Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Looking for "Fatbody" D9DQW 1GB stick dumps.
    Xtreme 3D Team
    Jan 2006
    Canada
    I have a couple of pc-3200 1GB non-ecc dell memory sticks with the Micron Fatbody D9DQW ic's but need to reprogram them for pc2-4200 or higher to get them to work in my P5B-D. If anyone has please PM it to me or upload it and let me know. If you need more information please let me know.
    Jan 2006
    France
    I think that they can work fine without better SPD
    Xtreme 3D Team
    Jan 2006
    Canada
    Quote Originally Posted by jmax_oc
    What do you mean? They wont event boot at stock settings because my motherboard cant recognize pc-3200, they need to be pc-4200 and up.
    Anybody have any dumps I can use, they have to be 1GB with D9DQW ic's.
    Oct 2005
    Curitiba - Brazil
    G0 Q6600 | GIGABYTE DS3R | 2GB SAMSUNG 800 | 7600GS | BENQ 1640 | VANTEC STEALTH 470w PSU
    The Canuck
    Oct 2002
    Montreal, Canada
    I'm in the same boat as you.
    Also, looking for D9DQW 1GB dumps
    Xtreme 3D Team
    Jan 2006
    Canada
    Thanks but already saw that thread, unfortunatly they have dumps for 512mb sticks not 1gb.
    Quote Originally Posted by MACMAC
    MACMAC, are you able to get your sticks to bootup at all? What motherboard are you using?
    Feb 2005
    U.K.
    I'll help if i can guys,i have 2 x 1gb patriot pc5600 xblk with D9DQW.You'll have to tell me what you want me to do though.
    Xtreme 3D Team
    Jan 2006
    Canada
    Check your PM Thickbrit.
    Feb 2005
    U.K.
    I hope this works.
    Attached Files Attached Files
    INTEL inside
    Oct 2004
    Québec, Canada
    Quote Originally Posted by Thickbrit
    I hope this works.
    thanks, we will see if it works later today !
    retired computer enthusiast
    The Canuck
    Oct 2002
    Montreal, Canada
    I hope this works.
    Hey, I just opened your dump in Thaiphoon and it says 512MB modules
    However, from what I can gather, it appears to simply be a Thaiphoon bug...
    Feb 2005
    U.K.
    Must be,because they are 1gb sticks, pdc22g5600 xblk.
    INTEL inside
    Oct 2004
    Québec, Canada
    still looking for D9DQW 1gig stick dump
    Xtreme 3D Team
    Jan 2006
    Canada
    Quote Originally Posted by Supertim0r
    Whats wrong with the one a couple posts above?
    SSD faster than your HDD
    Feb 2005
    Kalamazoo, MI
    All sticks say that in Thaiphoon, if he took them off 1GB sticks, then they are 1GB dumps.
    The Canuck
    Oct 2002
    Montreal, Canada
    Quote Originally Posted by MTP04
    I just didn't like the fact that they apparently default at 200Mhz/PC2-3200, but it will be tested tomorrow.
    Xtreme Legend
    Nov 2003
    Helsinki, Finland
    Finally I found some time to write a custom SPD for you guys.
    If your modules match these specs, you are good to go:
    Type: DDR-II SDRAM
    Capacity: 1024MB
    Configuration: 64M x 8
    Ranks / Banks: 2 (Double sided)
    Data Width: 64
    Frequency / Timing Table
    DDR-533MHz @ 3-3-3-10-15 (tCL-tRP-tRCD-tRAS-tRC)
    DDR-667MHz @ 4-4-4-13-19 (tCL-tRP-tRCD-tRAS-tRC)
    DDR-800MHz @ 5-4-4-15-22 (tCL-tRP-tRCD-tRAS-tRC)
    Target IC
    D9DQT, D9DQW, D9DRD, D9DQZ, D9DQR, D9DQP
    Click here to download.
    Load it to Thaiphoon Burner and fully rewrite the desired sticks with this SPD file.
  18. #18
    INTEL inside
    Oct 2004
    Québec, Canada
    Thanks The Stilt !
  19. #19
    The Canuck
    Oct 2002
    Montreal, Canada
    Ok, so the flash has been successful, and it does boot up wonderful at DDR2-800 5-4-4 at 1.8V
    Now all we have to see is whether it will boot up in a P5B-Deluxe!
  20. #20
    INTEL inside
    Oct 2004
    Québec, Canada
    they won't boot on the P5B DX and P5W DH
    well, this is MACMAC Fat Body :
    stock memory :
    mobo used to test/flash :
    after :
  21. #21
    The Canuck
    Oct 2002
    Montreal, Canada
    Well we are all very confused.
    No matter what SPD, timings, voltage these sticks will not boot in a P5B!
    Will boot fine in a plethora of other motherboards, but just will not boot in an Asus
    Basically all out of ideas on my end!
  22. #22
    Aug 2006
    I'm stuck with the same problems with these D9DQW's and my P5B Deluxe. Perhaps a bios update will help if someone tells Asus??
  23. #23
    The Canuck
    Oct 2002
    Montreal, Canada
    I'm absolutely sure a new bios would help, but I don't think Asus is going to allocate any resources to ensure compatibility for us "OEM" D9DQW owners, who represent a miniscule minority of users.
  24. #24
    Aug 2006
    Perhaps someone could make a modified bios that'll work, if there's anyone here that knows how to do that. I don't think it'd it would take too much resources on Asus's part to fix this compatibility issue.
    What motherboard were you able to get it to work with and how high can you push these sticks to at any specific voltage?
  25. #25
    Xtreme Legend
    Mar 2005
    Australia
    hmmm i can buy some D9DQW 1GB kit but after reading this it seems even after flashing they won't work right
    Team.AU
    Got tube?
    GIGABYTE Australia
