I got this from a good friend
Fotos:
La placa completa se ve muy sexy en pcb negro
Epox se preocupo y le puso 2 conectores IDE a la placa, trae 8 conectores SATA y switchs on off en la placa misma
El tipico led que muestra los procesos al botear, ahora al parecer nos dira la temperatura de nuestro CPU en grados Celcius
Especificaciones:
CPU Socket:
Socket LGA775 for Intel Quad Core processor Q6000 series
Support Intel Core 2 Duo processor E6000/ E4000 series
Support Intel Dual core Pentium D 8xx/9xx series up to 3.6GHz
Support Intel Single core Celeron-D 3xx series, Pentium-4 5xx/6xx series, P4EE up to 3.8GHz
Support 533/800/1066 MHz front-side bus
Support Intel CPU manufactured in 65nm process.
Chipset:
Intel P965 + ICH8R (EP-5P965+ GLI only)
System Memory:
Four 240-pin DDR2 SDRAM DIMM sockets
Support 1.8v DDR2-533/667/800 DIMMs with dual channel architecture
Support single-sided or double-sided, non-ECC, DIMMs with 256Mb/512Mb/1Gb devices
Support up to 8GB system memory
Expansion Slots:
Three PCI connectors compliant with PCI v2.3
One PCI-Express (x1) connectors compliant with PCI Express 1.0a
One PCI Express (x16) connector compliant with PCI Express 1.0a
One PCI Express (x4) connector for extra PCI-E VGA in GLI (Graphics Link Interface) mode
EZ-IDE:
Two IDE interface (for 2 device) from onboard SiI3811A SATA-IDE converter for driver-free IDE
USB:
Ten USB connectors compliant with USB2.0 from embedded USB controller (4 connectors at rear panel)
S-ATA:
Six S-ATA II ports with up to 300MB/s bandwidth from ICH8R
LAN:
One Gb Ethernet from Realtek RTL8111B PCI-E (x1) controller
Audio:
Selectable 2, 6 or 8-CH audio from Realtek ALC883 HDA compliant CODEC
Support rear panel SPDIF Optical output.
Support Aux-In, CD-In
Support Front panel audio for Mic-In and stereo Line-out only.
(Front panel Line-out electrically shared with rear panel Line-out).
Support Jack detection for fool-proof audio device installation
Source: Chilehardware
