap the fill port, so I haven't glued the bottom on yet. I'm letting the whole thing dry before I drill the top to keep any plastic chips from sticking to tacky glue.
    Dropped the tank into the case, just to see how it would look, I'm debating painting the outside back of the tank black to help it blend into the rest of the case.
    Been working on the feet:
    Sometimes you just need a bigger drill :naughty: or I just needed a drill with a half inch chuck and the 18v Dewalt wasn't home.
    Slapped the pieces into the drill press to shape and sand them:
    The finished piece sans lighting. Credit goes to zapwizard for the basic design. This one is the small foot that will fit next to the radiator in the back corner.
    Got the feet mounted, they still need to be tweaked and tightened, but all in all I think they look pretty good. I've got a special plan for the little one, but you'll have to wait for that. They also need to be lit. I'm debating between having a couple LED's in each foot, or having one larger circle in the center with 10 or 20 LED's, thoughts?
    Last coat of paint I put on freaking orange peeled on me. :wallbash: So I might just let it be, or it'll get sanded down and prettied up. Just FYI, this is take version 2, velcro mounts and CCFL lights. V3 will happen after the rest of the case is tied together and powder coated, and will have metal brackets for mounts and a small pile of LED's to light the bugger.
    Picked this up from a friend, its got a blown PSU, but is otherwise fine. Should make a nice little box to play with linux on and whatnot. Plus, its a micro ATX board, which just might make it into my next project...Oracle II anyone?
    Specs:
    1Ghz Duron
    256MB RAM
    20GB 7200RPM
    Geforce 2 Something or other
    Painting the res black was the right choice I think. I think I'm going to have the fittings powdercoated black as well so they blend in better.
    Couple things here: you can see the strip I left unpainted on the res for my light bars (Cold cathodes will be there temporarily, LED strips will take their place), and the motherboard tray support bars are in place. They serve two purposes, to level the motherboard tray out, and to provide support. All they need are some small washers to shore them up and I'll be good.
    Update on the watercooling system:
    Talking to the cooltechina support guys, they told me not to restrict the intake, so I slapped a new 1/2inch fitting straight into the side of the res. The extra plug and cool elbow on the back will run to a drain line for all my bleeding needs.
    I'm going to pretty up the adaption setup on the outtake, I just haven't figured out how yet.
    Assuming all goes well with my ethics test tomorrow, I'll screw the pump in and get the loop installed, plus I should get the side panels mapped and cut. I'm hoping to have everything wrapped and off to be powdercoated by Wednesday, Friday at the latest.
    Small problem eh? Looks like the motherboard tray support was off line and is tugging the case. The side panels correct that little issue, so life is grand once again.
    One side panel mounted. I haven't cut anything out yet, but this panel is going to remain largely intact as I want to shield the sound of the two pumps as much as possible.
    I decided to go with a solid piece of angle instead of tabs like I did with the rest of the cube to provide the top with a little more rigidity. I haven't cleaned these pieces up, so I'll round the edges and do a couple more things next time I'm in the shop.
    Notes
    I've decided to paint the case instead of powdercoat it for a couple reasons. 1. I've decided to go with a multi tone color scheme. I'm thinking black on the outer shell, grey mesh, and something insane for the interior (Red? Yellow? Green?). 2. I wanted to cover up some of the mistakes/ gashes on the metal. According to my powdercoating place you cant really do that with their process.
    I need to decide if I want to include the 120mm brackets to move air over the motherboard, as well as throw a couple 92mm fans to the bottom level to add some airflow over the pumps and hard drives. Thoughts? Add the fans or not? What colors should I paint the thing?
    I haven't built the fanbus or any of the lighting elements, those may have to wait until after I've gotten the majority of the case done, painted, and assembled.
    Got the side panels on:
    Really a very basic design, a little angle aluminum, some screws, and a couple rivets.
    I added the tabs to counteract a little bit of squatting the case has been exhibiting, they basically pull in the front and back panels, squaring the whole thing up. I've also been noticing that things haven't been fitting together as well as they were initially, so I'm probably going to have to remake some brackets to compensate.
    Long story short, I decided to tear the case down so I could begin cleaning up pen marks, sanding out some scratches, and getting the whole thing ready to paint.
    Things to note: 92mm blowhole in the back panel, 92mm blowhole in the motherboard tray, and mesh covered intake in the right side panel by the hard drive rack and pumps.
    So lets review: I tore the entire case down to each seperate piece. The whole thing was all laid out, all nice and pretty. All in all took me about an hour to drill all the rivets and unscrewing all the bolts. I dont know if I've mentioned this, but this is a school project, its required for me to graduate high school. I'm in the closing stages, where I have to get final approval from my "advisory panel" so that I can present my project. One of my panel members contacted me the morning after I had torn down Oracle and asked me to bring it in. Apperantly he didn't read the part about it being torn down. He's a nice guy though, very easy to get along with, so I wont hold it against him.
    Basically I had to put the whole thing together again, took me a good hour, maybe a little more. Used a little double sided tape to attach the mesh, and you've got a pretty good representation of the final product, minus the paint and lighting. As one of my best friends said "Damn, that som' bitc' looks like a mean motherf :baby: er" He's an odd one, a redneck who's pretty damn good with computers.
    So painting has been put off for a bit, since I've got a few more things to do before I get there.
    Things to do:
    - Custom PSU (details later)
    - Internal Lighting
    - External Lighting (Powerswitch plate & Feet)
    - Paint (Colors still undecided)
    Work Updates:
    Built a power switch plate.
    Some pictures of the tank in action. Pictures really dont convey how nice it looks. I took a couple quick videos with my digital camera, so the quality isn't the best. Both videos are around 9 megs and can be found HERE.
    Okay folks, this is just a real rough sketch of what I'm thinking. The water pump is positioned in between the tank and the rad, and the hard drive rack will be next to the air pump and behind the tank. I'm not going to be using velcro this time to hold the tank in, so I've added an extra piece that will allow me to use bolts to hold the tank in place. The fans are inside the shroud. The final build will probably involve the fans between the mount and the rad, but I haven't decided on whether I want to do a push or a pull configuration. The PSU's intake is from the bottom of the case, I forgot to label it.
    I'm also planning on adding lots of plexi accents, I'll post more details about that later.
    EDIT: One more thing, I'm switching from the AC loop to a Dangerden based high flow setup.
    So more sketchup fun! Yeah! You would not believe how long it took to make that stuipd air pump, and the 50Z wasn't fun either.
    Anyway, the only things that this sketch is missing are feet, the PSU mount, and the absurd amounts of mesh that will be involved here. There are also some plexi pieces that I haven't drawn up yet, so its not entirely complete. However, 90% of the structure is there.
    I know I know, more sketchup and no real work. I'm sorry, really I am!
    Anyway, on with the updated sketches:
    Notice the placement of the PSU, the inclusion of fans on the radiator, the orientation of the hard drive rack, the PSU mount, the feet, and the change in the air pump placement.
    The element I'm still wrestling with is how to get some airflow over the hard drive rack. I've got a couple ideas, but I have no idea how I'm going to shoe horn it in.
    Worked on the hard drive airflow situation, think I got it figured out. I use Coolermaster 120mm white LED fans, they're absurdly quiet and move enough air to be effective in this situation.
    There are only two things that I dont like about this design. The first is I have to remove the motherboard try to remove the harddrive rack, and the second is going to be my need for rather long SATA cables unless the ports are really close to the edge of the motherboard. Its also a pretty tight fit, so I'll have to be absurdly accurate to make it all fit right.
    I am Xtreme
    Apr 2005
    Upstate, NY
    I'm speechless
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    holly crap. you going to make those go into production? haha That is really some nice work... nice long and hard work.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Jan 2006
    Houston Texas
    Damn man....That's really a piece of art
    Xtreme Cruncher
    Aug 2006
    TN, United States
    Very nice. How much time do you have in that thing?
    Crunch for the cure!! Join the XS WCG Team
    Current Project (HOLY CRAP THIS THING IS OLD) Pics
    System:
    E6400@3.6 1.35v, 4x 250gb Hitachi sata drives(Raid0), 8800gts320, Asus P5B Deluxe, 4Gb crucial anniversary edition, 2xNEC dvd burners , Corsair hx520, Lian li v2100b
    Cooling:
    Loop 1: ddc2/petra's top, mcr220, storm rev 1
    Loop 2: Laing D5, mcr220, mcw30, mcw60
    Heat
    Oct 2004
    Quote Originally Posted by NickS
    I'm speechless
    Thanks!
    Quote Originally Posted by Nanometer
    I'd kill if someone wanted to produce more of these, I think that would be awesome. Heck, I'd probably give the design away if I got a few of them.
    Quote Originally Posted by SoulGG
    That's the goal. In the end I really want it to be very minimalistic and tasteful.
    Quote Originally Posted by smopoim86
    Ahhhh...500 hours? Depending on whether you count all the design time it could be much much more.
    Cheers!
    E
    Nov 2006
    Quote Originally Posted by endscape
    Thanks!
    Cheers!
    E
    500 hours?!? Man you are good at what you do. For the sake of anything that matters, unless you are retired, have inherrited a trust fund, or are just bored with life...PLEASE take this to production and try to make yourself a buck! Otherwise it aint worth it, IMO.
    Aug 2006
    Excellent work.
    Oct 2004
    Quote Originally Posted by davewolfs
    500 hours is a horribly conservative estimate I'm afraid, though the majority of the time has been spent in the design phase. I went through about 20 differant models before I arrived at the one I started building, and then about another 10 while I was laid up before I settled on this current plan.
    I am looking into getting a few made, but there is no way that I could get them produced cheap enough in the small quantities I'd want to be able to even make my initial investment back. So who knows? If I find someone with the facilities who would be interested in making a few I'd be more than happy to work with them.
    And no, I'm not retired or independantly wealthy, and my life is ridiculously interesting at the moment, but Oracle is my main hobby. I enjoy the designing aspect of the whole thing. I've gone through a lot of computer cases, and have never once found one that did everything I want. Oracle is close, but still doesn't do everything that I want/ need.
    The original inspiration for Oracle was another project of mine, an ambient noise producing desktop fountain that hasn't been built yet. I also wanted something that was understated, something you wouldn't notice until it was kicked on. Has anyone played with that new Samsung (?) MP3 player with the built in speaker? The one that has a completly blank face until you turn it on? That's what I was looking for. Several of the early revisons had touch sensitive buttons to further that look, those, however, got phased out. You can check out my design thread over at Bit-Tech.
    Oracle is meant to be as much a work of art as a computer case. Time is irrelavent at this point. If it takes me an hour or 1000 hours I'll put the time in to make what I've got in my head a reality.
    Feb 2006
    I think it's odd that the typical reservoir/t-line is meant to eliminate air bubbles yet you have gone to special lengths to inject air into the system.
    Outside of the noise factor- which would drive me crazy- have you actually tried a loop yet using this rez?
    What keeps the loop/blocks air-free?
    Sep 2005
    That is sick, I think it beats the hell out of the UFO's.
    Jul 2006
    NYC
    Wow just looks so awesome. I wish I had a workspace like that. Would love to mod all day
    Watch 24!
    Q6600 G0 w/ Scythe Zipang
    A Data 2x2gb DDR2-800
    Corsair 750w PSU
    8800GTX
    320gb Maxtor HDD
    Audigy 2 ZS
    RocketFish case
    Oct 2004
    Quote Originally Posted by clokker
    The air pump is really very quiet, you can barely hear it over the fans. I also plan on putting the pump in an insulated container to cut the noise down even more.
    The res functions perfectly fine with the air pump running. The air inlet is far enough from the pump intake that no bubbles were sucked in over a 72 hour period. The final revison of the tank might include a physical seperator to insure that nothing gets pulled in, but we'll see.
    Quote Originally Posted by Hey_Its_Cole
    That's the idea! The UFO's are gorgeous cases, and had there been a 16 inch model I probably would have used it for a base, but with only a 14 and an 18 inch model being made I decided not to.
    I am considering a Twice7 for my next not-from-scratch mod.
    Quote Originally Posted by Shift
    Its a fantastic shop, I <3 it. Once we get the new heater up in there it will be heaven.
    Jul 2006
    Minsk
    WoW... *speechless*
    Make me 1 :beer:
    Intel Core i7 860 @4000MHz [1.35v] | Thermalright Ultra 120 Xtreme [lapped]+ 2x Scythe SlipStream 1.2K rpm | Asus Maximus III Formula | 2x2Gb Crucial Ballistix BL25664BN1608.16FF @ PC12800 8-8-8-24 1.65V | Zotac GeForce GTX280 1024mb @ 700/1400/2600 | OCZ Vertex 2 60GB SSD | 1000Gb Western Digital 10EADS | 4x 2000Gb Seagate Barracuda LP ST32000542AS | Creative Xtreme Music SB0460 | Genius 5.1 Professional Home Theatre | Vantec Nexus NXP-205 | Dell 2407WFP | Thermaltake Toughpower 750W XT [60A@12V] | Thermaltake Kandalf Silver + modding
    Oct 2004
    Quote Originally Posted by iSlash
    WoW... *speechless*
    Make me 1 :beer:
    Sure, pay for the materials and I'd be happy to put one together for ya.
    Oct 2004
    And the hard drive airflow situation is solved! Air is pulled through the radiator and out the back, and takes a little detour through the PSU's intake, with the PSU also exhausting out the back. Make any sense?
    The Rad/ PSU shroud is going to be a to make, but I think I can manage.
    Metal is presently in the shop, half way through being cut, so I should have an actual picture update sometime this evening.
    Xtreme Cruncher
    Aug 2006
    Sydney, Australia
    Very nice creation. I love all the design and modelling work. I like to spend plenty of time thinking and drawing up designs too. Very challenging and rewarding and important for the build process.
    Of the homemade cases I've seen, this is the style of construction I had in mind myself.
    I might offer some constructive criticism though, you have gone to great lengths to fabricate all the pieces (barring drive cages, which I think is sensible too) but in some cases I expected you would have spent the extra time/effort to incorporate tabs/angle brackets into the rails etc themselves rather than adding an additional bracket. I hope you know what I mean. Given the rest of the design/contruction quality, it looks like an oversight/after thought.
    Excellent work all round. I look forward to seeing further progress updates and the finished product.
  18. #18
    Apr 2003
    Maryland
    Great project endscape.
    As a retired master machinist who worked as a sheet metal mechanic for a time I can say that you definitely have some skills.
    One question though. Any particular reason you used a pre-made HDD rack? With all that tooling & know-how I would think you would fabricate a cool rack as well.
    ~ SolTek SL-75FRN2-RL (nForce2) = 10x230fsb, 2.0/2/2/11
    ~ 1800+ DLT3C/VPMW/0307 ~ Leadtek 6800nu (unlocked 16/6)
    ~ PCP&C 425deluxe ~ Gskill "LE" 1gb TCCD/437 ~ 36gb Raptor/200gb Barracuda ~ SLK-900a
    The MIND is like a parachute - works best when OPEN
  19. #19
    Apr 2006
    City of Lights, The Netherlands
    No optical drives? Can be usefull it you want to use it as an avarage PC.
  20. #20
    Xtreme Recruit
    Oct 2006
    cider isn't cider unless it has alcohol in it and is warm
  21. #21
    Nov 2006
    Virginia
    My God...with your taste, skills, and drive for perfection you could have been a major player on the team that built the Bugatti!!!
    A sweeping bow to you and loud applause
  22. #22
    Oct 2004
    Quote Originally Posted by GAM
    I must confess that the brackets that hold the panels together were very much an after thought. Originally I had planned on using two U's of metal rather than six individual panels.
    Updates are on the way tonight, I promise.
    Quote Originally Posted by Susquehannock
    Thanks for the compliments, its certainy appretciated!
    The hard drive racks require a level of precision and repitition that I do not yet posess sadly, so I decided to go with something pre made.
    Quote Originally Posted by Helmore
    It really isn't meant to be an average PC, but I still wouldn't include an optical drive in anything unless it was meant to go into production. I really dont use an optical drive, my main PC doesn't even have one.
    Quote Originally Posted by flavoraid
    Quote Originally Posted by Chapper
  23. #23
    Oct 2004
    The case before I started to work on it again. The dust makes me sad , shows how long it sat haha.
    My metal place sent me steel . It shouldn't make much of a differance once its painted, save making the case a bit heavier in the back end.
    Marking up the back panel for the motherboard tray.
    After a bit of cutting.
    A bit more cutting.
    I actually ran out of dremel discs , so I had to make a little supply run .
    Got some of those snazzy new dremel quick change cutting discs
    The motherboard tray in place. There will be a sheet of plexi between the tray and the steel, I think I'm going to work on that tomorrow.
    My new favorite toy, a right angle adapter for my dremel.
    Sometimes a job calls for bigger tools , having a shop with built in air lines is a truly wonderful thing.
    Or REALLY big tools. That thing scares me, I dont touch it. My dad had it out for one of his projects.
    Sorry for the blur. Anyways, you can see the space cut for the fan, and the extra bit chopped out to allow for the power switch on the motherboard tray. I'll round that out and clean it up a bit before all is said and done
    Starting to work on the left side motherboard/ radiator mount.
    Dont know why this picture is here, but here it is so enjoy.
    A little preview of things to come.
    I dont have a problem. Shut up. They were on sale. Seriously.
    In other news, I ordered a few toys. SVC didn't have the radiator I wanted (BI Pro III) so I decided to go with the Black Ice GT Stealth 360 X-Flow since that's the only other decent radiator they had in stock and I wanted to get this order on its way. For those of you keeping score at home, you'll notice I have a 16 inch deep case and a 16.2 inch radiator. Basically the back port is going to hang out the back of the case, so I'm going to have to run a bit of tubing into the case. I think with the proper lighting and a bit of fancy cutting it will look awesome.
    So the radiator, a small pile of fans, and something else I cant remember are on their way to me, should be here Friday or Saturday.
    Hopefully tomorrow I'll get the bottom and the back mounted, along with the motherboard tray mounts fabbed up and installed.
    A question that someone posed on another forum: what hardware is going in Oracle? Honestly I haven't a clue. I like the way I have my computer set up now, so it wont be transplanted. A buddy of mine has volunteered to have his PC installed for the final photoshoot (for which he will also be the photographer as it happens), but other than that it will remain empty until I come up with a spare $1500 to put together a quality system. Unless some kind soul wants to donate some hardware...
  24. #24
    Oct 2004
    Well folks, I am officially very sick, so there wont be any updates of any sort for a few days at least.
  25. #25
    May 2006
    Adelaide, Australia
    Come live in Adelaide, South Australia and make me one.
    I can't fathom doing all of that work. Instant respect from me!
    xStraight Edgex
    Quote Originally Posted by Glyph View Post
    noise of that new drive might be deafening.
    "IS THAT THE NEW 20K RAPTOR IN YOUR RIG?"
    "WHAT?"
