Results 1 to 21 of 21
Thread: Nvidia 8800GTX single/SLI Overclocked
Threaded View
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Machine specs
    Asetek Vapochill LS R507 Modded -50 in bios
    Intel X6800 ES
    Intel QX6700 ES
    Nvidia Nforce 680i SLI mainboard
    Nvidia 8800GTX Stock heat sink
    Corsair Dominator 9136 C5D
    Corsair 620w PSU
    Its cooling off here in Vegas and a warm winters night breeze through the window gets me a ambiant 27c temp inside my case.
    I am using Ntune software to adjust the video card clocks to 686/2200 for my benches. I pulled the heatsink to check out mounting and replaced the thick gray TIM with some Zalman thermal grease ZM-STG1 and this enabled a slightly higher overclock, it gained me about 25Mhz benchable.
    The maximum memory overclock possible with Ntune is 2200Mhz, to reach higher speeds you can use Powerstrip.
    For my benches I did not adjust LOD or any setting in the control panels. I was getting best frame rate on all tests with just loading the driver and benching. No quality changes were made.
    Nvidia has made huge advancements in image quality, its drastic and without a doubt Nvidia holds the IQ crown. I have pushed the card to max possible detail in many games, for one Flight Simulator 10 maxed out flying in Las Vegas or NY City was a truely boggling display of the cards performance.
    Intel X6800
    Futuremark 3DMark 2001
    Futuremark 3DMark 2003
    Futuremark 3DMark 2005
    Futuremark 3DMark 2006
    Aquamark 3 700/2220
    QX6700
    SLI Results 680/2200
    Futuremark 2K6 - 20432
    http://service.futuremark.com/compare?3dm06=634993
    Futuremark 2K5 - 25831
    http://service.futuremark.com/compare?3dm05=2330563
    Futuremark 2K3 - 66574
    http://service.futuremark.com/compare?2k3=5053213
    Futuremark 2K1 - 78389
    http://service.futuremark.com/compare?2k1=9089621
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
