Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: Schyte Infinity on 7900GT !!!!!!!
    Team KOC2.com
    Nov 2005
    Indonesia
    just enjoy the pics...
    a closer look
    the vmod
    pre testing with crappy AS5 (ex VF900cu). Core @ 705mhz with 1.55v vgpu. Mem @ stock.
    Team KOC2.com
    Nov 2005
    Indonesia
    the temp different with vf900cu about 10-15c...
    Feb 2004
    Finland
    That's one big gpu cooler you got there I just wonder how long are those zipties going to last.
    [i5 2500K, ASrock extreme3 gen3, Corsair Vengeance LP 8GB 1600MHz, Palit GTX570 Sonic Platinum, CM HAF932, Antec Truepower New 650w]
    Team KOC2.com
    Nov 2005
    Indonesia
    still searching mod for putting screw there....
    Jan 2003
    Gent , Belgium
    MAASSSIIIIVVVVVVVV!!!
    now that's exactly what i would do in my dreams (provided that there's a more sturdy way to mount than zip ties)
    q:
    how much overlap do you have at the bottom of your mobo?
    Team KOC2.com
    Nov 2005
    Indonesia
    if you means gaps between infinity and PCI/PCI-e Slot than it has no gaps....
    the infinity uses the slot (PCI) as its 'bed' due to the PCI-e Slot were lower and it makes the infinity perfectly sleep on the pci slot...
    Jan 2003
    Gent , Belgium
    ok, not what i meant, but good to know that that's a perfect fit;
    no what i meant is how much does the infinity stick out from under your mobo? in my case i have about 1cm (0.3inch) between the bottom of my case and the bottom of my mobo. if the infinity sticks out more than 1cm i'd be screwed ...
    Nov 2005
    The Netherlands
    lol , how did you manage to attach it to the card ?
    Team KOC2.com
    Nov 2005
    Indonesia
    cable ties did the job quiet nicely
    i think its arround 3cm....
    Nov 2004
    Denmark
    Quote Originally Posted by TaPaKaH
    The universal method... Zipties!
    Friggin' awesome job there mate, try sending NightCrawler(tm) a PM, he could probably help you out with the mounting (he did a CNPS9500 once)..
    Best REgards
    Silverstone RAVEN RV02|
    Core i5 2500K@4.4GHz, 1,300V|
    Corsair A70|ASUS P67 Sabertooth|Creative X-Fi Titanium Fatal1ty|
    Corsair Dominator DDR1600 4x4096MB@DDR3-1600@1.65V|Sapphire HD7970 3GB 1075/1475MHz|
    Corsair Force F120 120GB SSD SATA-II, WD Caviar Black 2x1TB SATA-II 32mb, Hitatchi 320GB SATA-II 16mb|Silverstone DA750 750w PSU|
    Jul 2006
    Maryland - US
    WOW! thats awsome
    zip-ties rule, cant wait to see some load temps.
    Cooler Master Stacker 810 WATERCOOLED
    Black Ice GTX 360 // Danger Den TDX CPU WB //
    Maze 4 GPU WB // D5 Pump // SwifTech Micro Res.
    ASUS P5B DELUXE // E8400 @ 4410MHz 490*9 1.41v
    2x2GB MUSHKIN ASCENT DDR2 1066
    SAPPHIRE OC HD5970 2Gb @ 900-1150
    Corsair HX1000w // SB Audigy 4
    Team KOC2.com
    Nov 2005
    Indonesia
    you can see the load temps on Riva tuner.... it was while artifact scanning for 20min on 1.55v - 705mhz core... 43c
    Xtreme Legend
    Mar 2005
    Australia
    have you tried placing that fan on a side maybe rather than top
    that's extreme but let's see some extreme air OCs now heheheh
    Team.AU
    Got tube?
    GIGABYTE Australia
    Team KOC2.com
    Nov 2005
    Indonesia
    actually i put 2 fan... one on top and one on side....
    well, actually i already do some benches but so far it doesnt increase my gpu core.... it still stuck at 765mhz (120mhz pcie) for bench...
    need to mod to 1.7v ... i think the cooler could handle it
    Dec 2004
    The Holy Land
    what , cool one
    Asus P5-E X38 Intel QX9650 INOO3D 9800 Gx2 4x Super Talent's T800UX2GC4
    Creative X-Fi Raid 0 Raptors 36Gb data 1Tb Seasonic M12 700w
    Dell 2407WFP Lian-Li Pc-65 mod Custom Built Phase Change Unit |Logitech G25|
    RIG#2: DFI LANPARTY LT X48-T2R|Q9550| INOO3D 9800GTX|
    2xCellshok 1000| PC Power and cooling 750w Thermaltake v1
    Wife: DFI LANPARTY UT P35-T2R|Q930|BFG 8800GTS 512MB|
    Samsung ddrII 667| PC Power and cooling 610eps12v Thermaltake v1
    Htpc:Dfi Sli-Dr Venus|3700+|2x1gb Team Group ddr500|Thermaltake Mozart TX
    I am Xtreme
    Apr 2005
    Upstate, NY
    Wow dude, that is just sick!
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Sep 2006
    That poor card. I'm sure it's super cool, but the weight must be out of this world. If someone else is crazy enough to do this, I'd say go with a Thermalright Ultra-120 or SI-128. Same performance with way less weight. Still crazy as hell though.
    God's in his heaven, all's right with the world.
    AMD Athlon 64 4000+, ASUS A8R32-MVP Deluxe, eVGA GeForce 8800 GTX, 1Gb OCZ RAM, WD 10k RPM Raptor and 7.2k RPM Caviar, Thermalright SI-128 ,Lian-Li PC-V1000 Plus II
  18. #18
    Team KOC2.com
    Nov 2005
    Indonesia
    the card takes no weight from the cooler, maybe this pics can explain...
  19. #19
    Apr 2006
    Quote Originally Posted by andre X_X
    good job
    but the card sure looks a bit bend
  20. #20
    Xtreme Mentor
    May 2005
    Westlake Village, West Hills
    The card does look like it is bent hehe. That's a freaking huge cooler on the card. There goes all your PCI slots lol. I like your vmod, not the cleanest but it's very organized.
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
  21. #21
    Sep 2006
    i was about to say wow why didnt ur card break in half lolol, then i saw this
    sick bro lol
    gigabyte 965p-s3
    intel c2d e6300 @ 3.255 24/7 (stock hs/f)
    corsair xms2 (twin2x1024a-6400c4) ddr2 800 @ 930 5-5-5-15
    xfx 7600gt @ 650/841 [560/725 stock] (stock hs/f)
    samsung spinpoint-p 160gb
    antec sonata2 w/ 450w trupower2.0 psu
    i love my budget gaming rig <3
    highest OC so far.
  22. #22
    Aug 2005
    very nice mod.
  23. #23
    Xtreme Cruncher
    Jul 2005
    London - UK
    Now try putting it in a vertical case
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
  24. #24
    Oct 2005
    israel
    OMG!
    nice one.
    e2160
    ip35-e
    Geil 2048MB 800MHZ
    hd 2600xt
    western digital 250gb
    Corsair VX 450W
    hec 6a19
  25. #25
    Mar 2006
    York, England
    Looks good! May need a taller case now or cut hole into your current one and put the case on stilts
