Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: E6600 lapping - 10C drop and pics!
    Aug 2006
    Lapped my E6600 today with this kit, good stuff and inexpensive.
    Pics:
    Getting the Scythe Infinity out of the P180s in and out without removing the board is a real ******.
    The HS after removing it.. you can see that there are some gaps in the contact between it and the IHS.
    You can see how concave the IHS was. I started at 800 grit since I didn't see any reason to be so rough, but it was taking too long. On to 400...
    Various stages of lapping, from start to finish. 400 grit was a lot faster, then went back to 800 and to 1000.
    The finer paper that came with the EasyPCKits package wasn't labeled in grit but in microns, like 40 microns and down from there. It didn't get the flawless mirror shine that I saw a lot of people get with 1200-2000 grit paper from the autoshop, but it was still flat nonetheless. The IHS is still highly reflective, just shows some scratches still. Having it absolutely perfect probably affects performance in no measurable way.. it just would have been nice
    Trying a new (for me) method of applying AS5. I used to do what a lot of other people do, spread a thin layer evenly with a card or razor blade. I'm told this is a bit better as the line goes straight over the two cores, so I'm giving it a shot. I know it looks like I jizzed a ton on there but I had to smudge it around as it was uneven.
    System back in place, that thing is heavy and it sucks to unhook it and move it about.
    Screencap of my OC and temps. Before lapping, on load it went up as high as 62C during the day. During most of Orthos it was 50-51C but I think it went down to 48 due to my room cooling throughout the night. The difference is quite excellent and it might get a little cooler once the AS5 settles. Idle temps are 40-42C both before and after lapping.
    This is the same OC I had before the lapping, I haven't had time to try and take it any higher. My voltage is set to 1.475 in the CMOS but this board notoriously vdroops by about .10v or so while on load which explains the 1.368v reading. I've been afraid to go higher than 1.475v (CMOS) since I wasn't comfortable with the 62C load temps from before, but I won't get higher than 400 FSB (8x multi) unless I do. With 9x I don't think I got higher than 360 FSB, which makes the 8x a better choice. I'd really like to get 400x9.. here's to hoping.
    A few things worth mentioning: I wrapped up my CPU in scotch tape with the plastic back piece on to make sure no pieces of nickel or copper got on the back of the CPU. I used 70% isopropyl rubbing alcohol to clean the CPU before and after lapping. While lapping, I didn't use any liquid of any kind; I read a lot of different opinions on whether or not to do it wet and I just decided not to so I wouldn't have to worry about it and it turned out fine. Maybe doing it dry is why I didn't get a perfect finish?
    And the pics are mirrored here in case Imageshack goes down.
    Sep 2005
    Denton, TX
    i lapped my e6400 today... that i got today... about 30 mins after i started testing it. It only dropped my temps a couple degrees unortunatly. But it did enable me to do 4ghz 1m pi stable.
    Good job there. Push it some more!
    Current 24/7 settings
    Delidded L628B e6400@ 3.6ghz 1.38v
    3.9ghz 1.56v dual prime, 4ghz dual 32m pi stable on water and P5B Deluxe
    Patriot 667 LLK @ 970 mhz 4-4-4-4 2.3v
    x1900xt 690/780
    Jun 2006
    Dr^_^Gon Land
    Quote Originally Posted by Soul Colossus
    wow , quite concave for sure !
    nice work then. I also change my way of applying thermal paste
    yours looks close to artic recommandations
    E8400@3.6ghz 1.11v |Asus P5E3 deluxe bios 1001| 2 giga Cellshock DDR3 12800@1696mhz|Samsung Syncmaster 2232BW 22' | Asus 8800 GTSē 512 TOP|Western digital sata 500 SE16 | Blu Ray LG GGW-H20LRB| Creative X-fi platinum|Nexus 600W | case Coolermaster 1000 "Storm"
    Xeon E3110@3.6ghz 1.15v|Asus P5K premium "blackpearl" bios 503|2 gigas Cellshock DDR2 8500 |Twintech 9600 GT|nec 1970 GX|Gigabyte 3D aurora case
    E8400(Q804A249) valid@ 4.8 ghz 1.56v
    Xeon E3110 (Q746A534)valid@ 4.79 ghz 1.59v real bios AIR /superpi 1m@9.968 .. under vista
    My Ibanez 540S " Saber "overclocked with Di Marzio and Sperzel
    My cousin on drums Hi Brian !
    May 2006
    I'm still amazed that Intel puts out this crap on such a quality product. Certainly adequate for stock speeds (which is all they care about, I guess.)
    MAIN: 4770K 4.6 | Max VI Hero | 16GB 2400/C10 | H110 | 2 GTX670 FTW SLi | 2 840 Pro 256 R0 | SB Z | 750D | AX1200 | 305T | 8.1x64
    HTPC: 4670K 4.4 | Max VI Gene | 8GB 2133/C9 | NH-L9I | HD6450 | 840 Pro 128 | 2TB Red | GD05 | SSR-550RM | 70" | 8.1x64
    MEDIA: 4670K 4.4 | Gryphon | 8GB 1866/C9 | VX Black | HD4600 | 840 Pro 128 | 4 F4 HD204UI R5 | 550D | SSR-550RM | 245BW | 8.1x64
    Xtreme 3DTeam Member
    Aug 2006
    Where You don't get nothin' for $
    Wow - nice work and a fine benefit for You.
    Any idea where to buy this kit ---> http://www.easypckits.com/products/premiumlk/ in Europe?????????
    If nothing works nomore......:
    Jan 2005
    The Netherlands
    Quote Originally Posted by camouflage
    Just e-mail the shop, he wil send to Europe.
    AMD Opteron 148 CABYE 0543 FPBW || DFI LanParty nF4 SLI-DR AD0
    2x 512MB OCZ PC3500 Limited Edition Winbond BH-5 || 2x 512MB Corsair PC3200LL V1.1 Winbond BH-5 || 1x 256MB Mushkin PC3500 LV2 Winbond BH-5
    SAPPHIRE X800GTO2 @ 16P 600/570, Voltmodded, GPU=1,7V/VDD/VDDQ=2,3V
    Zippy PSL-6720P(G1) GAMING ,POWER - I love it!
    Sep 2006
    did u polish or anything, or it just came out that shiny between the different grits?
    gigabyte 965p-s3
    intel c2d e6300 @ 3.255 24/7 (stock hs/f)
    corsair xms2 (twin2x1024a-6400c4) ddr2 800 @ 930 5-5-5-15
    xfx 7600gt @ 650/841 [560/725 stock] (stock hs/f)
    samsung spinpoint-p 160gb
    antec sonata2 w/ 450w trupower2.0 psu
    i love my budget gaming rig <3
    highest OC so far.
    May 2004
    Sherbrooke, Quebec, Canada
    Quote Originally Posted by ryaan
    I'm quite sure he didn't.
    I too lapped my e6700 yesterday. It came out shiny enough without any polish, I used 1500grit for the finish. With a Tuniq Tower 120 and Vcore at 1.45V (after vdroop), idle temp went from 51C to 46C and load temp went from 85C to 76C.
    Wolfdale e8400es @4.5Ghz / Ultra-120 Extreme
    2GB Ballistix @ 589Mhz 4-4-4-x @ 2.5V - SPI 32M
    *** Motherboards tested: DFI Blood Iron (current), Asus P5K3-dlx, DFI P965-S, P5B-Dlx, DFI RD600, Bad Axe 2, EVGA 680i, DS3 and P5W DH ***
    Fan modded Zippy 850W, 500GB 7200.11 and EVGA 8800GTX @678/1062
    Apr 2006
    what grade of ssand paper did you use? anything over 1000 needed?
    May 2004
    Quote Originally Posted by GrimReaper
    Not sure if you're asking me or him, but he used 400, 800, 1000 (written in his first post )
    I used 800, 1000, 1500
    Oct 2006
    Winnipeg Manitoba Canada
    How are you guys protecting the other side of the proc? Just use tape to cover it?
    May 2004
    Quote Originally Posted by arminkropp
    Used the black plastic cover that the cpu comes with
    Oct 2006
    Merci
    May 2004
    Merci
    Your welcome
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    Nice job
    Usualy on CPU's - I prefer thick layer of thermalpaste instead of lapping.. - Has nearly same effect..
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
    no sleep, always tired TheGoat Eater's Avatar
    Oct 2006
    Iowa, USA
    I got over twenty cuts - looked down at my hand when it felt wet and it was just covered in blood - well more than one half like three fingers pretty well smeared in blood.
    Sep 2006
    Quote Originally Posted by M.Beier
    Nice job
    when i gooped on alot of as5 my temps were higher... maybe god just hates me? =\
    gigabyte 965p-s3
    highest OC so far.
  18. #18
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    First of all, I use ceramique, which isnt that thick = easier to spread decently
    But no, if good contact, less is better, but if poor contact, more thermalpaste allows one to have contact, which enhance temp alot..
    - Lapped my mach II evap
    Spectating;
  19. #19
    Aug 2006
    Quote Originally Posted by Vassili
    Thanks mate - already done. Very kind reseller, just payed him via PAYPAL and will get the kit soon...........
  20. #20
    Oct 2006
    does anyone have extra sandpaper i could have? i could paypal you some money.
  21. #21
    I am Xtreme
    Dec 2002
    Quote Originally Posted by ingenue007
    You have no hardware or automotive store? You only need some 600grit.
  22. #22
    Oct 2006
    i have some 400 grit at the moment.
    do i need to do sequentially from 800-1500 or can i get away with buying just one pack of 800 or one pack of 1000? i just don't want to buy 3 packs of sandpaper and never use the rest again.
    do you guys lap your HSF also?
  23. #23
    I am Xtreme
    Feb 2005
    SiliCORN Valley
    anything above 800 isnt going to improve anything.
    all you have to do is let up on the pressure and just sand it lightly.
    and for anyone in the USA.
    go back to the automotive section where the autmotive paints are, they have 800, 1000 and 2000 grit paper for like a couple bucks.
    then march over to the picture section and buy a 99 cent picture frame that has glass in it.
    there ya go. and you spend less than 10 bucks and got the glass, 2000 1000 and 800 grit paper.
    i looked all over the place from hardware stores to a few automotive stores and the one place i never thought i would find it, i did,, right back in the auto section at walmart.
    "These are the rules. Everybody fights, nobody quits. If you don't do your job I'll kill you myself.
    Welcome to the Roughnecks"
    "Anytime you think I'm being too rough, anytime you think I'm being too tough, anytime you miss-your-mommy, QUIT!
    You sign your 1248, you get your gear, and you take a stroll down washout lane. Do you get me?"
    Heat Ebay Feedback
  24. #24
    Oct 2006
    35n28, 97w31
    Quote Originally Posted by Lestat
    A couple of days ago I must have spent an hour looking through my local Walmart big box and finally gave up. I couldn't believe such a big store didn't have what I was looking for. I went back with the information you provided and found what you described. Each package cost $3.08 but the display was empty. I was wondering if there are a bunch of overclockers in my neighborhood.
    Where did you find the picture frame that cost 99 cents? The closest that I found for a 5x7 frame with glass cost $2.81.
    | Intel Core i7-2600K | ASRock P67 EXTREME4 GEN3 | G.SKILL Sniper Series 8GB (2 x 4GB) DDR3 1866 | EVGA GTS 450 |
    | Swiftech APOGEE Drive II CPU Waterblock with Integrated Pump | XSPC RX360 | Swiftech MCP655-B Pump | XSPC Dual 5.25in. Bay Reservoir |
    | Thermaltake 850W PSU | NZXT SWITCH 810 | Windows 7 64-bit |
    [SIGPIC][/SIGPIC]
  25. #25
    Oct 2005
    99 cent store? :P
    anywho, same situation with sandpaper here - can't find any fine grit.
    dothan 730 @ 2.6Ghz l p4c800ed l 4x512MB bh5 2-2-2-5 5:4 ~3v l Antec Neo 480
    e6600 @ 3.6GHz l P5W64 WS Pro l 4x1GB D9GMH (B6-3) 3-3-3-3-12 4:3 2.2v l PCP&C 750
