I did every mod available to this board today.
the Vcore and Vdroop turned out perfect.
now when I select 1.5 volts, it's 1.5 volts, not 1.38 volts...
and the droop, is virtually zero.
the Vdimm, I did with a 5K fixed resistor for a .2 offset, and that turned out perfect too. set 2.45 in bios, get 2.65 in windows.
worked great.
but the Chipset Mod (VMCH) has me very nervous as I wonder if the mod is correct...
I did the mod, exactly as shown here... but regaurdless of how much I tweak the VR, the voltages never match bios, or even surpass it.
I set 1.65 volts in bios, and measure it, even with minimum resistance at 0K or close, and I still only see 1.45 volt or close.
right now, I have it set at 1.45 volts in bios, and it only shows 1.28 volts when measured from the measure point shown.
now, I've done this mod twice today, trying to see if the VR was no good or something, and they are both fine, and the solder point is correct and theres no problem with the mod itself.
I also took readings of the VMCH when there was no mod, and the voltages again, didnt even come close to what bios says...
so I am worried that this may not be the proper read point for this mod...
and if it's not, then thats definatly a bad idea to be adjusting the VR, if the read point isn't right.
thing is... when I adjust the voltages, I am seeing a voltage change I can read with my meter...
however, even at absolute least resistance, the voltage is still far lower then I would expect...
like I said, set 1.65 volts in bios, and then measure it... it shows 1.45 volts max.
I can't think of whats going on here...
